TYBEE, and SCHRS #177880
05/11/09 11:18 PM
05/11/09 11:18 PM
Annapolis, MD
Mark Schneider Offline OP
Annapolis, MD
Wow.. the earth moved under the feet of US Sailors today.
Not only did the Tybee get scored on handicap and in one design class... (My personal favorite old saw)
BUT... they are using SCHRS measurement ratings and not portsmouth
Woo woo!!
Whoever made these calls... Thank you!
crac.sailregattas.com
Re: TYBEE, and SCHRS [Re: Mark Schneider] #177884
05/12/09 01:32 AM
05/12/09 01:32 AM
Scarecrow
Scarecrow
What is interesting is the very obvious split in the corrected time results. Typically this occurs if either the ratings are up the creek or the weather gave one class a huge advantage.
So the question is, if this was F18 prefered conditions (in comparison to N20) when will the N20 be clearly advantaged?
Re: TYBEE, and SCHRS [Re: ] #177887
05/12/09 02:29 AM
05/12/09 02:29 AM
A third option, is that those sailing the F18's are better sailors and made better decisions regarding route......
Looking at the video from yesterday(light winds), the N20's SHOULD have romped it as they could get on the wire as they have more power?
Re: TYBEE, and SCHRS [Re: ] #177894
05/12/09 05:12 AM
05/12/09 05:12 AM
pgp Offline
pgp  Offline
There has been some mention of heavy weather, on the nose, later in the week.
Pete Pollard
Blade 702
Re: TYBEE, and SCHRS [Re: scooby_simon] #177895
05/12/09 05:15 AM
05/12/09 05:15 AM
Scarecrow
Scarecrow
But then their kites may not be able to be carried to the same height. Meaning you end up with nacras 2 sail reaching Vs F18s 3 sail double trapping. This was definately happening for some of the race. Its hard to believe (although possible) that all bar 1 F18 crew is better than all the Nacra 20 crews. I actually think what we are seeing is evidence the N20 needs a new sail plan it if wants to stay dominant in this style of racing. Passage races are rarely straight upwind or down so the sails need to be able to cope with other options.
Re: TYBEE, and SCHRS [Re: pgp] #177897
05/12/09 05:16 AM
05/12/09 05:16 AM
Scarecrow
Scarecrow
But then the F18's have smaller rigs and similar righting moment. What would you choose.
Re: TYBEE, and SCHRS [Re: ] #177898
05/12/09 05:37 AM
05/12/09 05:37 AM
pgp Offline
pgp  Offline
F16! laugh
Time will tell but the I've always heard the 20 is a better open water boat. Longer, fuller bows and all that.
With all respect to the guys sailing the 20s (I wouldn't even attempt this race), the 18s have more talent on the water.
The only thing I'm certain of: catamaran sailing is marketable.
Pete Pollard
Blade 702
Re: TYBEE, and SCHRS [Re: ] #177900
05/12/09 06:01 AM
05/12/09 06:01 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
There is a lot of racing left, let's give it a couple of days. And yes there is a lot of talent in the F18 fleet.
F18 USA 242
http://www.solarwind.solar
Re: TYBEE, and SCHRS [Re: pgp] #177901
05/12/09 06:13 AM
05/12/09 06:13 AM
mikekrantz Offline
mikekrantz  Offline
It was a very tight reach starting with about 5 knots of breeze building to 15+ over the course of the day. The F18's were able to set their spins early in the light air and hold their line, whereas it was too tight for the N20's. Then once the breeze came on, the F18's were again able to hold their lines while the N20's set their spins, drove down to the beach, drop, reach back up and reset.
The N20 that won line honors (Royal Yellow) set themselves up high early on, and it paid off.
We took the low road and passed 15 boats in the last 40 miles.
The Infusion was a machine in those conditions. We were both chickenlined in at the back beam reaching at 20knots. We would blast through a 4' wave up to the beam, drop down to 15 knots, shake it off, and take off again.
Re: TYBEE, and SCHRS [Re: ] #177902
05/12/09 06:24 AM
05/12/09 06:24 AM
So are you saying the N20 kites are cut too full and so cannot be carried high enough?
Yes the F18's have less sail and similar RM so will be able to carry their kites higher is the wind gets to the critical band; however, I was very surprised in the footage I saw that the F18's were twin wiring with the kite up and the 20's were just sitting in with the kite in the sock, why did the 20's not pop the kite, drop the halyard 18 inches (flattens most kites except really bad ones) and continue the fight, maybe with dumping some traveller?
Re: TYBEE, and SCHRS [Re: mikekrantz] #177903
05/12/09 06:30 AM
05/12/09 06:30 AM
pgp Offline
pgp  Offline
Originally Posted by mikekrantz
. . . We were both chickenlined in at the back beam reaching at 20knots. We would blast through a 4' wave up to the beam, drop down to 15 knots, shake it off, and take off again.
smile Kudos!
Pete Pollard
Blade 702
Re: TYBEE, and SCHRS [Re: scooby_simon] #177905
05/12/09 06:44 AM
05/12/09 06:44 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
What are you doin to me man? You're given away the code. I haven't tried 18" in a while, but certainly some easing of luff tension is good while trying to go high.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: TYBEE, and SCHRS [Re: Chris9] #177921
05/12/09 08:38 AM
05/12/09 08:38 AM
andrewscott
andrewscott
wow... when i try to point higher (with the spin out) i always make sure the halyard is all the way up, and sheet in as hard as possible... please explain how dropping the halyard helps you point higher.
thanks -
Re: TYBEE, and SCHRS [Re: ] #177923
05/12/09 08:45 AM
05/12/09 08:45 AM
Clermont, FL, USA
Clermont, FL, USA
It flattens the entry to sail. It does allow you to carry it higher but it also moves the forward vector further aft (am I saying that right?) giving more healing moment with less forward speed. The trick is knowing when to pull the plug, just because you can carry it doesn't always mean you're going faster. As with anything sailing it just depends.
It's really easy to see. Go out on on a light air day sail as high you can with a full hoist then drop halyard the change really jumps right out at you.
F18 USA 242
Re: TYBEE, and SCHRS [Re: David Ingram] #177925
05/12/09 08:58 AM
05/12/09 08:58 AM
andrewscott
andrewscott
Thanks David. I will try it next sail...
Will you be around to help me right my cat? (kidding)
Re: TYBEE, and SCHRS [Re: scooby_simon] #177926
05/12/09 09:06 AM
05/12/09 09:06 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I'll tell you why. In those conditions you pop the kite on the N20 and you hold it for a minute. The littlest puff comes through and suddenly you have to turn 50 degrees downwind to keep from flipping dragging you into shore where you are just going to have to drop it immediately to come back up. So instead you reach high and fast gaining height without any loss in speed. Then when you are high enough you pop the chute and try to hold it high as long as you can. Rinse and repeat. That's what Steve did and he won the leg.
This was definitely F18 condition with the high reaching. Heavy air upwind the F18's will kill also. The N20 comes alive in the 8-12knots dead down wind condition. If and when they get that you will see the opposite result of what they had yesterday with all the N20's killing the F18's.
Mike Hill
N20 #1005
Re: TYBEE, and SCHRS [Re: Mike Hill] #177927
05/12/09 09:08 AM
05/12/09 09:08 AM
Clermont, FL, USA
Clermont, FL, USA
Exactly! There is so much racing left.
F18 USA 242
Re: TYBEE, and SCHRS [Re: ] #177928
05/12/09 09:12 AM
05/12/09 09:12 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
For further guide, I look at the spin luff looking for, lets say a knuckle or bend in the luff not due to wind. When my halyard is all the way up the luff is tight, you can grab the luff and try to turn it and get nothing. I usually have my spin haylard eased 4"-6" in light to moderate conditions. Moderate and above tight. I would prefer to be able to ease the tack line, but I have an end pole snuffer. I had a sailmaker out with me one time who was trying to figure out the 6.0 since he was making us new sails. at ont point we had the old Worrell style spin up and needed to get above an obstacle. He eased the tack line off so the tack was near the leeward bow and I could drive much higher. Not sure about going faster as Dave points out...
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: TYBEE, and SCHRS [Re: Chris9] #177933
05/12/09 09:53 AM
05/12/09 09:53 AM
andrewscott
andrewscott
Interesting info. Thanks for the data
i will have to try this out. I have let off on the tack line in light air before, but not to point higher...
Re: TYBEE, and SCHRS [Re: scooby_simon] #177950
05/12/09 12:47 PM
05/12/09 12:47 PM
rexdenton Offline
rexdenton  Offline
We had almost the same thing happen on the last day of the Sakonnet 100 last year. All of the F18's and I-20's finished within about 7 minutes of each other. In a fresh breeze, the boats are pretty equal, because of the reaching speed with the F18 chute up and dbl traps.
Nacra F18 #856
0 registered members (), 2,368 guests, and 417 spiders.
Yesterday at 10:10 AM
