| Traveller purchase ratio? #189621 08/31/09 06:46 AM 08/31/09 06:46 AM |
Posts: 757 japan | Hi all, when i bought my nacra 5.2 the traveller sheet was tied off to the block on the rear beam giving me a 2:1 purchase
especially when sailing without the jib in big winds and broad reaching i've found 2:1 on the traveller sheet not to be enough
looking at the boat today i realised that instead of tying off to that rear beam block i can easily increase the purchase to 3:1 by running a longer sheet through it and then back to the traveller car
am guessing that 18-20 foot cats use 3:1...block and saddle 12-16 foot cats use 2:1...only saddle on rear beam center and 17foot boats use either 2:1 or 3:1
would that be about right?
| | | Re: Traveller purchase ratio?
[Re: erice]
#189625 08/31/09 07:17 AM 08/31/09 07:17 AM |
Posts: 171 Cary, NC | Have any pictures of the 2:1 set up?
Ryan 1983 Isotope
[Re: erice]
#189626 08/31/09 07:18 AM 08/31/09 07:18 AM |
Posts: 190 | As I recall my 5.3 had a bullet block on the back beam and the traveler sheet turned back to the traveler car. This gave us 3:1
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
[Re: lesburn1]
#189628 08/31/09 07:36 AM 08/31/09 07:36 AM |
Posts: 12,310 South Carolina | Mine had that too (and I could never get it work well without tangling or limiting the amount I could center the traveler)...everything now (F18, N20, etc) uses a simple 2:1.
Jake Kohl | | | Re: Traveller purchase ratio?
[Re: lesburn1]
#189630 08/31/09 07:51 AM 08/31/09 07:51 AM |
Posts: 757 japan | have a pic but can't post. easy to describe 1:1 would have sheet running through swivel and tying off on traveller car 2:1 would have sheet running through swivel to traveller car and then back to center of rear beam 3:1 would have sheet running through swivel to traveller car, back to block mounted at center of rear beam, then back to traveller car am also hoping that 3:1 will allow me to pull main in about another inch for going to weather better as someone pointed out in this video from 1:35 to 1:53 the main isn't centering well even when fully pulled in with just 2:1 http://www.vimeo.com/5075989 ahhhh, so pretty much everything uses 2:1...hhhmmm..........
[Re: erice]
#189631 08/31/09 07:59 AM 08/31/09 07:59 AM |
Posts: 2,584 +31NL | If you feel a lot of resistance pulling it in you might try some smoother line like swiftcord. You could put a split-tail on the end of your traveler as well to center it properly.
[Re: Tony_F18]
#189634 08/31/09 08:07 AM 08/31/09 08:07 AM |
Posts: 757 japan | have heard of split tailing but can't quite imagine it, will search, anyone feel free to chime in with pics or links please
[Re: erice]
#189635 08/31/09 08:13 AM 08/31/09 08:13 AM |
Posts: 4,451 West coast of Norway | am also hoping that 3:1 will allow me to pull main in about another inch for going to weather better as someone pointed out in this video from 1:35 to 1:53 the main isn't centering well even when fully pulled in with just 2:1 http://www.vimeo.com/5075989 You were going to windward in that sequence? I thought you were reaching. Car is out rather a lot, yes. You do have a split tail on the traveller sheet so you are able to center it? Mainsheet looks like it needs much more tension and that is an easy fix  (I dont know your boat and you did not film the sails and their trim, but the sheet looks really loose). | | | Re: Traveller purchase ratio?
[Re: Tony_F18]
#189637 08/31/09 08:19 AM 08/31/09 08:19 AM |
Posts: 757 japan | hi Tony, saw that in the google search, how does it attached to the rear beam, 2 saddles on each side of halfway?
Rolf, have forgotten exactly what i was doing there, will use my newly purchased spray dry lube on the traveller car rollers, thanks for tip
do need to replace the rough old line
[Re: erice]
#189641 08/31/09 08:30 AM 08/31/09 08:30 AM | andrewscott
| andrewscott
Unregistered | Rolf, have forgotten exactly what i was doing there, will use my newly purchased spray dry lube on the traveler car rollers, thanks for tip
They say not to lube up delron bearings as it will cause them to not roll and get flat spots the new OneDrop from McLube works well and is under $10. I also HAVE to lube (silicone) up my track every weekend to help my car slide (or it wont slide under tension) on my TheMightyHobie18 you HAD to release main pressure if you wanted to travel. I probably need new car/track but the x track is part of my rear beam so there is no easy/reasonably cheap upgrade. my x track is getting so sharp from use i cut my hands pulling my cat up the beach 2 weeks ago. time to fix that...
290
guests, and 50
