| Re: Pls. critique Nacra 5.2 spinnaker idea
[Re: DennisMe]
#169994 03/02/09 09:14 AM 03/02/09 09:14 AM | andrewscott
| andrewscott
Unregistered | Just do it! Enough drawings... go rig your spin and capsize already!!!! (just kidding)
i have my tack line and cleat go the front beam, about 1' away from the mast. | | | Re: Pls. critique Nacra 5.2 spinnaker idea
[Re: ThunderMuffin]
#170055 03/02/09 01:02 PM 03/02/09 01:02 PM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | Dennis, That's exactly how I have the spin rigged on my FX-1. It's a great setup. I tried to use a spinlock on the mast for the halyard like the F-18 guys do, but sailing singlehanded, the angle was wrong. And the slightest bump would cleat the halyard. Flipped a couple of times from that. I had to get too far away from the tiller  I just used a Ronstan swivel cam cleat on the fwd xbar. Take the strap off of the top of it so that you can flip the swivel 90deg and get the halyard completely out of the cams. Sometimes if the halyard rests back on the cleat, the line would re-cleat itself during the douse. There are a few diagrams here. Scroll down to sails and look at spinnaker setups. Or scroll to the FX-ONE and tiger diagrams. Hope that helps. You're system looks great. J
[Re: DennisMe]
#174689 04/13/09 01:53 PM 04/13/09 01:53 PM |
Posts: 31 GA | Brought "Second Chance" back up to par. Dennis I just finished with the spin addition to my 5.2. She is old but has been completely rebuilt for single handed sailing. Including a self tacking jib, 16-1 cunningham lead to each side, carbon fiber bow foil, carbon fiber spin pole, downhaul on the jib, H16 spin, mid pole snuffer, rudder crossbar mods equal no play, 10-1 mainsheet, mast rotation control lead to each side, jib sheets contained inside front crossbar, and lots more. Here are some pics that might help you with your boat. ![[Linked Image]](http://www.saylorspecialties.com/nacra/dadsnacra.jpg) My 5.2 with out spin ![[Linked Image]](http://www.saylorspecialties.com/nacra/DSC00039.jpg) H16 spin ![[Linked Image]](http://www.saylorspecialties.com/nacra/DSC00036.jpg) TackLine ![[Linked Image]](http://www.saylorspecialties.com/nacra/DSC00034.jpg) Spin Sheet ![[Linked Image]](http://www.saylorspecialties.com/nacra/DSC00033.jpg) Spin Sheet Blocks [img] http://www.saylorspecialties.com/nacra/DSC00032.jpg[/img] Front crossbar and spin bag [img] http://www.saylorspecialties.com/nacra/DSC00031.jpg[/img] Bow foil, spin pole. [img] http://www.saylorspecialties.com/nacra/DSC00029.jpg[/img] Spin Hoop [img] http://www.saylorspecialties.com/nacra/DSC00027.jpg[/img] Line for pole prebend. Found that I need to add a little more bend. [img] http://www.saylorspecialties.com/nacra/DSC00025.jpg[/img] Tackline exit and cleat, spin halyard cleat (going to change block and add stand up spring) | | | Re: Pls. critique Nacra 5.2 spinnaker idea
[Re: saylor_nacra]
#174694 04/13/09 02:06 PM 04/13/09 02:06 PM |
Posts: 31 GA | More photos ![[Linked Image]](http://www.saylorspecialties.com/nacra/1.jpg) Spin Pole end attachment lines and tackline. ![[Linked Image]](http://www.saylorspecialties.com/nacra/2.jpg) Spin attachment point at cross bar. ![[Linked Image]](http://www.saylorspecialties.com/nacra/3.jpg) Spin pole attachment point at back of pole. (Don't use bolt, just pin it now) ![[Linked Image]](http://www.saylorspecialties.com/nacra/4.jpg) Spin halyard turning block on mast (have put heat shrink cover on red lines). Still doing some tweaking with line placemant and housekeeping while sailing. But she handles great under spin, a lot to keep up with for one person. The self tacker takes care of herself. Set the main and forget, play with spin sheet and drive. If you have any questions or would like more specific photos let me know. All the custom carbon, spin hoops and bags/socks I build and have for sale. Thanks, Carl Saylor Specialties L.L.C. www.saylorspecialties.com | | | Re: Pls. critique Nacra 5.2 spinnaker idea
[Re: saylor_nacra]
#174713 04/13/09 04:28 PM 04/13/09 04:28 PM |
Posts: 1,203 uk | Nice work be carefull of the 16;1 down haul, the lug on the halyard won't take it maxed out. you don't need much downhaul on a soft rig anyhow. likewise, be carefull of the 10;1 mainsheet on that boom. The clew of the sail does not line up with the sheeting point so you will be trying to bend the boom!
[Re: TEAMVMG]
#174722 04/13/09 05:16 PM 04/13/09 05:16 PM |
Posts: 12,310 South Carolina | Nice work be carefull of the 16;1 down haul, the lug on the halyard won't take it maxed out. you don't need much downhaul on a soft rig anyhow. likewise, be carefull of the 10;1 mainsheet on that boom. The clew of the sail does not line up with the sheeting point so you will be trying to bend the boom! Agreed - with 16:1 you will probably be able to break something... The sheet attachment point on the boom looks stock, however.
Jake Kohl | | | Re: Pls. critique Nacra 5.2 spinnaker idea
#174728 04/13/09 06:22 PM 04/13/09 06:22 PM | Scarecrow
| Scarecrow
Unregistered | Dennis,
If you go with the seperate tack line like in your second sketch run the tack line through the back carabiner and then to the second one and get rid of the shock cord. When you pull the tack line on (kite up) this will give you slack in the halyard/retreval line. Then as you douse the kite and the tack line runs forward it will suck up the slack and everything will be nice and tidy. If you then run a retreval point to the clew as discussed in the f16 forums at length (do a search) you'll end up with a nice tidy tramp upwind. | | | Re: Pls. critique Nacra 5.2 spinnaker idea
[Re: DennisMe]
#174926 04/15/09 11:28 AM 04/15/09 11:28 AM |
Posts: 976 France | The H16 spin looks about right to me, did you have any trouble getting the right sheeting angle set up?
I've attached the spin sheet blocks to the side stay. Angle is fine. I think it could be pushed back a little bit to be perfect, but considering that the H16 spi I have is a second hand bag bought on ebay for a pittance it's not worth the trouble of making holes in my hulls. On my stealth the spin blocks are set up on the trampoline, but I don't trust the old trampoline on my Nacra to do the same. | | | Re: Pls. critique Nacra 5.2 spinnaker idea
[Re: pepin]
#174929 04/15/09 11:41 AM 04/15/09 11:41 AM | andrewscott
| andrewscott
Unregistered | | | | Re: Pls. critique Nacra 5.2 spinnaker idea
[Re: DennisMe]
#174988 04/15/09 09:39 PM 04/15/09 09:39 PM |
Posts: 31 GA | I modified the H16 spinnaker a bit, Took it into my shop and took a little off the foot of the sail mostly towards the clew to raise the clew about a 6". I attached the turning block to the side stay. The spin hoop I make myself, I made the molds last year and have sold a few. They are the same size and design as in the link from performance NACRA. I have the bags made in florida in two lengths one for the shorter boats like mine and the other for 18'+. If you are making a one off hoop there are lots of ways to do it, one way would be to use a foam ring and glass over it. Carl Saylor Specialties L.L.C. www.saylorspecialties.com | | |
2,593
guests, and 166
