Need help for SPI setup. #18417
04/08/03 03:45 PM
04/08/03 03:45 PM
The Netherlands (North West Eu...
RobLammerts Offline OP
Hello all,
I was wondering if some of you could help me to setup my SPI system.
I have a 25m2 Spi. 9.34 * 8.08 * 4.20 meters and a 9.34 meter long mast.
At what place do I mount the Spi hound ?
I am thinking of a Spiboom of app 3.90 meters.
Thanks in advance.
Rob Nacra 6.0 European version Nr 090 + Spi
Re: Need help for SPI setup. [Re: RobLammerts] #18418
04/09/03 03:45 AM
04/09/03 03:45 AM
Perhaps this works better for you guy's
Sorry
Meter Foot
9,63 31,59 Mast length.
8,08 26,51 Spi
9,34 30,64 Spi
4,2 13,78 Spi
25 82,02 Square foot Spi
Re: Need help for SPI setup. [Re: RobLammerts] #18419
04/09/03 07:01 AM
04/09/03 07:01 AM
catman Offline
catman  Offline
LOL, meters,whats that??? Well the the safe place for the spin. hound is believed to be one third up,the distance between the main hound and top of the mast. I'm not sure where the stock spin. hound is on a N boat. Most seem to be half way. What boat did the spin. come from. Can you go back to that boat and measure those dimensions? I would opt for the lower spin. hound postion and if needed have the spin. recut.
Re: Need help for SPI setup. [Re: catman] #18420
04/09/03 08:16 AM
04/09/03 08:16 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
The height of the spin tack-pole height, has alot to do with it.
If you're tramp launching it, put the tack lower, rake the mast back, that equals a lower hound height.
F-18 Infusion
#626- SOLD it!
Re: Need help for SPI setup. [Re: Todd_Sails] #18421
04/09/03 11:07 AM
04/09/03 11:07 AM
Burlington, Vermont USA
K
Kevin Rose Offline
Kevin Rose  Offline
K
Todd and Mike,
I've became intrigued by another thread recently showing spi setups on international Tornados.
What are your thoughts on this type of attachment?
Kevin Rose N6.0na #215 Lake Champlain (New England's "west coast") Burlington, Vermont
Re: Need help for SPI setup. [Re: Kevin Rose] #18422
04/09/03 11:45 AM
04/09/03 11:45 AM
There is a hound mounted on the mast by the previuos owner, and indeed it is mounted app one third from the main hound.
When I look at other 6.0's they alway's mount between top and hound app 1/3 from the top.
I am thinking of lounching from the tramp.
The length of the Spi pole will be app 12.8 foot (3.9 meter)
And yes Kevin I am thinking of a similar hound, there is also a lot of info on this on Wouters site.
Does anyone have used a set up like this ?
Re: Need help for SPI setup. [Re: RobLammerts] #18423
04/09/03 02:01 PM
04/09/03 02:01 PM
Andrew Offline
Andrew  Offline
I use a setup similar to the one in the picture for my Prindle 19, and it works great. I recommend it highly; you only have the one (or two) holes in the mast itself. The bail (or leash, or tether) that holds the halyard to the mast is drilled thru the luff track and does not compromise the watertighness of the mast. Further, it minimizes weight aloft, and promotes mast rotation. All good!
sail fast
Re: Need help for SPI setup. [Re: Andrew] #18424
04/09/03 03:27 PM
04/09/03 03:27 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
I agree, have same on my Spitfire, and also had on my Hawk, allows mast to rotate fully.
Dermot
Catapult 265
Do you have a pic of that? [Re: RobLammerts] #18425
04/09/03 03:52 PM
04/09/03 03:52 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
I dont see that the bail, lash/tether goes into the luff track. How does it work? Does it tie thru 2 holes, have eyes on one or each side?
Thanks,
David
SEACATS
Re: Do you have a pic of that? [Re: dave mosley] #18426
04/09/03 05:06 PM
04/09/03 05:06 PM
K
Kevin Rose Offline
Kevin Rose  Offline
K
From Wouter's pages: You can see the two holes into the luff track. Knot is on outside.
Re: Do you have a pic of that? [Re: Kevin Rose] #18427
04/09/03 05:50 PM
04/09/03 05:50 PM
catman Offline
catman  Offline
Kevin, My set up is some thing like the one pictured.The only diffrence is my spin haylard is led inside the luff track. It goes over the top of the mast through two small blocks and then down to the hound block. The nice thing is I only have one line hanging around if the chute is bagged and no line against the outside of the mast. You need to keep an eye on the hound line. If you can't run it like mine then it has to be done like the picture.
Re: Do you have a pic of that? [Re: catman] #18428
04/09/03 05:59 PM
04/09/03 05:59 PM
catman Offline
catman  Offline
As far as the pole goes,how much adjustment do have with a N boat. Does the foil restrict you?
Re: Do you have a pic of that? [Re: Kevin Rose] #18429
04/09/03 06:00 PM
04/09/03 06:00 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
Try the site:
http://www.geocities.com/f16hpclass/Tech_genaker_mast_setups.html
Dermot
Catapult 265
Re: Do you have a pic of that? [Re: catman] #18430
04/09/03 10:18 PM
04/09/03 10:18 PM
K
Kevin Rose Offline
Kevin Rose  Offline
K
The foil does limit how high you can bring the pole. Many of the 6.0na sailors use bridle foil wires that are 4" longer than stock. (I just ordered a pair from Rick Bliss at New England Catamarans.)
Re: Do you have a pic of that? [Re: Dermot] #18431
04/10/03 01:07 AM
04/10/03 01:07 AM
catman Offline
catman  Offline
Dermot,The only problem with that setup is it looks like there is 4 holes instead of just two. Am I seeing that right?
Re: Do you have a pic of that? [Re: catman] #18432
04/10/03 03:16 AM
04/10/03 03:16 AM
Cape Town, South Africa
Steve_Kwiksilver Offline
We have the same method of having a strop at the height of the required position of the pulley, if you want to have fewer holes in the mast, take the line to the top of the mast & tie it off there instead of drilling 2 holes in the sealed part of the mast for an eyelet. (See the attached pic.) The holes for the line which holds the pulley in place are in the luff track, outside of the sealed section of the mast, so no water can get into the mast.
Steve
Re: Do you have a pic of that? [Re: catman] #18433
04/10/03 03:40 AM
04/10/03 03:40 AM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
Wouters photo has 4 holes in the track, where the rope goes in and then out again on the same side and is knotted.
The photo that Kevin has at the beginning of this thread, looks as if the hole is just large enough to take the rope twice. It goes across the track, out, and is then knotted.
As others have said, holes in the track do not compromise the sealed mast.
Dermot
Catapult 265
Re: Do you have a pic of that? [Re: Dermot] #18434
04/11/03 01:51 AM
04/11/03 01:51 AM
catman Offline
catman  Offline
I understand the holes don't enter the sealed part of the mast. My point is if two work why drill more.
Off to Miami,
Re: Do you have a pic of that? [Re: catman] #18435
04/11/03 07:29 AM
04/11/03 07:29 AM
Todd_Sails Offline
Todd_Sails  Offline
Kevin, et.al.,
I have been posting a link to the tornado site for awhile now. MIne is rigged exactly like the pic, and my knots for the bail loop line are INSIDE my sail track. It works fine with just two holes, pull it thru, tie a knot, and slip it back into the sail track, the outside knot obviously works also.
For those who don't have the link:
http://www.acay.com.au/~bundy/layout.html
This is a good discussion, enjoy!
F-18 Infusion
#626- SOLD it!
Re: Do you have a pic of that? [Re: Todd_Sails] #18436
04/11/03 09:51 AM
04/11/03 09:51 AM
K
Kevin Rose Offline
Kevin Rose  Offline
K
I have been posting a link to the tornado site for awhile now. MIne is rigged exactly like the pic, and my knots for the bail loop line are INSIDE my sail track. It works fine with just two holes, pull it thru, tie a knot, and slip it back into the sail track, the outside knot obviously works also. . . This is a good discussion, enjoy!
Todd,
Links to sites like that are sooooo helpful. Thanks. The photographs of the rigging details are great. One thing that I noted was the hardware used for attachment to the main beam. Any thoughts on the best way to source those specialty items?
On a related note, aside from old windsurfer masts, etc., it seems that there's always difficulty in sourcing aluminum tubing for poles. Yesterday I was poking around in the Thomas Register for distributors. When looking at the various specs for t-6061 drawn tubing, this question came to mind. What is the minimum acceptable wall thickness? (Say, for a 2" OD tube.)
Also, for those who run the tack line inside the pole, what do you use for blocks where the line exits near the beam? Is it an in-line, through deck block set into the pole?
1 registered members (FredL), 446 guests, and 68 spiders.
