| Another F16 Blast. .. Very Well Done !
[Re: HJS]
#195777 11/10/09 10:58 AM 11/10/09 10:58 AM |
Posts: 9,582 North-West Europe | Full results can be found here http://www.weston.org.uk/site/news/archive/2009/Catamarans_2009OpenNov.htmVery well done by Chris Sproat and Georgina Burke indeed. I guess this is what the F16 class needed. The best of boat design, sailor skills, regular training and an active cat sailing scene coming together in order to show what "it" can do in a respected fleet. Marvelous ! Wouter
| | | Re: Another F16 Blast. .. Very Well Done !
[Re: Rolf_Nilsen]
#195809 11/10/09 01:08 PM 11/10/09 01:08 PM |
Posts: 976 France | What was the difference between a Viper and a F16 Viper? None. But the Viper is heavier than the minimum weight for a F16, hence its rate. | | | Re: Another F16 Blast. .. Very Well Done !
[Re: Rolf_Nilsen]
#195814 11/10/09 01:28 PM 11/10/09 01:28 PM |
Posts: 52 | No, but it was sailing off a considerably more generous rating. None the less it takes nothing away from the boats performance or from it's performance at Grafham a few weeks ago when it was leading the many times UK F18 champion over the water until it took a swim!
[Re: macca]
#195844 11/10/09 04:57 PM 11/10/09 04:57 PM |
Posts: 3,528 Looking for a Job, I got credi... | Not that I am here to stir **** but if you run the results from Weston with the fabled F16 yardstick you will see a different result...
So if a Viper wins the intergalactic challenge this week, maybe you should look at increasing the min weight of the boats as it clearly has no performance advantage and you will benefit from a ratings advantage which in this case has resulted in the best F16 result that I have seen to date.
I'd suggest that if Chris was sailing a fully optimised F16 on the F16 handicap he would have also won the event. Chris is a feckin good sailor. Simple as that.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Another F16 Blast. .. Very Well Done !
[Re: macca]
#195851 11/10/09 05:27 PM 11/10/09 05:27 PM |
Posts: 2,718 St Petersburg FL | Not that I am here to stir **** but if you run the results from Weston with the fabled F16 yardstick you will see a different result...
The boat has nothing to do with winning the "Intergalactic, Global, Universe, Championship of the all the planets in the whole wide Milky Way" look at the folks driving the Vipers... John Casey, Gregg Goodall, Robbie Daniels, I bet if you put any of those drivers on a piece of plywood with satin sheets as sails they will beat all of us mortals. I believe its in the best interest of the class not to go down the entire "that boat is better" road. | | | Re: Another F16 Blast. .. Very Well Done !
[Re: macca]
#195871 11/10/09 07:39 PM 11/10/09 07:39 PM |
Posts: 9,582 North-West Europe | Not that I am here to stir [censored] but if you run the results from Weston with the fabled F16 yardstick you will see a different result...
Maybe, but also maybe not ! Afterall, the report said ".... including one race won over the water!" I'm not convinced that Sproat and Burke had much need for the softer handicap. Of course it does help but I personally feel that a 2nd place score in this fleet would be just as impressive as their overall win. Note that the 3rd place holder is another 7 points further behind (14 points in total). That constitudes some leeway in their advantage. I think Chris and Georgina did very well in a tough fleet of state-of-the-art catamarans. Wouter
[Re: macca]
#195879 11/10/09 08:32 PM 11/10/09 08:32 PM |
Posts: 586 Hobart, Tasmania, Oz. |
My point is that they were sailing a 1.04 boat and not an F16 (as per rating)
If the Viper is quicker than the other F16 boats (as we will see this week in Florida) then why does the class persist with a handicap that is worse than it could be for the same or better on the water performance?
are you saying the the rest of the f16's should add 20 kilos of correctors to get up to 104 handicap and that they will be faster as well??? or not significantly slowed down??? I am still trying to come to terms with Wouter describing a fleet of F18's as "state-of-the-art"
[Re: HJS]
#195888 11/10/09 09:48 PM 11/10/09 09:48 PM |
Posts: 465 Oxford, UK | A couple of the older Taipans are near the weight limit, but the VIPERS, BLADES & FALCON are mostly above the 120kgs!! Huh? I saw most of the Blades and Falcons weighing in and I didn't see one over 120. Paul | | | Re: Another F16 Blast. .. Very Well Done !
[Re: Robi]
#195890 11/10/09 10:32 PM 11/10/09 10:32 PM |
Posts: 1,021 Australia | As far as weights are concerned I have no idea where they are. I do know the Vipers are indeed heavier. But what makes them the best F16?
That is like saying the Capricorn is better than the Infusion or the Infusion is better than the Wildcat.
All the F18' are built to the same weight so its not the same at all. | | |
495
guests, and 58
