Page 4 of 4 1 2 3 4
Re: The Hobie i-cat pricing is known ! [Re: Smiths_Cat] #181238
06/07/09 09:03 AM
06/07/09 09:03 AM
how long is the Hobie ICat ?
Re: The Hobie i-cat pricing is known ! [Re: scooby_simon] #181246
06/07/09 11:51 AM
06/07/09 11:51 AM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Simon,
Check the link to the pdf file Wouter has posted. Longueur = length....
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: The Hobie i-cat pricing is known ! [Re: Gilo] #181252
06/07/09 12:59 PM
06/07/09 12:59 PM
Originally Posted by Gilo
Simon,
Thanks, cannot find all up weight....
Re: The Hobie i-cat pricing is known ! [Re: scooby_simon] #181306
06/08/09 06:08 AM
06/08/09 06:08 AM
Wouter Offline OP
Wouter  Offline OP
Simon,
Nobody knows the weight yet, but the most persistent rumour has it at 220 lbs (or 100 kg).
I, for one, don't expect it to come out lower then that anyway.
Re: The Hobie i-cat pricing is known ! [Re: Wouter] #181348
06/08/09 09:35 AM
06/08/09 09:35 AM
Various SCHRS Ratings
F16 single handed 0.982 (A Calsses are about the same)
Icat in various weight guises, I've assumed the plates are high aspect as per a fully optimiesed F16, same luff length on the maisail at 8.1 and the same size kite at 17.5sqm (rating without kite in ())
100kg - 0.947 (0.995)
104 - 0.953 (1.001)
110 - 0.962 (1.010)
120 - 0.976 (1.025)
130 - 0.990 (1.040)
140 - 1.003 (1.054)
150 - 1.017 (1.068)
151 - 1.018 (1/069)
160 - 1.030 (1.081)
Re: The Hobie i-cat pricing is known ! [Re: scooby_simon] #181364
06/08/09 11:35 AM
06/08/09 11:35 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
As Wouter says nobody knows the weight yet. A-cats are down to 75kg, so I wounder why a one foot shorter, 0.5m lower boat should be heavier. 100kg would be a shame, since you could do this in GRP and alu as well.
What would be the rating at 80kg?
Cheers,
Klaus
Re: The Hobie i-cat pricing is known ! [Re: Smiths_Cat] #181366
06/08/09 12:15 PM
06/08/09 12:15 PM
Cheers,
Klaus
80 kg = 0.962
75 kg = 0.954
70 kg = 0.945
Re: The Hobie i-cat pricing is known ! [Re: Smiths_Cat] #181367
06/08/09 12:17 PM
06/08/09 12:17 PM
Wouter Offline OP
Wouter  Offline OP
Why stop at 80 ?
Hell, ask for the rating with the iCat at 75 kg ! grin
Re: The Hobie i-cat pricing is known ! [Re: Wouter] #181388
06/08/09 02:40 PM
06/08/09 02:40 PM
Why stop at 80 ?
I provided ratings at 80,75 and 70.
Re: The Hobie i-cat pricing is known ! [Re: Wouter] #181395
06/08/09 02:51 PM
06/08/09 02:51 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
yep, what would be the limit? 70kg maybe. But give some extra material to the mast for sailing with two persons, some extra material for French pebble beaches, so it will be more. However I have some concerns...
Simon,
thanks for calculating.
Cheers,
Klaus
Page 4 of 4 1 2 3 4
0 registered members (), 11,245 guests, and 405 spiders.
