Black Anodizing #187626
08/11/09 02:07 PM
08/11/09 02:07 PM
brucat Offline OP
brucat  Offline OP
Any good ideas on how to restore faded black anodizing?
My 2006 H16 is practically brand new (hardly ever used since having a baby), but the black crossbars look like an 80s beach boat from sitting out in the sun for the past 3 years.
As an aside, I don't recall the black anodizing on my last two boats looking this bad when I sold them (at 4 and 5 years old, respectively).
Re: Black Anodizing [Re: brucat] #187633
08/11/09 03:01 PM
08/11/09 03:01 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
re-anno'ing aluminum is a difficult process since the treatment is actually a chemical process. you could powdercoat them, or paint them, but both add un-wanted weight.
Considering the amount of heat that black aluminum absorbs, I'm surprised that manufacturers do that.
Clear anno protects the metal and keeps it nice and cool.
Re: Black Anodizing [Re: ThunderMuffin] #187634
08/11/09 03:06 PM
08/11/09 03:06 PM
andrewscott
andrewscott
nothing like holding on to a 70lb mast that is burning your hands!!!
Re: Black Anodizing [Re: ] #187642
08/11/09 05:16 PM
08/11/09 05:16 PM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
When I re-did my 2 Hobies, I bought black epoxy paint~~ regular spray can size from Ace hdw. I think it's like refridg. paint....... looks good !!
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
Re: Black Anodizing [Re: brucat] #187648
08/11/09 06:29 PM
08/11/09 06:29 PM
G
Got Wood Offline
Got Wood  Offline
G
My first call would be Powdercoating. Second call Paint.
Taipan AUS329 'Got Wood'
Mosquito 752 'Sticky Finger'
HARDWOOD RACING TEAM
Re: Black Anodizing [Re: Got Wood] #187665
08/11/09 08:36 PM
08/11/09 08:36 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I once tried to re-anodize the beams on my H-20, it was just barely OK not like new. See above for alternatives.....
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Black Anodizing [Re: arbo06] #187669
08/11/09 09:04 PM
08/11/09 09:04 PM
There are places that do really good anodizing, but in small batches it isn't cheap unless they can sneak it in with another batch. If they do military grade stuff its a good sign.
Re: Black Anodizing [Re: Karl_Brogger] #187684
08/12/09 03:02 AM
08/12/09 03:02 AM
catman Offline
catman  Offline
You can try Penetrol for making them look good again. Wipe two or three coats on about 24 hrs. between coats. It will eventually start to flake off after about a year then just pressure spray and re coat.
A guy here has a 89 H-18 and he wipes all of the metal down with it. Looking at it you'd think metal was all new.
You can find it in the paint dept at Home Depot.
Re: Black Anodizing [Re: catman] #187702
08/12/09 08:44 AM
08/12/09 08:44 AM
andrewscott
andrewscott
3am post Mike? you must be going to bed around 6pm these days.. smile
Re: Black Anodizing [Re: ] #187708
08/12/09 09:40 AM
08/12/09 09:40 AM
catman Offline
catman  Offline
I think someone's clock is off. It shows 6:02 am here which is about right.
Thanks for pointing that out though. (:P
Re: Black Anodizing [Re: catman] #187719
08/12/09 11:57 AM
08/12/09 11:57 AM
brucat Offline OP
brucat  Offline OP
Thanks guys. I'm definitely not painting or re-anodizing, was looking for other ideas, I should have clarified.
Isn't Penetrol just a cleaner? I've heard of that before.
Re: Black Anodizing [Re: brucat] #187723
08/12/09 12:47 PM
08/12/09 12:47 PM
TurboCat Offline
TurboCat  Offline
Penetrol is actually a addative for paint that makes it flow out easier.
Re: Black Anodizing [Re: TurboCat] #187745
08/12/09 04:02 PM
08/12/09 04:02 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
There is more than one type of Penetrol, one is for fiberglass restoration, I have used it on faded tramps, and faded, colored hulls (doesn't work very well on white hulls)
with good results
Re: Black Anodizing [Re: brucat] #187762
08/12/09 06:42 PM
08/12/09 06:42 PM
catman Offline
catman  Offline
Like was said helps flow out for paint,varnish. If you use it like I said it will act the way armorall does for plastic,tires etc. The difference is this stuff will dry and not wash off. The stuff is cheap and worth trying before spending a bunch of cash refinishing or whatever. Try a small area and see if it works. If you scratch it just wipe more on. Like paint though you want to do it on a windless day to keep stuff sticking to it.
I just used it on a old clear anodized Bimini frame that was clouded. Wiped it with Penetrol and it looks nice and has a shine.
There's only two types that I've seen. I found both at depot. Regular and Marine Penetrol. Recently I tried to find the marine version and it's no where to be found. I think it's all the same stuff.
Re: Black Anodizing [Re: catman] #187764
08/12/09 06:46 PM
08/12/09 06:46 PM
catman Offline
catman  Offline
PENETROL
A quart is plenty.
Re: Black Anodizing [Re: Hullflyer1] #187776
08/12/09 08:43 PM
08/12/09 08:43 PM
arbo06 Offline
arbo06  Offline
I use flowtrol for latex paints, will that work?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Black Anodizing [Re: arbo06] #187783
08/12/09 09:15 PM
08/12/09 09:15 PM
ncik Offline
ncik  Offline
Anodizing shouldn't "flake" off. It is part of the oxide layer on the aluminium and can only really be removed mechanically or chemically.
I suspect it is paint or powder coating if it is flaking off. Probably not applied correctly (grind, acid wash, primer, etc.) if it is only 3 years old.
Re: Black Anodizing [Re: arbo06] #187867
08/13/09 10:57 AM
08/13/09 10:57 AM
catman Offline
catman  Offline
Additive for latex, not the same.
Re: Black Anodizing [Re: ncik] #187869
08/13/09 11:01 AM
08/13/09 11:01 AM
catman Offline
catman  Offline
I think he said it was fading. It happens. If you read up on anodizing they just add a dye for the color and like most things there are high and low quality products. The sun is pretty tough to beat.
0 registered members (), 3,923 guests, and 139 spiders.
