Question of Balance #185244
07/15/09 04:07 PM
07/15/09 04:07 PM
Chicago, Illinois USA
TEH Offline OP
TEH  Offline OP
I thought I’d throw this one out to the group to see if anyone had any comments or suggestions other than “lose weight.”
I weigh 205 lbs and I am having trouble keeping the boat in balance, particularly in light winds. I get a lot of churn off the stern and a low pitch gurgle.
When I trap out under higher winds, I feel I can get the balance right as the gurgle goes away and I get a good clean wake and a higher pitch hiss as the boat goes through the water. I generally have my forward foot slightly ahead of the shroud to achieve this balance.
In lighter winds, I move up on the boat, ahead of the shroud, but I feel the stern is still dragging too much and it is hard to run the tiller from this position. I am thinking about using the collapsible stick from my Hobie to make it easier to use versus the long one-piece stick on the Blade.
Blade F16 USA 725
Re: Question of Balance [Re: TEH] #185245
07/15/09 04:18 PM
07/15/09 04:18 PM
pgp Offline
pgp  Offline
I think you'll have to go to the telescoping stick. As the wind permits, get as far forward as possible, and in toward the mast. Even at 230 I can get the gurgle to quiet down. The hum might be an unfair edge.
Pete Pollard
Blade 702
Re: Question of Balance [Re: pgp] #185246
07/15/09 04:23 PM
07/15/09 04:23 PM
TEH Offline OP
TEH  Offline OP
Sounds good. I have seen the speed pickup on the GPS by moving both up and towards the center.
Blade F16 USA 725
Re: Question of Balance [Re: TEH] #185253
07/15/09 05:29 PM
07/15/09 05:29 PM
France
pepin Offline
pepin  Offline
France
I fixed my non telescopic stick off center on the tiler bar. Not by much, but in low wind I can put if flat on the middle of the trampoline and leave it there when I tack. I lock it between the mast and the spi halyard cleat on the front beam.
With it there I can drive the boat while sitting on the front beam with small gentle pushes on it.
0 registered members (), 724 guests, and 115 spiders.
Posts267,056
