| Re: Let's throw the N-20 under the bus thread!
[Re: ]
#179056 05/20/09 02:23 PM 05/20/09 02:23 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | How much difference do you think that it would make to the Inter18 if you put an Infusion rig on it?
It would go a bit better but still get slaughtered in an F18 fleet.
As much as i love it, I am afraid that the N20 is the same generation as the inter18. I know that no one is really serious about bringing back the Inter18 to Formula 18 racing but I think we would be surprised. With an updated mast and sailplan I think it would fair pretty well. The reason for not trying this is cost. By the time you get to a competitive class legal Inter18 boat you could have bought something proven. We sometimes allow a carbon masted I18 sail with us and they are not bad. Later, Dan
[Re: ThunderMuffin]
#179151 05/21/09 08:33 AM 05/21/09 08:33 AM |
Posts: 40 | Herbie,
So far EP has been more than accomodating in their offer to resolve our faulty spins.
As for the sail development... I don't think open "revolt" is going to accomplish much to be honest. Working within the infrastructure already established will bring about change much faster IMO.
Its not like there haven't been changes to the N20 platform before. Snuffer/spin pole, rudder shapes, alum rig (which hasn't yet shown up yet tho) so the precedent is already there for the manufacturer to change things and remain class legal. To be honest, I really like it this way as opposed to something like the laser, where the owners have to have a vote on whether they can put a stupid bungie on their outhaul.
I'm not sure I follow, but maybe revolt is too strong of a word. Many very successful one design classes have the sail making open within a measurement rule (Melges, J22, Etchells, in fact most OD keel boats.. not that I'm a fan of racing keel boats). The key benefits of this are competition amongst the makers to keep costs down / quality up and local service (a big one I think unless you live near where EP is). | | | Re: Let's throw the N-20 under the bus thread!
[Re: ThunderMuffin]
#179156 05/21/09 08:48 AM 05/21/09 08:48 AM |
Posts: 5,590 Naples, FL | What I noted between the two mainsails I had was 1) the head on the newer sail wasn't as wide as the older sail 2) the leech down near batten 5 & 6 was about 2" different
Also, the battens for one sail didn't fit the same way in the newer sail. I attributed this primarily to stretching. I had to cut the top battens about an inch on the new sail to keep it from sticking out so far...
I figure #279 sail was probably a bit different as well, as that was the earlier generation sail. I think the same was true with the three spinnakers I had (the shoulders looked different, even before they were heavily used - probably just my uneducated eye)
It's good to know that they're computer cut and good quality control.
And whatever the sail cut was or was not, the sail's effect on my performance was negligable compared to my sailing ability...
[Re: Steve B]
#179164 05/21/09 09:11 AM 05/21/09 09:11 AM |
Joined: Sep 2002 Posts: 3,224 Roanoke Island ,N.C. Team_Cat_Fever OP
Posts: 3,224 Roanoke Island ,N.C. | A set of rules that states that simply that the sails must be made by a specific sailmaker leaves a lot to be desired. Perhaps, the fact that there might not be a specific set of dimensions is driven by the lack of consistantcy in the sailmakers sail sizes and cuts? Just wondering.
Unfortunately ,I think this may be the case. Another advantage of an open sail plan is the cost will drop the second it is implemented, I've heard by as much as 25%. Competition can be a wonderful thing. EP has been excellent in dealing with the spin issues ,so far, so customer service is there. I just believe that the sail plan could be so much faster. If performance/nacra and EP are willing to tighten up the quality and advance the design then there would be no need to open up the sails. I'm sure they have the ability, it's just a matter of making it happen.
[Re: Steve B]
#179169 05/21/09 09:45 AM 05/21/09 09:45 AM |
Posts: 291 | The contention that changing from one sail maker to open sail makers will necessitate the need to measure the sails is interesting.
In light of the fact that EP N-20 spinakers have different lenghts (as much as 18") and that EP mains have as much as 6" delta in luff lengths, etc., shouldn't all sails be measured to assure everyone is on the same footing?
Is there a site or rule book that outlines the dimensions of the sails for the N-20 class? I know that most other one-design classes have a specific set of luff, leech, mid-girth, foot, sail area and other criteria. Without such a rule, how do we know if the sails are to spec?
IMHO, all sails should be measured by an independent sail measurer to assure that everyone has the same size sails. Those are interesting comments. Hobie had the same issue with the 18. In regards to sails the rule book only stated that a Hobie sail was a legal sail and all others were not. When I decided to seperate from the class rules I went searching for measurements to have a new sail made. Guess what, nobody could produce them. In fact when I called the factory the response I got was "if it is a Hobie sail then it is a legal sail". Now I am starting to wonder why this is such a closely gaurded seceret. I began measuring sails from other Hobie 18's on the beach. Out of the 10 sails I measured the luff was only the same length TWICE! The variance on my 10 test sails was five inches. For one design that is unacceptable. Makes it seem more like you are racing "Almost One Design".
[Re: JACKFLASH]
#179170 05/21/09 09:47 AM 05/21/09 09:47 AM |
Posts: 5,525 | ROFLMAO! SM(almost)OD!
Pete Pollard Blade 702
[Re: Team_Cat_Fever]
#179194 05/21/09 10:53 AM 05/21/09 10:53 AM |
Posts: 548 MERRITTISLAND, FL | Unfortunately ,I think this may be the case. Another advantage of an open sail plan is the cost will drop the second it is implemented, I've heard by as much as 25%. Competition can be a wonderful thing.
You guys are dreaming and I have heard quit a few contrary aruments wihtin this thread. Price is not likely to go down unless you happen to shop at some local bargain sail maker. To get a "Name brand" sail you are likely to pay even more than for the EP. Not much volume and you now spread it out even thinner so getting a Landy or Glaser to design and then back up a sail plan will not be cheap. The big complaint here seems to center on different sails not all being the same. Open it up to different builders and you expect those to all be the same? You are now definitely not sailing 1-design. Not that it matters, but what exactly are people trying to accomplish with this. Now everyone has to pay 20-40 bucks to play officialy with no more unifority to the class concept than you have now. | | | Re: Let's throw the N-20 under the bus thread!
[Re: ThunderMuffin]
#179201 05/21/09 11:16 AM 05/21/09 11:16 AM |
Posts: 1,200 Vancouver, BC | But then you have to deal with getting the sails measured in by a certified measurer. There are definitely pros and cons to each approach.
Not as big an issue as you think. Tornado has open sail makers. Quality/consistency is second to none. As for measurements, this is only needed at class sanctoned events (nationals, worlds etc) and takes about 30 min. per boat. There are ways to stream line the process...something like a class rule that to make a legal sail a manufacturer must certify it measures in/affix a label/stamp before selling the sails. If fraud is a concern, then enforce on site measurement in official/important events. The reason the I20's have not evolved with current trends in sail plans is precisely b/c they are SMOD. The builder needs to keep his profit margins and without competition there is little incentive carry out sail development.
[Re: Matt M]
#179209 05/21/09 11:51 AM 05/21/09 11:51 AM |
Posts: 3,116 Annapolis, MD | Matt... You should disclose that you build boats and purchase sails in bulk from sailmakers. Your perspective will be different then a sailor. Price is not likely to go down unless you happen to shop at some local bargain sail maker. To get a "Name brand" sail you are likely to pay even more than for the EP. Not much volume and you now spread it out even thinner so getting a Landy or Glaser to design and then back up a sail plan will not be cheap.
I agree with your price point idea. A better way to have descibed the trade off is would be to address the VALUE provided for your dollar. The major international catamaran classes are Hobie 16, F18, A Class and Tornado. All but the Hobie 16 owners have decided that the best value for their $$$ comes from having a sail rule and having the CHOICE of sailmakers. Herbie reports that the majority of monohull OD classes ALSO choose the Value inherent in having multiple sailmakers. Open it up to different builders and you expect those to all be the same? You are now definitely not sailing 1-design. This is a false choice... unless the sailors are one design as well.... eg same size and weight... you decidedly do not want one design sails. The majority of racing sailors, monohull or multihull interpret one design to mean a measurement rule which restricts the dimensions of the power plant. Historically catamaran builders convinced the consumer that their monopoly called ONE DESIGN SAILS was good for them. The competitive sailing world has mostly rejected this argument. Now everyone has to pay 20-40 bucks to play officialy with no more unifority to the class concept than you have now. A red herring argument. The 20 to 40 bucks is going to an independent (from the sailmaker) class member who takes time certify TO THE CLASS OF SAILORS... that the sail rule is followed and the playing field is level. The 20 to 40 bucks ENSURES that the rule is followed to the class!... AND it validates the sail to the consumer who KNOWS he is not only legal for the class... but also he has the largest legal sail he is allowed... Not just one that is 4 inches too short... BUT measures in to the SMOD spec! If your independent sail does not measure in... or is not close to your specs.... the sailmaker fixes the problem!
crac.sailregattas.com
[Re: Mark Schneider]
#179220 05/21/09 12:49 PM 05/21/09 12:49 PM |
Posts: 5,590 Naples, FL | I guess the bigger picture would be to ask what, specifically, needs to be changed with the current sail plan?
Are the sails to full/flat? Materials too flimsy/heavy? Sail life too long/short? Sail shape unable to be changed by controls? Is wind/angle performance band too narrow? Sailplan not adaptable to various sized crews?
[Re: ThunderMuffin]
#179363 05/22/09 08:50 AM 05/22/09 08:50 AM |
Posts: 5,590 Naples, FL | Exactly what I was going to say.... Can't mistake that hair
[Re: Will_R]
#179368 05/22/09 09:05 AM 05/22/09 09:05 AM |
Posts: 5,590 Naples, FL | okay. I gleaned from the conversations that the "sail plan" needed to be changed, not just the supplier.
2,527
guests, and 227
