Page 2 of 3 1 2 3
Re: flaking the spinnaker [Re: ] #172371
03/19/09 04:46 PM
03/19/09 04:46 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Paranoia.
Top Tboat teams are religious about sail care and they typically only use them for a couple of regatta before switching to fresh. If you choose to go down this path, then I expect you will also remove your main battens before rolling up your main each and every day you've sailed. This "prevent" battens taking a set...though I've not seen this at a significant level with sails rolled up for years with battens in. You should also be taking your jib off your roller furler each day and alternating the rolling direction to reduce pre-curves (Top T teams will roll from the top one day, then roll for mt he bottom the next, switching direction each time).
Me, I leave my spinny in the snuffer between outings, while trailering, storing boat etc.. Main (& Jib) battens stay in unless broken (save for Top main batten..can't roll with it in). Jib gets rolled in whatever direction is easiest for that moment.
I feel there's way too much still to be gained by better sailing skills than these anal-retentative practises.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: flaking the spinnaker [Re: Tornado] #172374
03/19/09 05:02 PM
03/19/09 05:02 PM
Bravo Mike!
Re: flaking the spinnaker [Re: Tornado] #172375
03/19/09 05:06 PM
03/19/09 05:06 PM
Near SLC, Utah
tomthouse Offline
tomthouse  Offline
Near SLC, Utah
Well, for my two cents:
In the past, I've religiously folded (flaked) my sails. Over time I've noticed the material wears, weakens and tear along the "fold lines".
More recently I ensure the sail is completely dry and I use a stuff sack for "between use" storage. Since this change, I've not experienced the wear, weakening and eventual tearing along the fold lines. That is probably because the fold lines are random, when using the stuff sack.
Wow, look outside, it's Spring and time to get the boat ready for the season....waaa hoooo...!
Re: flaking the spinnaker [Re: ] #172376
03/19/09 05:27 PM
03/19/09 05:27 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Andrew
Sent you a pm on the spins.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: flaking the spinnaker [Re: Tornado] #172428
03/20/09 08:15 AM
03/20/09 08:15 AM
andrewscott
andrewscott
Originally Posted by Tornado
Paranoia.....
How about my trailer tires? should i remove them and stuff them in a bag after every use? I hear the UV rays will degrade rubber
Re: flaking the spinnaker [Re: ] #172430
03/20/09 08:30 AM
03/20/09 08:30 AM
Paranoia.....
I have sunbrella covers for my trailer tires.
Re: flaking the spinnaker [Re: Jake] #172433
03/20/09 08:44 AM
03/20/09 08:44 AM
Memphis, TN
M
mikeborden Offline
mikeborden  Offline
M
Memphis, TN
Now that takes the cake!!!! cool
Viper USA 132
1984 Hobie 18
Re: flaking the spinnaker [Re: Jake] #172434
03/20/09 08:48 AM
03/20/09 08:48 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
That's the guy I want to buy a used boat from!
F18 USA 242
http://www.solarwind.solar
Re: flaking the spinnaker [Re: Jake] #172436
03/20/09 08:54 AM
03/20/09 08:54 AM
andrewscott
andrewscott
SO is the cape actually to keep the UV off your shirt/pants?
I am just kidding... i have just replaced a tire that had cracks though it.... and need to replace the other one. I may spray 303 on them to help protect them but i doubt i will go so far as to get covers for them.
But just yesterday i was thinking about making a cover for my spin/snuff and maybe even the mast (up to the spin bail).
Re: flaking the spinnaker [Re: ] #172437
03/20/09 09:06 AM
03/20/09 09:06 AM
Memphis, TN
M
mikeborden Offline
mikeborden  Offline
M
Memphis, TN
What Dave said.
I know a guy that puts wood(1X6) with a chock at the end of it and puts his trailer on those instead of parking it on the ground. I think the ground is probably worse for a tire than the sun. Heck, the boat covers the tires so there shouldn't be a whole lot of UV exposure.
Super anal people are the ones you want to buy a used boat from that's for sure.
No pun intended for Jake here.
cool
Viper USA 132
1984 Hobie 18
Re: flaking the spinnaker [Re: mikeborden] #172442
03/20/09 09:28 AM
03/20/09 09:28 AM
andrewscott
andrewscott
Jake, i think Mike just called you Super Anal... is that your "alter ego's name"? and i thought it was "squeegee man"....
Re: flaking the spinnaker [Re: ] #172445
03/20/09 09:45 AM
03/20/09 09:45 AM
pgp Offline OP
pgp  Offline OP
Just remember, I asked "how, not if" .
Pete Pollard
Blade 702
Re: flaking the spinnaker [Re: pgp] #172448
03/20/09 09:50 AM
03/20/09 09:50 AM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Originally Posted by pgp
Anyone know an easy way?
Yep, don't bother.
Will flaking prevent the panels in a spinnaker stretching - which is what typically ends up degrading their performance?
- I don't think so.
If you like the "Japanese Tea Ceromony" ritual of neatly folding the kite with the help of someone else then power to you.
If you think life is short then leave it in the snuffer bag.
Chris.
Re: flaking the spinnaker [Re: flumpmaster] #172452
03/20/09 10:35 AM
03/20/09 10:35 AM
pgp Offline OP
pgp  Offline OP
Thanks everyone. I'll fiddle with it a little more. If it continues to be a pita. . .
LIFE IS SHORT!
Pete Pollard
Blade 702
Re: flaking the spinnaker [Re: Jake] #172455
03/20/09 10:58 AM
03/20/09 10:58 AM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Here's the cover for my SNU on the HT.
Dave
Re: flaking the spinnaker [Re: davefarmer] #172456
03/20/09 11:02 AM
03/20/09 11:02 AM
andrewscott
andrewscott
Dave
NICE~ are those button snaps along the side of it to secure it?
Re: flaking the spinnaker [Re: ] #172460
03/20/09 11:28 AM
03/20/09 11:28 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
Dennis has covers available for the Snu now too.
http://www.gobarefootstudio.com/snu_cover.html
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: flaking the spinnaker [Re: ] #172493
03/20/09 09:59 PM
03/20/09 09:59 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Yes to the button snaps, but I like the look of the fasteners on Dennis' version. The snaps have become a bit more difficult with time. Nice fabric, and good protection. I think I paid closer to $120. The guy made tramp cover as well that I'm pleased with.
Dave
Re: flaking the spinnaker [Re: davefarmer] #172521
03/21/09 09:42 PM
03/21/09 09:42 PM
USA1273 Offline
USA1273  Offline
Just to add more fuel to the fire.....
Having made sails for 14 years for some of the premire lofts, the consensus on folding kites is that you always fold them in half from head to mid-foot, then fold them toward the foot, and then roll from the middle of the sail toward the leech and luff to avoid crushing the last foot of cloth leading into the tapes. This is the way we did it on the AC boats, TP52s and what we do on our own F18.
Probably 6 to 1/2 dozen in the end since the snuffers kill the cloth of the kites in about 2 regattas.
F18 USA 1273
Andrews 77 (SOLD) Melges 32 (SOLD) Formula18 Olympic 49er (FOR SALE)
Always outnumbered - Never outgunned....
Re: flaking the spinnaker [Re: USA1273] #172526
03/22/09 04:03 AM
03/22/09 04:03 AM
Good info, thanks.
Page 2 of 3 1 2 3
0 registered members (), 21,948 guests, and 1,940 spiders.
Most Online23,915
6 seconds ago
