| Who uses Cat Beach Wheels #19843 05/22/03 10:49 PM 05/22/03 10:49 PM |
Joined: May 2003 Posts: 15 West Palm Beach SingerIsland OP
Posts: 15 West Palm Beach | I wonder how many people use Cat Beach wheels. Are you going up and down dune lines or a flat run?
| | | Re: Who uses Cat Beach Wheels
[Re: vicatman]
#19845 05/23/03 01:55 AM 05/23/03 01:55 AM |
Posts: 15 Scotland | I use a small trolley as I exclusively launch from a concrete slipway. Never tried it on sand. Did anybody use small wheel trolleys on sand? Does it work? Should I buy a big wheel one if I plan to launch from sand (Dart Hawk F18, 180kg)?
thanks, phil
Phil
Dart Hawk F18 #744
Scotland
[Re: SingerIsland]
#19846 05/23/03 02:10 AM 05/23/03 02:10 AM |
Posts: 364 | All serious racers that I know of use beach wheels. It saves dragging the boat on the beach, AND dunking the trailer in the water. This can be a big issue, even with galvanized trailers, when the sailing venue is saline. I've had my beach wheels three years, under two different boats, and the trailer has not been dunked during that time. They are insanely expensive, and they are worth it. Go get beach wheels!
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: Andrew]
#19847 05/23/03 08:32 AM 05/23/03 08:32 AM |
Posts: 12,310 South Carolina | oh yeah - I can move my N6.0 around by myself with the wheels (as long as it's not too hilly). We use them everywhere to reduce wear on the boat and make moving the boat around much easier.
Jake Kohl | | | Re: Who uses Cat Beach Wheels
[Re: Andrew]
#19849 05/23/03 05:48 PM 05/23/03 05:48 PM |
Posts: 1,911 South Florida & the Keys | Amen! My wheels are 6 years old, I've never even had to repair them or even put air in them. Better then sliced bread or a back injury!
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Who uses Cat Beach Wheels
[Re: SingerIsland]
#19850 05/23/03 06:39 PM 05/23/03 06:39 PM |
Posts: 75 Jensen Beach, FL | Never leave home without them. Or deal with the dreaded oyster shell........ Ouch!!!  Followed by an extensive and expensive bottom job.  AJ Nacra 6.0 Express | | | Re: Who uses Cat Beach Wheels
[Re: SingerIsland]
#19851 05/27/03 11:18 AM 05/27/03 11:18 AM |
Posts: 217 | I always use them, except when launching from ramp with dock. On flat ground, or gentle beach, it is easy to move the boat single-handed. On steeper inclines or softer sand you may need a helper. As the others have said, eliminating wear & tear on hulls is key. They've been well worth the $$ I spent on them. I've done zero maintenance on the wheels in 8 years. They're in the sun constantly, the rubber is fine.
[Re: jcasto1]
#19852 05/27/03 03:47 PM 05/27/03 03:47 PM |
Posts: 591 Bradenton, FL | My boat sits mast-up ~150 sandy feet from the water. I keep the wheels under it and can load the boat onto them and wheel it to the water's edge solo. Saves the bottoms and my back (G-Cat's don't drag well). Best $350 I ever spent. I've had them since '97 and never done anything but put air in them!
Hobie 14T
269
guests, and 39
