| Spin pole while trailering #175425 04/20/09 03:11 PM 04/20/09 03:11 PM |
Joined: Dec 2008 Posts: 329 Chicago, Illinois USA TEH OP
Posts: 329 Chicago, Illinois USA | New Blade owner question:
My spin pole fits in my van, but I'm not sure I want it in there with my kids. How do you transport it?
Blade F16 USA 725
| | | Re: Spin pole while trailering
[Re: TEH]
#175428 04/20/09 03:21 PM 04/20/09 03:21 PM |
Posts: 6,049 Sebring, Florida. | Or you can tie it to the top of your van if you have bars up there, or on top of your gear box if you have one on the trailer. Just be sure to tie it to something or you will be buying a new one! Some guys have cut a hole in one end of their gear box and then fixed a PVC pipe with cap to the hole, long enough to fit the spin pole into.
Blade F16 #777
[Re: pepin]
#175430 04/20/09 03:27 PM 04/20/09 03:27 PM |
Posts: 5,525 | Slide it, diagonally, under the hiking straps. Use the martingales to secure it.
Pete Pollard Blade 702
[Re: pgp]
#175437 04/20/09 03:52 PM 04/20/09 03:52 PM |
Posts: 329 Chicago, Illinois USA | Thanks
For those of you lashing it to the boat in some way, you remove the bag, right?
Blade F16 USA 725
[Re: TEH]
#175438 04/20/09 04:03 PM 04/20/09 04:03 PM |
Posts: 404 Chattanooga, TN | We cut a hole in the end of the sail box to extend it. Used PVC pipe to close it up and carry it bag on, spin in bag, and rigged in the box.
Joanna
Blade F16 "Too Sharp to Touch" | | | Re: Spin pole while trailering
[Re: Karl_Brogger]
#176192 04/27/09 02:57 AM 04/27/09 02:57 AM |
Posts: 61 | I leave it attached with all the bridles and rigging in place. Just tie it up tight to the mast cradle (as if it was rigged) so the bridles are tight and it is ready for the mast erection. Dont undo the tack or the sheets. Leave the spinnaker in the tube and just block the end with some old cloth to keep the dirt out. Easy.
Stealth F16 The Black Pig
[Re: davidtugwell]
#176212 04/27/09 09:03 AM 04/27/09 09:03 AM |
Posts: 6,049 Sebring, Florida. | I've not tried that but is sounds like it might work. Anything that saves me rigging time, I'm all for it!
Blade F16 #777
2,049
guests, and 501
