| Re: Black Anodizing
[Re: ThunderMuffin]
#187634 08/11/09 03:06 PM 08/11/09 03:06 PM | andrewscott
| andrewscott
Unregistered | nothing like holding on to a 70lb mast that is burning your hands!!! | | | Re: Black Anodizing
[Re: ]
#187642 08/11/09 05:16 PM 08/11/09 05:16 PM |
Joined: Oct 2006 Posts: 119 Bernhards Bay, N.Y. popeyez7
Posts: 119 Bernhards Bay, N.Y. | When I re-did my 2 Hobies, I bought black epoxy paint~~ regular spray can size from Ace hdw. I think it's like refridg. paint....... looks good !!
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION'' ~17,18 Hobies, ~Jet boat~Speedster 150 ~2 Kayaks~ ~~~~VIETNAM VET. 69-71~~~~
| | | Re: Black Anodizing
[Re: brucat]
#187648 08/11/09 06:29 PM 08/11/09 06:29 PM |
Posts: 76 | My first call would be Powdercoating. Second call Paint.
Taipan AUS329 'Got Wood' Mosquito 752 'Sticky Finger' HARDWOOD RACING TEAM
| | | Re: Black Anodizing
[Re: Got Wood]
#187665 08/11/09 08:36 PM 08/11/09 08:36 PM |
Posts: 1,911 South Florida & the Keys | I once tried to re-anodize the beams on my H-20, it was just barely OK not like new. See above for alternatives.....
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Black Anodizing
[Re: Karl_Brogger]
#187684 08/12/09 03:02 AM 08/12/09 03:02 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | You can try Penetrol for making them look good again. Wipe two or three coats on about 24 hrs. between coats. It will eventually start to flake off after about a year then just pressure spray and re coat.
A guy here has a 89 H-18 and he wipes all of the metal down with it. Looking at it you'd think metal was all new.
You can find it in the paint dept at Home Depot.
| | | Re: Black Anodizing
[Re: catman]
#187702 08/12/09 08:44 AM 08/12/09 08:44 AM | andrewscott
| andrewscott
Unregistered | 3am post Mike? you must be going to bed around 6pm these days..  | | | Re: Black Anodizing
[Re: brucat]
#187762 08/12/09 06:42 PM 08/12/09 06:42 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Like was said helps flow out for paint,varnish. If you use it like I said it will act the way armorall does for plastic,tires etc. The difference is this stuff will dry and not wash off. The stuff is cheap and worth trying before spending a bunch of cash refinishing or whatever. Try a small area and see if it works. If you scratch it just wipe more on. Like paint though you want to do it on a windless day to keep stuff sticking to it.
I just used it on a old clear anodized Bimini frame that was clouded. Wiped it with Penetrol and it looks nice and has a shine.
There's only two types that I've seen. I found both at depot. Regular and Marine Penetrol. Recently I tried to find the marine version and it's no where to be found. I think it's all the same stuff.
| | | Re: Black Anodizing
[Re: ncik]
#187869 08/13/09 11:01 AM 08/13/09 11:01 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Anodizing shouldn't "flake" off. It is part of the oxide layer on the aluminium and can only really be removed mechanically or chemically.
I suspect it is paint or powder coating if it is flaking off. Probably not applied correctly (grind, acid wash, primer, etc.) if it is only 3 years old. I think he said it was fading. It happens. If you read up on anodizing they just add a dye for the color and like most things there are high and low quality products. The sun is pretty tough to beat.
5,776
guests, and 514
