Mixed fleet - pointing ability - who gives way #170890
03/08/09 10:15 PM
03/08/09 10:15 PM
Hobart, Tasmania, Oz.
Dazz Offline OP
Dazz  Offline OP
On the weekend we had a mixed regatta, all in from 14ft paper tigers up to a-cat/F18
I'm hoping some one can clarify who has right of way when a quicker boat sails underneath a slower one and calls them up.
what has been happening is particularly off the start line, the faster boats are getting trapped below the smaller ones. the faster boat being covered doesn't have much more speed sometimes not at all but still can point very much higher.
The little boat sailors says they are sailing their proper course and refuse to point higher.
to my mind the overtaking boat should keep clear but I can see where the windward boat should keep clear too.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Mixed fleet - pointing ability - who gives way [Re: Dazz] #170892
03/08/09 10:21 PM
03/08/09 10:21 PM
Adelaide, South Australia
simonp Offline
simonp  Offline
simple: when boats on same tack the windward boats keep clear.
Simon
BLADE F16 AUS405
Re: Mixed fleet - pointing ability - who gives way [Re: simonp] #170894
03/08/09 10:55 PM
03/08/09 10:55 PM
Scot Offline
Scot  Offline
If the overlap was established from clear behind (likely the case here), the leeward boat can not go above her own proper course (closehauled). If this happens to be higher than the windward boats proper course, then tough luck for the windward boat!
Re: Mixed fleet - pointing ability - who gives way [Re: Scot] #170896
03/08/09 11:55 PM
03/08/09 11:55 PM
Tornado_ALIVE Offline
If you are the faster boat, don't get caught up in this game. Foot off a little, get in front, sheet on and get out of there. You may have all the rights to squeeze the other boat up but in the big picture it will slow you down whilst your competitors sail off.
Re: Mixed fleet - pointing ability - who gives way [Re: Tornado_ALIVE] #170898
03/09/09 12:12 AM
03/09/09 12:12 AM
ncik Offline
ncik  Offline
Agreed, being right doesn't equal being fast.
Re: Mixed fleet - pointing ability - who gives way [Re: ncik] #170900
03/09/09 12:33 AM
03/09/09 12:33 AM
Dazz Offline OP
Dazz  Offline OP
Preaching to the choir!
It not me but I watched it happen plenty of times this weekend and there was a lot of talk around the club.
"Darph Bobo"
Re: Mixed fleet - pointing ability - who gives way [Re: Dazz] #170901
03/09/09 01:05 AM
03/09/09 01:05 AM
Seattle,Wa
Don_Atchley Offline
Don_Atchley  Offline
Seattle,Wa
But can the windward boat be force to sail any higher than close-hauled and proper course?
What if the overlap exists right from the start?
Hobie Tiger 2003
Re: Mixed fleet - pointing ability - who gives way [Re: Don_Atchley] #170904
03/09/09 02:53 AM
03/09/09 02:53 AM
ncik Offline
ncik  Offline
If all else fails, windward boat must keep clear, overlap created from clear astern or otherwise. If windward boat believes leeward boat is sailing above close hauled after establishing overlap from astern, then windward boat needs to yell loudly or protest.
Re: Mixed fleet - pointing ability - who gives way [Re: ncik] #170907
03/09/09 04:21 AM
03/09/09 04:21 AM
45degApparent Offline
Thats why you need to plan your start carefully when racing mixed fleet. Both windward and leeward loose in this scenario.
Windward need to keep clear of leeward, so poor luck for those who can not point. Both loose in that scenario though.
Re: Mixed fleet - pointing ability - who gives way [Re: ncik] #170917
03/09/09 07:08 AM
03/09/09 07:08 AM
yes, Windward boat keeps clear.
states that they believe the leeward boat is sailing above proper course; shouts protest and then tacks away. As give way boat you need to prove "in the room" that the other boat was wrong. If you force them to avoid you, you will almost certainly get binned in the room.
Re: Mixed fleet - pointing ability - who gives way [Re: scooby_simon] #170921
03/09/09 08:02 AM
03/09/09 08:02 AM
Arkansas, USA
C
CaptainKirt Offline
CaptainKirt  Offline
C
Arkansas, USA
Seems like if a Paper Tiger tried to protest an "A" cat for instance in this scenario they would likely lose on general merits of the two boats "in the room", I think it would be hard to "prove" otherwise. Agree smartest thing to do is set your start up different if possible though.
Kirt
Kirt Simmons
Taipan, Flyer
Re: Mixed fleet - pointing ability - who gives way [Re: CaptainKirt] #170947
03/09/09 01:14 PM
03/09/09 01:14 PM
This is why you should never ever start above an A cat.
Re: Mixed fleet - pointing ability - who gives way [Re: Robi] #170957
03/09/09 02:04 PM
03/09/09 02:04 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Clear Air is king..
In a slower boat with no boards...aka a Dart 18... you need to set up your start so that you can tack onto port ASAP. Even if you nail the start... you know you won't be able to hold your lane and will be over run to weather and you also have to keep clear of leeward boats. Tack for clear air so that you can sail to your rating number!
If it's a short start line... plan to start in the second row at the boat end... you can tack for clear air almost immediately and have only lost a boat length or two to get to clean air. It is also much much less frustrating then a futile battle with an A cat or Tornado
crac.sailregattas.com
Re: Mixed fleet - pointing ability - who gives way [Re: scooby_simon] #170976
03/09/09 03:07 PM
03/09/09 03:07 PM
brucat Offline
brucat  Offline
If it's blowing like stink, and you're on a Hobie 16, it doesn't matter. Start wherever you want, and double trap out. The big boats will be too busy trying to stay upright to bother you.
Any other time, do what Mark said, or start at the pin and foot like a mother...
Re: Mixed fleet - pointing ability - who gives way [Re: Dazz] #171009
03/09/09 04:22 PM
03/09/09 04:22 PM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
Two rules (more if you want to get complicated) apply in this situation: RRS 11 "On the same tack, overlapped" and RRS 17 "On the same tack, proper course".
Rule 11 (a.k.a. windward/leeward) states "When boats are on the same tack and overlapped, a windward boat shall keep clear of a leeward boat". In the given scenerio, the windward boat is required to keep clear.
Rule 17 states "If a boat clear astern becomes overlapped within two of her boatlengths to leeward... she shall not sail above her proper course...". This is a restriction on the action of the right-of-way boat. Assuming in this case, that the leeward boat established overlap from clear astern within two of HER boatlengths, she may not sail above HER proper course. If, however, leeward's (L) proper course is above windward's (W) proper course (i.e. L can point higher), then W is out of luck. She must keep clear, even if it means luffing, stalling, or tacking away.
Eric
Re: Mixed fleet - pointing ability - who gives way [Re: Isotope235] #171020
03/09/09 05:01 PM
03/09/09 05:01 PM
brucat Offline
brucat  Offline
Following up on my earlier message, for light to moderate air...
If you're on a slow (non-pointing) boat, probably the worst place to start is the middle of the line. You get rolled by the fast boats that started between you and the starboard end, and pinched out by boats that started between you and the pin.
If a pointy boat is below you, the smart ones won't actually try to head you up. They may foot a little, and will just outpoint you enough to come up under your bow, cross in front, and kill you with dirty air. If you're trapped and can't tack out because of boats above you, you will die a slow and miserable death...
Re: Mixed fleet - pointing ability - who gives way [Re: brucat] #171024
03/09/09 06:29 PM
03/09/09 06:29 PM
Like I said to that Hobie 16 that reach in on top of me and my a-cat during a mixed regatta late last year..."you don't want to be there". The response? "Oh yeah? last I checked I was in this start too". The gun went off and I sheeted in, jumped on the wire, and proceed on my proper course pointing to the moon as I chuckled at the quiet mumble of obscenities from the other boat.
Re: Mixed fleet - pointing ability - who gives way [Re: Jake] #171027
03/09/09 06:33 PM
03/09/09 06:33 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Some people just don't understand friendly advice.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Mixed fleet - pointing ability - who gives way [Re: Jake] #171032
03/09/09 06:53 PM
03/09/09 06:53 PM
Yep exactly, I learned this the hard way, never ever dever again!
Re: Mixed fleet - pointing ability - who gives way [Re: Isotope235] #171039
03/09/09 08:51 PM
03/09/09 08:51 PM
Seattle,Wa
Don_Atchley Offline
Don_Atchley  Offline
Seattle,Wa
Eric,
Thanks for tying that together for me. smile
Hobie Tiger 2003
0 registered members (), 4,623 guests, and 532 spiders.
