| Mixed fleet - pointing ability - who gives way #170890 03/08/09 10:15 PM 03/08/09 10:15 PM |
Joined: Sep 2006 Posts: 586 Hobart, Tasmania, Oz. Dazz OP
Posts: 586 Hobart, Tasmania, Oz. | On the weekend we had a mixed regatta, all in from 14ft paper tigers up to a-cat/F18
I'm hoping some one can clarify who has right of way when a quicker boat sails underneath a slower one and calls them up.
what has been happening is particularly off the start line, the faster boats are getting trapped below the smaller ones. the faster boat being covered doesn't have much more speed sometimes not at all but still can point very much higher.
The little boat sailors says they are sailing their proper course and refuse to point higher.
to my mind the overtaking boat should keep clear but I can see where the windward boat should keep clear too.
| | | Re: Mixed fleet - pointing ability - who gives way
[Re: ncik]
#170900 03/09/09 12:33 AM 03/09/09 12:33 AM |
Posts: 586 Hobart, Tasmania, Oz. | Preaching to the choir!
It not me but I watched it happen plenty of times this weekend and there was a lot of talk around the club.
[Re: Dazz]
#170901 03/09/09 01:05 AM 03/09/09 01:05 AM |
Posts: 334 Seattle,Wa | But can the windward boat be force to sail any higher than close-hauled and proper course? What if the overlap exists right from the start? Hobie Tiger 2003 | | | Re: Mixed fleet - pointing ability - who gives way
[Re: ncik]
#170917 03/09/09 07:08 AM 03/09/09 07:08 AM |
Posts: 3,528 Looking for a Job, I got credi... | But can the windward boat be force to sail any higher than close-hauled and proper course? What if the overlap exists right from the start? yes, Windward boat keeps clear. If all else fails, windward boat must keep clear, overlap created from clear astern or otherwise. If windward boat believes leeward boat is sailing above close hauled after establishing overlap from astern, then windward boat needs to yell loudly or protest. states that they believe the leeward boat is sailing above proper course; shouts protest and then tacks away. As give way boat you need to prove "in the room" that the other boat was wrong. If you force them to avoid you, you will almost certainly get binned in the room.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Mixed fleet - pointing ability - who gives way
[Re: scooby_simon]
#170921 03/09/09 08:02 AM 03/09/09 08:02 AM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | Seems like if a Paper Tiger tried to protest an "A" cat for instance in this scenario they would likely lose on general merits of the two boats "in the room", I think it would be hard to "prove" otherwise. Agree smartest thing to do is set your start up different if possible though.
Kirt
Kirt Simmons Taipan, Flyer
[Re: Robi]
#170957 03/09/09 02:04 PM 03/09/09 02:04 PM |
Posts: 3,116 Annapolis, MD | Clear Air is king..
In a slower boat with no boards...aka a Dart 18... you need to set up your start so that you can tack onto port ASAP. Even if you nail the start... you know you won't be able to hold your lane and will be over run to weather and you also have to keep clear of leeward boats. Tack for clear air so that you can sail to your rating number!
If it's a short start line... plan to start in the second row at the boat end... you can tack for clear air almost immediately and have only lost a boat length or two to get to clean air. It is also much much less frustrating then a futile battle with an A cat or Tornado
crac.sailregattas.com
[Re: Dazz]
#171009 03/09/09 04:22 PM 03/09/09 04:22 PM |
Posts: 807 Hillsborough, NC USA | Two rules (more if you want to get complicated) apply in this situation: RRS 11 "On the same tack, overlapped" and RRS 17 "On the same tack, proper course".
Rule 11 (a.k.a. windward/leeward) states "When boats are on the same tack and overlapped, a windward boat shall keep clear of a leeward boat". In the given scenerio, the windward boat is required to keep clear.
Rule 17 states "If a boat clear astern becomes overlapped within two of her boatlengths to leeward... she shall not sail above her proper course...". This is a restriction on the action of the right-of-way boat. Assuming in this case, that the leeward boat established overlap from clear astern within two of HER boatlengths, she may not sail above HER proper course. If, however, leeward's (L) proper course is above windward's (W) proper course (i.e. L can point higher), then W is out of luck. She must keep clear, even if it means luffing, stalling, or tacking away.
Regards, Eric | | | Re: Mixed fleet - pointing ability - who gives way
[Re: Isotope235]
#171020 03/09/09 05:01 PM 03/09/09 05:01 PM |
Posts: 3,969 | Following up on my earlier message, for light to moderate air...
If you're on a slow (non-pointing) boat, probably the worst place to start is the middle of the line. You get rolled by the fast boats that started between you and the starboard end, and pinched out by boats that started between you and the pin.
If a pointy boat is below you, the smart ones won't actually try to head you up. They may foot a little, and will just outpoint you enough to come up under your bow, cross in front, and kill you with dirty air. If you're trapped and can't tack out because of boats above you, you will die a slow and miserable death...
Mike | | | Re: Mixed fleet - pointing ability - who gives way
[Re: brucat]
#171024 03/09/09 06:29 PM 03/09/09 06:29 PM |
Posts: 12,310 South Carolina | Like I said to that Hobie 16 that reach in on top of me and my a-cat during a mixed regatta late last year..."you don't want to be there". The response? "Oh yeah? last I checked I was in this start too". The gun went off and I sheeted in, jumped on the wire, and proceed on my proper course pointing to the moon as I chuckled at the quiet mumble of obscenities from the other boat.
Jake Kohl | | | Re: Mixed fleet - pointing ability - who gives way
#171032 03/09/09 06:53 PM 03/09/09 06:53 PM |
Posts: 2,718 St Petersburg FL | Like I said to that Hobie 16 that reach in on top of me and my a-cat during a mixed regatta late last year..."you don't want to be there". The response? "Oh yeah? last I checked I was in this start too". The gun went off and I sheeted in, jumped on the wire, and proceed on my proper course pointing to the moon as I chuckled at the quiet mumble of obscenities from the other boat. Yep exactly, I learned this the hard way, never ever dever again!
[Re: Isotope235]
#171039 03/09/09 08:51 PM 03/09/09 08:51 PM |
Posts: 334 Seattle,Wa | Eric, Thanks for tying that together for me.  Hobie Tiger 2003 | | |
2,549
guests, and 508
