| re,Main Halyard #172064 03/17/09 06:18 PM 03/17/09 06:18 PM |
Joined: Nov 2008 Posts: 136 Thorneside | QLD | AUS furr_ball OP
Posts: 136 Thorneside | QLD | AUS | Hey there,
Had some trouble with halyard and the locking swage getting stuck in top pulleys. Mine locks into cleat at top of mast on the front and catches on the way up and down.
What types of halyards do others use? Anyone use spectra? Do you lock it off at top or bottom of mast? Anyone use a ring and hook system like the nacra? Any photo's of system as tried to find but couldn't?
Any comments.
Cheers,
Drew........Furr_ball........Mosquito 1635
| | | Re: re,Main Halyard
[Re: furr_ball]
#172066 03/17/09 06:51 PM 03/17/09 06:51 PM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P
Posts: 142 3 weeks Newman WA 1 week Robe ... | hi drew, i use a hook and a stainless ring welded onto the main halyard shackle. the ring is much like a rescue boat tow ring as we used to have on ourr junior dinghys. i have seen a slightly different setup on darryn kopp's boat bullet. he uses( i beleive) a hook with a ring attached to the sail. and the halyard has no shackle, the halyard gets fed around the ring so it stands up and then the halyard gets tied to the headboard. his system seems to attach and release easier than mine. darryn if your reading how about a photo of your setup???? if you look on page two of this forum, simon clavin has a question called mast hook. that might leed you to some answers. sorry must go there are dumb butt concretors that need me to hold their hand again.
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
| | | Re: re,Main Halyard
[Re: Peter_Foulsum]
#172380 03/19/09 06:06 PM 03/19/09 06:06 PM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | The hook in the photo and ring/shackle to go with it are available directly from AHPC - 03 5443 6910.
The pulley is a standard Ronstan fitting - just held in place by the pin.
Tim Shepperd Mosquito 1775 Karma Cat
| | | Re: re,Main Halyard
[Re: Tim_Mozzie]
#172388 03/19/09 08:11 PM 03/19/09 08:11 PM |
Posts: 136 Thorneside | QLD | AUS | Thanks all for info.
I get how it hooks on but could someone explain how you release.
I believe it is by rotating mast, does this simply lift the ring off the hook?
| | | Re: re,Main Halyard
[Re: furr_ball]
#172395 03/19/09 09:18 PM 03/19/09 09:18 PM |
Joined: Apr 2007 Posts: 432 McCrae Y.C. Mornington Peninsu... Simon C
Posts: 432 McCrae Y.C. Mornington Peninsu... | That's correct.
If it's set up right it should just hook on when you've pulled the halyard all the way. note... need to keep pointed into the wind to keep ring and hook lined up.
For releasing... pull hard on the halyard to lift the ring off the hook and rotate the mast which allows the ring to "miss" the hook as you release the halyard.
Simon Taipan AUS341
| | | Re: re,Main Halyard
[Re: dkd]
#172423 03/20/09 06:37 AM 03/20/09 06:37 AM |
Joined: Nov 2007 Posts: 43 Gwandalan [ Lake Macquarie ] Karl69
Posts: 43 Gwandalan [ Lake Macquarie ] | G,day all I use the same set up as in Peters picture which works good once you get use to it, but tucking away the halyard is a pain. I like the sound of Davids set up. Dave would you be able to email me a picture. thanks.
Karl Herman Mosquito, 1704 Top Gun. NSW.
| | | Re: re,Main Halyard
[Re: Peter_Foulsum]
#176307 04/28/09 02:56 AM 04/28/09 02:56 AM | twicebitten
| twicebitten
Unregistered | Hi all, the system as pictured by Peter is the same as I had on Twice Bitten, which is now at Peters club also. great system easiest, latch and unlatch of any I have used. Although the rotate your mast systems are OK, once you work out if you need rope behind ring or in front to get it to hook on and usualy there is a best side to rotate it towards to unhook as well, but once you get used to them they are OK if designed correctly, which the AHPC one is. I guess I like the continuous halyard type as pictured by Peter as it is fool proof on and off regardless of wind flapping sail and you don't have to tuck halyard away. Mind you the A class sailors don't like the weight of the halyard up the mast never mind 2 lengths with this system, but I can live with it  . Don't think that Bob would though | | | Re: re,Main Halyard
[Re: ]
#177066 05/04/09 09:43 PM 05/04/09 09:43 PM |
Joined: Oct 2008 Posts: 93 Bribie Island, QLD MCGriffith
Posts: 93 Bribie Island, QLD | Whilst derigging the other day at Cleveland after the Peel Island Marathon, Ross Guinea of Nacra Australia approached me and commented on my Main Halyard system. My main Halyard is 4mm spectra which runs to a block at the top of the mast then back down the side of the mast, where it ties off at the bottom of the mast. Ross was telling me that by doing this, when the downhaul is put on, the mast goes into compression, as such wont bend the way it is suppose to, as such the sail wont flatten properly, so consequently my downhaul isnt doing anything. Being who he is im inclined to take his word for it, so im very much considering changing to a hook and ring at the top of the mast.
Any thoughts/comments/experiences?
Cheers. Michael.
| | | Re: re,Main Halyard
[Re: MCGriffith]
#177070 05/04/09 11:21 PM 05/04/09 11:21 PM |
Posts: 432 McCrae Y.C. Mornington Peninsu... | He's right.
As I think Tim mentioned a few posts up, you can get everything you need from AHPC. They will bend a Taipan hook to suit the Mozzie section and post it to you. You could get the pulley and ring/shackle from your local shop if you preferred but I'd just get it all from AHPC. I had to re-do the top of my mast recently and the stuff arrived 2 days earlier than they promised and took about 20 minutes to fit.
My sail hooks and unhooks every time.
Cheers,
Simon
Simon Taipan AUS341
| | | Re: re,Main Halyard
[Re: dkd]
#177590 05/08/09 04:51 PM 05/08/09 04:51 PM |
Posts: 93 Bribie Island, QLD | Thanks for the advice guys, i popped down to BCC and Roscoe reshaped one of the nacra hooks to fit the mossie mast profile for me, i fitted it my self and it seems to work a treat, just need try it all out on the water now.
Cheers. Michael.
301
guests, and 39
