Traveller purchase ratio? #189621
08/31/09 06:46 AM
08/31/09 06:46 AM
japan
erice Offline OP
erice  Offline OP
japan
Hi all,
when i bought my nacra 5.2 the traveller sheet was tied off to the block on the rear beam giving me a 2:1 purchase
especially when sailing without the jib in big winds and broad reaching i've found 2:1 on the traveller sheet not to be enough
looking at the boat today i realised that instead of tying off to that rear beam block i can easily increase the purchase to 3:1 by running a longer sheet through it and then back to the traveller car
am guessing that 18-20 foot cats use 3:1...block and saddle
12-16 foot cats use 2:1...only saddle on rear beam center
and 17foot boats use either 2:1 or 3:1
would that be about right?
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Traveller purchase ratio? [Re: erice] #189625
08/31/09 07:17 AM
08/31/09 07:17 AM
Cary, NC
Storz Offline
Storz  Offline
Cary, NC
Have any pictures of the 2:1 set up?
Ryan
1983 Isotope
Re: Traveller purchase ratio? [Re: erice] #189626
08/31/09 07:18 AM
08/31/09 07:18 AM
lesburn1 Offline
lesburn1  Offline
As I recall my 5.3 had a bullet block on the back beam and the traveler sheet turned back to the traveler car. This gave us 3:1
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
Re: Traveller purchase ratio? [Re: lesburn1] #189628
08/31/09 07:36 AM
08/31/09 07:36 AM
Mine had that too (and I could never get it work well without tangling or limiting the amount I could center the traveler)...everything now (F18, N20, etc) uses a simple 2:1.
Re: Traveller purchase ratio? [Re: lesburn1] #189630
08/31/09 07:51 AM
08/31/09 07:51 AM
japan
erice Offline OP
erice  Offline OP
japan
have a pic but can't post. easy to describe
1:1 would have sheet running through swivel and tying off on traveller car
2:1 would have sheet running through swivel to traveller car and then back to center of rear beam
3:1 would have sheet running through swivel to traveller car, back to block mounted at center of rear beam, then back to traveller car
am also hoping that 3:1 will allow me to pull main in about another inch for going to weather better
as someone pointed out in this video from 1:35 to 1:53 the main isn't centering well even when fully pulled in with just 2:1
http://www.vimeo.com/5075989
ahhhh, so pretty much everything uses 2:1...hhhmmm..........
eric e
2009 weta tri - 294
Re: Traveller purchase ratio? [Re: erice] #189631
08/31/09 07:59 AM
08/31/09 07:59 AM
If you feel a lot of resistance pulling it in you might try some smoother line like swiftcord.
You could put a split-tail on the end of your traveler as well to center it properly.
Re: Traveller purchase ratio? [Re: Tony_F18] #189633
08/31/09 08:06 AM
08/31/09 08:06 AM
Tornado also have a 2:1 on the traveller. No problem centering it.
Friction is your enemy. Not only the line but also rollers the line pass through and the roller balls inside the car must have as little friction as possible.
If running the car is very heavy work, why not release some mainsheet or alter course before operating the car? Both will release pressure on the main and the traveller car.
Re: Traveller purchase ratio? [Re: Tony_F18] #189634
08/31/09 08:07 AM
08/31/09 08:07 AM
japan
erice Offline OP
erice  Offline OP
japan
have heard of split tailing but can't quite imagine it, will search, anyone feel free to chime in with pics or links please
eric e
2009 weta tri - 294
Re: Traveller purchase ratio? [Re: erice] #189635
08/31/09 08:13 AM
08/31/09 08:13 AM
You were going to windward in that sequence? I thought you were reaching.
Car is out rather a lot, yes. You do have a split tail on the traveller sheet so you are able to center it?
Mainsheet looks like it needs much more tension and that is an easy fix wink (I dont know your boat and you did not film the sails and their trim, but the sheet looks really loose).
Re: Traveller purchase ratio? [Re: erice] #189636
08/31/09 08:15 AM
08/31/09 08:15 AM
http://www.layline.com/product/11211/764
Re: Traveller purchase ratio? [Re: Tony_F18] #189637
08/31/09 08:19 AM
08/31/09 08:19 AM
japan
erice Offline OP
erice  Offline OP
japan
hi Tony, saw that in the google search, how does it attached to the rear beam, 2 saddles on each side of halfway?
Rolf, have forgotten exactly what i was doing there, will use my newly purchased spray dry lube on the traveller car rollers, thanks for tip
do need to replace the rough old line
eric e
2009 weta tri - 294
Re: Traveller purchase ratio? [Re: erice] #189640
08/31/09 08:29 AM
08/31/09 08:29 AM
If the traveller is not running freely, check the balls inside as well. They do wear out and require replacement.
Be careful if you take the car off. You need a piece of track to run the car on to.
The split tail is tied off to a small eyelet on each side of the centerpoint of the beam. Implementing this will gain you a few centimeters but it will not center 100% anyway. Best solution there is so far though.
Re: Traveller purchase ratio? [Re: erice] #189641
08/31/09 08:30 AM
08/31/09 08:30 AM
andrewscott
andrewscott
Rolf, have forgotten exactly what i was doing there, will use my newly purchased spray dry lube on the traveler car rollers, thanks for tip
They say not to lube up delron bearings as it will cause them to not roll and get flat spots
the new OneDrop from McLube works well and is under $10. I also HAVE to lube (silicone) up my track every weekend to help my car slide (or it wont slide under tension)
on my TheMightyHobie18 you HAD to release main pressure if you wanted to travel.
I probably need new car/track but the x track is part of my rear beam so there is no easy/reasonably cheap upgrade. my x track is getting so sharp from use i cut my hands pulling my cat up the beach 2 weeks ago. time to fix that...
Re: Traveller purchase ratio? [Re: erice] #189642
08/31/09 08:30 AM
08/31/09 08:30 AM
You rivet one of these to either side of the traveler center about 5" or 10" apart and cleat the tail in there:
1 registered members (FredL), 446 guests, and 68 spiders.
