Rating: 4
Page 9 of 10 1 2 7 8 9 10
Re: Alter Cup Updates from water [Re: PTP] #194331
10/23/09 12:22 PM
10/23/09 12:22 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Originally Posted by PTP
can someone post the pic of the spreaders being out of whack? it can have phil's gooberness over it, I don't care.
Here it is goobernessless, just for you Patrick.
Philip
USA #1006
Re: Alter Cup Updates from water [Re: P.M.] #194332
10/23/09 12:25 PM
10/23/09 12:25 PM
yeah, that ain't right.
thanks Phil smile
Re: Alter Cup Updates from water [Re: P.M.] #194333
10/23/09 12:29 PM
10/23/09 12:29 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Great job with the pics Phillip. Were can I find the pics of "The Stuff", they are not on the beachcats site.
Re: Alter Cup Updates from water [Re: ksurfer2] #194335
10/23/09 01:06 PM
10/23/09 01:06 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Thanks dude,
I appreciate the compliment. I will post a link once I get the pictures done. There is alot of work on my end. I have the start sequence and the finish sequence which is owesome. I will post the awards and "THE STUFF", and everything else once I get home. I'm traveling now.
Philip
USA #1006
Re: Alter Cup Updates from water [Re: P.M.] #194338
10/23/09 01:23 PM
10/23/09 01:23 PM
Portland, Maine
ThunderMuffin Offline OP
Portland, Maine
Chris: its not too difficult to imagine. My spin halyard comes down to my front crossbeam to a small turning block on the front of the beam. Then behind the turning block are two cleats almost back to back.
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194341
10/23/09 02:23 PM
10/23/09 02:23 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
erased
Re: Alter Cup Updates from water [Re: David Parker] #194342
10/23/09 02:38 PM
10/23/09 02:38 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Originally Posted by David Parker
is "slipping" common or even possible without some impact?
Was the boat whose spreader slipped the same boat that had to be laid over on its side to fix the spin block? Could the spreader have been displace during that tip-over?
Good questions. We talked about this at length last night and this morning. Both Easton and JC boats were gone over carefully and in detail before leaving the beach for the last race. Greg feels very confident that it was square when the boat was stood up, but you never know. Two theories 1) When they righted the boat on the beach the person walking the mast up walked it up along the diamond wires as apposed to the side stay, and might have bumped it up. 2)the head of the spin in the spin set could have got caught on the spreader and been forced up when raising the halyard.
When the boats left the beach they were all on the same tack and downwind, making it unlikely that Tripp yanked it up with the halyard, as the picture showed it was already that way. So it was likely yank up in a previous race with a different team on the boat, or done on the beach. I don't think it is likely that it got moved on the beach as the diamonds were set on 33, but who knows.
Philip
USA #1006
Re: Alter Cup Updates from water [Re: P.M.] #194343
10/23/09 02:40 PM
10/23/09 02:40 PM
pgp Offline
pgp  Offline
Is the little machine bolt still in place?
Pete Pollard
Blade 702
Re: Alter Cup Updates from water [Re: P.M.] #194345
10/23/09 02:43 PM
10/23/09 02:43 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
I'm going to see if I can find a picture of the spreader on that boat from a previous race, but that is a long shot . . .
Philip
USA #1006
Re: Alter Cup Updates from water [Re: pgp] #194346
10/23/09 02:46 PM
10/23/09 02:46 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
yes, on all boats. This was a freak thing to happen, as was the spin pole bridle on JC's boat.
Philip
USA #1006
Re: Alter Cup Updates from water [Re: P.M.] #194356
10/23/09 03:58 PM
10/23/09 03:58 PM
Dunedin Causeway, FL
David Parker Offline
The photo looks like it was boat #6 that broke the mast. I'm pretty sure it was boat #8 that was flipped to fix the spin halyard block. It was the race that Ding probably got redress for on Wednesday. Can you check if it was #8 or #6?
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194357
10/23/09 04:25 PM
10/23/09 04:25 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Okay I see. My cleat is on a swivel. Yours is not?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Alter Cup Updates from water [Re: Chris9] #194358
10/23/09 04:37 PM
10/23/09 04:37 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
chris, the double cleats are the small harken's to match the line size of the halyard. the fair lead for the double is a harken 16 mm air block sewn to the tramp a foot or two back. This allows you to hoist in any direction. You should position the 16 mm block so that you can pull the halyard through the jaws and it's always cleated. to release you pull the halyard between the 16 mm and the cleats while pulling on the retrieval line.
crac.sailregattas.com
Re: Alter Cup Updates from water [Re: David Parker] #194359
10/23/09 04:50 PM
10/23/09 04:50 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Boat #6 David
We had more than one of the sheave issues, and boats were regularly being turned over for various reasons.
Here is what I have found so far in the forensics of the pictures. I have many pictures of the spreader square on the end of day 3.
Day 4 the team on boat #6 in the previous race was Jake. I have a picture of the spreader in the compromised position. There was another race before (A fleet) that I have nothing on yet, so the spreader was raced in the compromised position for at least 2 races. Remember in all the hoists the spin was to port.
Tad, Is there a way I can attach the picture larger than 100K. Send me some magic . . .
Philip
USA #1006
Re: Alter Cup Updates from water [Re: P.M.] #194360
10/23/09 04:53 PM
10/23/09 04:53 PM
Portland, Maine
Portland, Maine
Philip: not on catsailor you can't.
email me the pics and I can upload them to velocitysailing.com to embed them here.
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194367
10/23/09 06:12 PM
10/23/09 06:12 PM
Portland, Maine
Portland, Maine
Here's the pic on race 4 I guess.
Re: Alter Cup Updates from water [Re: PTP] #194373
10/23/09 08:18 PM
10/23/09 08:18 PM
SC
zander Offline
zander  Offline
SC
Originally Posted by Wouter
In my opinion the simple steel Harken small blocks are best in this use.
these work great with a line from luff track through the center of the block to the other side and a pigtail from the tang.
Ask Jake about that little block on the spinny halyard.
Before Tybee we looked over the boats pretty well and JC had one of those on the "General Lee" (a.k.a. Team Seacats Orange) the strap was torn through about 2/3 or 3/4 of the way. Replaced it and all is well but they need to be inspected regularly.
The shock on Jake's face was priceless, who knows how many times that boat raced with the block compromised, I know tradewinds and some others. Probably some races when JC had it as well.
Always borrow money from a pessimist. He won't expect it back.
Re: Alter Cup Updates from water [Re: Mark Schneider] #194375
10/23/09 10:44 PM
10/23/09 10:44 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
I understand the tramp thingy; my crews didn't like the block being there. Dont understand the double cleat thing.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194392
10/24/09 09:12 AM
10/24/09 09:12 AM
Rock Hill,SC
KevinRejda Offline
KevinRejda  Offline
Rock Hill,SC
Some drama went down in a redress yesterday.
Humphries was sailing in the Silver Fleet yesterday and was leading the fleet in the race when his mainsheet broke about 100 yards from the finish. They fashioned a repair on the water and finished in 4th place. They filed for redress and the committee gave them a finish averaging their previous results.
Well the competitors didn't quite like that determination so they forced the committee to reopen the redress and they instead awarded Humphries the 1st place finish for that race as they rightfully should have (according to the competitors involved).
So they'll be joining the Gold fleet next time they race.
Just a clarification, no one "forced" anything, we reconsidered our decision and decided to make the change.
Kevin Rejda
Rock Hill, SC
Re: Alter Cup Updates from water [Re: P.M.] #194394
10/24/09 09:18 AM
10/24/09 09:18 AM
Rock Hill,SC
KevinRejda Offline
KevinRejda  Offline
Rock Hill,SC
Originally Posted by mummp
Originally Posted by acceleratedchaos
JC/Williams awarded a place of 2 for the redress.
This leaves two points seperating 1st and 2nd place with two races to go if in fact they get 3 races in today.
Actually, Easton/Byrd were awarded 1 in the changed redress, so they went into the last race 1 point apart. It is a crying shame the mast broke.
Incorrect, their request for redress had been denied and nothing was changed later, don't know where this info came from.
Kevin Rejda
Rock Hill, SC
0 registered members (), 638 guests, and 97 spiders.
Posts267,056
