Pictures of the Marstrom 2009 model #175905
04/23/09 04:26 PM
04/23/09 04:26 PM
North Europe, Sweden, Uppsala
Hakan Frojdh Offline OP
Took some pictures of the Marstrom 2009 model
Check this link for better quality pictures, the forum software seems to resize them without much sucess....
Web page with pictures thumbnail pictures and links to high res
Hull before painting
Forestay fitting
Complete boat
[img]http://www.webbo.dyndns.org/a-cat/marstrom_2009/a4.jpg[/img]
[img]http://www.webbo.dyndns.org/a-cat/marstrom_2009/a5.jpg[/img]
[img]http://www.webbo.dyndns.org/a-cat/marstrom_2009/a6.jpg[/img]
[img]http://www.webbo.dyndns.org/a-cat/marstrom_2009/a7.jpg[/img]
[img]http://www.webbo.dyndns.org/a-cat/marstrom_2009/a8.jpg[/img]
/hakan
Re: Pictures of the Marstrom 2009 model [Re: Hakan Frojdh] #175917
04/23/09 05:48 PM
04/23/09 05:48 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Very Nice Thanks
Obviously Marstrom is not convinced that the Flyer philosophy is the way to go.
Does he think the curved boards will work better on his classic hull shape versus the Flyer inspired boats.
crac.sailregattas.com
Re: Pictures of the Marstrom 2009 model [Re: Mark Schneider] #175928
04/23/09 08:05 PM
04/23/09 08:05 PM
I'm a real geek for all the line control line rigging he did on this boat, can you (or anyone who knows) tell me what is the skinny red line coming up next to the mainsheet on the tramp? Is that the traveler? And the one that looks like a red loop pull-handle on the blue line on the tramp?
http://www.webbo.dyndns.org/a-cat/forum/html/img_3811.htm
Re: Pictures of the Marstrom 2009 model [Re: Timbo] #175944
04/24/09 01:06 AM
04/24/09 01:06 AM
The skinny red line just aft of the main sheet is the traveler control. The red loop pull-handle is for the release of mast over rotation, it releases both cleats so you just pull it before or during the gybe.
The hull shape together with the curved centerboards performed well during the last A-cat worlds, Landenberg finished third.
/hakan
Re: Pictures of the Marstrom 2009 model [Re: Hakan Frojdh] #175949
04/24/09 04:51 AM
04/24/09 04:51 AM
I think there is one of these at my club, but it has a very different (more conventional) mast layout with a stainless mast rotator (will check next time i'm there).
Re: Pictures of the Marstrom 2009 model [Re: Tony_F18] #175953
04/24/09 06:05 AM
04/24/09 06:05 AM
Hakan, do you have any more photos of the trampoline fitting on the hull? I liked the look of it, and structurally it makes a lot of sense instead of the mushroom bolts etc.
More pics of the rudder system, beams, shroud fittings.. Lets make it simple and just say, do you have any more pictures? laugh
Re: Pictures of the Marstrom 2009 model [Re: Rolf_Nilsen] #176018
04/24/09 01:50 PM
04/24/09 01:50 PM
Hi,
I added more pictures at the link below and increased the resolution a bit.
Webpage with klickable thumbnails
/hakan
Re: Pictures of the Marstrom 2009 model [Re: Hakan Frojdh] #176029
04/24/09 04:09 PM
04/24/09 04:09 PM
Great stuff, thanks a lot! Very inspirational.
I also enjoyed the movie with swedish commentary. I hope I did not kill your bandwith by downloading it. Will share it with the other F16 nutheads here on the west coast.
Re: Pictures of the Marstrom 2009 model [Re: Rolf_Nilsen] #176205
04/27/09 08:11 AM
04/27/09 08:11 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Its unusual(to me) that a designer within a class with so much developement would keep the boats so similar year after year. I have a 1998 boat, and it looks REAL similar. Now some of the controls are simplified, but the hulls, rudders, mainsheet system, mast systems are all the same. I do love the shroud attachments, simple and effective. My boat has raised tabs, sure to broken off at some point.
BTW, whats up with the paint? Did Goran buy a 1 million gallon can and is trying to use it all up, or is there some other reason for the yellow paint?
Re: Pictures of the Marstrom 2009 model [Re: dave mosley] #176210
04/27/09 08:54 AM
04/27/09 08:54 AM
I think the bright yellow paint is a great marketing tool. Everyone knows at a distance who built that boat! And the M20, etc.
Re: Pictures of the Marstrom 2009 model [Re: Timbo] #176215
04/27/09 09:21 AM
04/27/09 09:21 AM
dave mosley Offline
dave mosley  Offline
My wife wont let me paint my boards or rudders because she says she can spot me. Really, if she looked at the back of the pack, it wouldnt be that hard anyway...
Re: Pictures of the Marstrom 2009 model [Re: Timbo] #176236
04/27/09 12:18 PM
04/27/09 12:18 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
Some are in Blue, so he probably has a quantity of both.
Tom Siders
A-Cat USA-79
Tornado US775
Re: Pictures of the Marstrom 2009 model [Re: windswept] #176241
04/27/09 01:18 PM
04/27/09 01:18 PM
After one gazillion boats in white, yellow and blue is probably a nice change for the painter smile
Mix yellow and blue, and you get green. Perhaps the next color if they tire of blue and yellow.
Re: Pictures of the Marstrom 2009 model [Re: dave mosley] #176263
04/27/09 03:42 PM
04/27/09 03:42 PM
Hi Dave,
if you compare this boat with a 1998 model most things have changed. Not obvious when you look at the pictures but here's a list.
Hulls: New shape with less rocker, flatter at the main beam and changes to the bow. Hulls are canted a bit. No internal bulkheads, can be seen in the pictures. Shroud fittings integrated in the hull as you noticed. This means that the whole hull is made in one piece with shroud fittings in place when it gets out of the owen.
Centerboards: Curved and higher aspect ratio
Rudders: Rudders are the same! But the fittings have changed a bit and it has "kick up" now.
Rear beam: New integrated traveller track in carbon.
Main beam: Strikerless design, still rock solid.
Mast: High modulous carbon fibre to stiffen it up sideways.
Boom: Same as before
cheers
Hakan
Re: Pictures of the Marstrom 2009 model [Re: Timbo] #176281
04/27/09 07:46 PM
04/27/09 07:46 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I hate to be the one who asks, but here goes. How much $$?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Pictures of the Marstrom 2009 model [Re: arbo06] #176284
04/27/09 07:57 PM
04/27/09 07:57 PM
ncik Offline
ncik  Offline
Who knows the colour of an Empacher rowing shell?
Colour is good for marketing, but I didn't know Marstrom only did yellow and blue. Maybe needs to reinforce that a bit more...somehow.
Re: Pictures of the Marstrom 2009 model [Re: ncik] #176286
04/27/09 08:26 PM
04/27/09 08:26 PM
dave mosley Offline
dave mosley  Offline
Hakan, thanks for the info on the changes, I did notice most of those, and had heard of the hull shape changes, but hard to tell from the pix. My point may have been....he had it pretty right 11 yrs ago!
I love my Marstrom, it will be hard for me to go to another boat. Someone did repaint it white though...
Re: Pictures of the Marstrom 2009 model [Re: arbo06] #176288
04/27/09 09:08 PM
04/27/09 09:08 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
You know what they say,
"If you have to ask..."
grin
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Pictures of the Marstrom 2009 model [Re: ejpoulsen] #176359
04/28/09 02:50 PM
04/28/09 02:50 PM
Here's a pic from the one at my club (also with banana boards).
This one has a much cleaner boom setup:
http://picasaweb.google.nl/lh/photo/5-svi7VW1wfMq0jWWsmiRA?feat=directlink
Re: Pictures of the Marstrom 2009 model [Re: Tony_F18] #176366
04/28/09 04:20 PM
04/28/09 04:20 PM
dave mosley Offline
dave mosley  Offline
It looks like no center tramp sheeting, can you tell me how he is sheeting that puppy? Looks like a new boat...tapered beams and such.
0 registered members (), 854 guests, and 127 spiders.
