Page 1 of 11 1 2 3 10 11
Another F16 Blast. #195763
11/10/09 09:47 AM
11/10/09 09:47 AM
Vic, Australia
HJS Offline OP
HJS  Offline OP
Vic, Australia
I have just read an email from Chris Sproat that I thought you might be interested in.
We have just won the Weston Cat Open which incorporated the UK Nacra Nationals. This was 57 boat mixed fleet start including most of the UK F18's. There were five races (one discard) and we won with 7 points, including one race won over the water!
The conditions were flat water with wind strength from force 2 - 4. Upwind we could match the F18s for height and speed. Down wind the F18 was marginally faster in the lighter conditions but not when the wind strength increased.
There were significant gusts in the wind which seemed to suit us.
I think we have made an impression by stealing the Nacra thunder. Bloody marvelous long may it last.
Another F16 Blast. .. Very Well Done ! [Re: HJS] #195777
11/10/09 10:58 AM
11/10/09 10:58 AM
Full results can be found here
http://www.weston.org.uk/site/news/archive/2009/Catamarans_2009OpenNov.htm
Very well done by Chris Sproat and Georgina Burke indeed.
I guess this is what the F16 class needed. The best of boat design, sailor skills, regular training and an active cat sailing scene coming together in order to show what "it" can do in a respected fleet.
Marvelous !
Re: Another F16 Blast. .. Very Well Done ! [Re: Wouter] #195788
11/10/09 11:53 AM
11/10/09 11:53 AM
G
GBR6 Offline
GBR6  Offline
G
I'm not sure this did anything for the F16 class in the UK; it was sailed as a Viper and off the 104 handicap, had it sailed as a F16 I do not believe it would have won the event. Fantastic performance from a 16ft boat though and it does look great.
Re: Another F16 Blast. .. Very Well Done ! [Re: GBR6] #195802
11/10/09 12:51 PM
11/10/09 12:51 PM
What was the difference between a Viper and a F16 Viper?
Re: Another F16 Blast. .. Very Well Done ! [Re: Rolf_Nilsen] #195809
11/10/09 01:08 PM
11/10/09 01:08 PM
France
pepin Offline
pepin  Offline
France
None. But the Viper is heavier than the minimum weight for a F16, hence its rate.
Re: Another F16 Blast. .. Very Well Done ! [Re: Rolf_Nilsen] #195810
11/10/09 01:10 PM
11/10/09 01:10 PM
waynemarlow Offline
waynemarlow  Offline
About 20 kilos in weight, has anyone measured the Viper yet ? as I beleive the one that originally came to the UK was a pre production heavy weight, still to beat the F18's on the handicap Chris used is still pretty impressive.
I wonder how many Spitfire sailors will jump on board the Viper bandwagon now that Chris is doing so well.
Re: Another F16 Blast. .. Very Well Done ! [Re: waynemarlow] #195813
11/10/09 01:22 PM
11/10/09 01:22 PM
It could be 100kgs over min weight and it would still be an F16 if that is the case. Rules dont specify max. weight. smile
Re: Another F16 Blast. .. Very Well Done ! [Re: Rolf_Nilsen] #195814
11/10/09 01:28 PM
11/10/09 01:28 PM
G
GBR6 Offline
GBR6  Offline
G
No, but it was sailing off a considerably more generous rating. None the less it takes nothing away from the boats performance or from it's performance at Grafham a few weeks ago when it was leading the many times UK F18 champion over the water until it took a swim!
Re: Another F16 Blast. .. Very Well Done ! [Re: Rolf_Nilsen] #195815
11/10/09 01:28 PM
11/10/09 01:28 PM
waynemarlow Offline
waynemarlow  Offline
Ah but by being 20 kilos over Chris can claim the softer handicap of the 104 class.
I have to say maybe we should all do that at mixed competitions. However it should only be considered if the 10 kilos of beer I have consumed trying to keep up with MarkP plus the 10 kilos of extra lard, will be considered in my case as to be boat weight
Re: Another F16 Blast. .. Very Well Done ! [Re: waynemarlow] #195833
11/10/09 03:36 PM
11/10/09 03:36 PM
Australia
macca Offline
macca  Offline
Australia
Not that I am here to stir **** but if you run the results from Weston with the fabled F16 yardstick you will see a different result...
So if a Viper wins the intergalactic challenge this week, maybe you should look at increasing the min weight of the boats as it clearly has no performance advantage and you will benefit from a ratings advantage which in this case has resulted in the best F16 result that I have seen to date.
________________________
http://aus300.blogspot.com
Re: Another F16 Blast. .. Very Well Done ! [Re: macca] #195844
11/10/09 04:57 PM
11/10/09 04:57 PM
I'd suggest that if Chris was sailing a fully optimised F16 on the F16 handicap he would have also won the event.
Chris is a feckin good sailor. Simple as that.
Re: Another F16 Blast. .. Very Well Done ! [Re: macca] #195851
11/10/09 05:27 PM
11/10/09 05:27 PM
The boat has nothing to do with winning the "Intergalactic, Global, Universe, Championship of the all the planets in the whole wide Milky Way" look at the folks driving the Vipers...
John Casey, Gregg Goodall, Robbie Daniels, I bet if you put any of those drivers on a piece of plywood with satin sheets as sails they will beat all of us mortals.
I believe its in the best interest of the class not to go down the entire "that boat is better" road.
Re: Another F16 Blast. .. Very Well Done ! [Re: macca] #195871
11/10/09 07:39 PM
11/10/09 07:39 PM
Not that I am here to stir [censored] but if you run the results from Weston with the fabled F16 yardstick you will see a different result...
Maybe, but also maybe not !
Afterall, the report said ".... including one race won over the water!"
I'm not convinced that Sproat and Burke had much need for the softer handicap.
Of course it does help but I personally feel that a 2nd place score in this fleet would be just as impressive as their overall win. Note that the 3rd place holder is another 7 points further behind (14 points in total). That constitudes some leeway in their advantage.
I think Chris and Georgina did very well in a tough fleet of state-of-the-art catamarans.
Re: Another F16 Blast. .. Very Well Done ! [Re: Wouter] #195878
11/10/09 08:14 PM
11/10/09 08:14 PM
Australia
macca Offline
macca  Offline
Australia
I know Chris and Georgina and they are great sailors.
My point is that they were sailing a 1.04 boat and not an F16 (as per rating)
If the Viper is quicker than the other F16 boats (as we will see this week in Florida) then why does the class persist with a handicap that is worse than it could be for the same or better on the water performance?
Re: Another F16 Blast. .. Very Well Done ! [Re: macca] #195879
11/10/09 08:32 PM
11/10/09 08:32 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
are you saying the the rest of the f16's should add 20 kilos of correctors to get up to 104 handicap and that they will be faster as well??? or not significantly slowed down???
I am still trying to come to terms with Wouter describing a fleet of F18's as "state-of-the-art"
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Another F16 Blast. .. Very Well Done ! [Re: Dazz] #195881
11/10/09 08:40 PM
11/10/09 08:40 PM
Australia
macca Offline
macca  Offline
Australia
The Viper is clearly the best "F16" boat at the moment and its 20kg heavier than the F16 rule permits as a min.
So if it can win regattas at its design weight of 125kg and its design handicap of 1.04 then I fail to see any advantage in using another F16 design that is slower on the water and has a worse handicap.
It may be possible that if you added 20kg to another design it wouldn't suffer as much in performance as it gains in rating...
And I too had a chuckle at Wouter's little comment at the State of the art F18.... I love them as a class but to call it state of the art is just a little out there!
Re: Another F16 Blast. .. Very Well Done ! [Re: Dazz] #195882
11/10/09 08:42 PM
11/10/09 08:42 PM
Vic, Australia
HJS Offline OP
HJS  Offline OP
Vic, Australia
With regard to the weight issue... How about checking out the weights of the boats at this years global challenge? There are very few boats less than 120kgs.
A couple of the older Taipans are near the weight limit, but the VIPERS, BLADES & FALCON are mostly above the 120kgs!!
Re: Another F16 Blast. .. Very Well Done ! [Re: HJS] #195884
11/10/09 09:29 PM
11/10/09 09:29 PM
As far as weights are concerned I have no idea where they are. I do know the Vipers are indeed heavier. But what makes them the best F16?
That is like saying the Capricorn is better than the Infusion or the Infusion is better than the Wildcat.
If viper wins the GC this week its not the boat, its the people sailing the boat.
Re: Another F16 Blast. .. Very Well Done ! [Re: HJS] #195888
11/10/09 09:48 PM
11/10/09 09:48 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Huh? I saw most of the Blades and Falcons weighing in and I didn't see one over 120.
Re: Another F16 Blast. .. Very Well Done ! [Re: Robi] #195890
11/10/09 10:32 PM
11/10/09 10:32 PM
Australia
macca Offline
macca  Offline
Australia
All the F18' are built to the same weight so its not the same at all.
1 registered members (FredL), 343 guests, and 59 spiders.
