Uni rigging ideas? #174632
04/13/09 09:30 AM
04/13/09 09:30 AM
Timbo Offline OP
Timbo  Offline OP
Anyone figure out a good way to run your downhaul and mast rotator lines so you can reach them while out on the wire when sailing Uni?
When the wind is puffy I like to be able to make adjustments while staying out on the wire upwind, but to reach these control lines on the hull, I have to come in, or at least sit up half way and bend my knees in, which is exactly what you -don't- want to do when a puff comes on.
I have tried extending the lines with shock cord to my trap line, but I usually end up tangled up when I come in to tack.
Re: Uni rigging ideas? [Re: Timbo] #174656
04/13/09 10:33 AM
04/13/09 10:33 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
When uni, do you have both trapeze (skipper/crew) rigged? Perphas trying to tie off to the crew trap so you can reach over for that. Probably would be out of your way on tacks.
USA 777
Re: Uni rigging ideas? [Re: tback] #174669
04/13/09 11:27 AM
04/13/09 11:27 AM
Timbo,
I run them to the shroud, round a block or shackle and then back under the tramp - easier on the Stealth as we have open laced sides.
Simple job of reaching into the shroud and grabbing the appropiate one!
Re: Uni rigging ideas? [Re: scooby_simon] #174676
04/13/09 12:20 PM
04/13/09 12:20 PM
Chattanooga, TN
jody Offline
jody  Offline
Chattanooga, TN
i have my downhaul going to a block attached to the stay, where a line with a sister clip goes to and runs back to the front beam and is tightened in there with a bungee. Have to lean in for a second to grab and pull but keeps it from getting caught all over when trying to move to the other side or out on the trap.
Jody Blade F16 724 Plays with Sharp Objects
0 registered members (), 21,605 guests, and 1,443 spiders.
Most Online23,137
1 hour ago
