| Re: standing on hulls
[Re: nova]
#20217 06/05/03 06:30 AM 06/05/03 06:30 AM |
Posts: 170 Australia | sorry bill i dont agree. The hobie 16 has a big problem with soft spots!!! This is due to people standing on the hull and it normaly happens just in front of the pylons. If you have a good boat and want to keep it for a long time dont let him/she walk there, spread the weight if you have to. In terms of the hull pulling away from the pylon well all i have to say is dont worry about it, they are built like a tank just like my ford(EA).
Well have fun sailing.
Jules
Jules_topcat
[Re: h16bill]
#20219 06/09/03 08:42 AM 06/09/03 08:42 AM |
Posts: 170 Australia | Sorry but what yours point?  also how well were the boats taken care of.
Jules_topcat
[Re: nova]
#20222 06/09/03 10:46 PM 06/09/03 10:46 PM |
Posts: 1,252 California | Nova,
Standing on the hull below the sidebar? No problem. On a Hobie 16, that hull is fully supported by the shroud wire for one thing... No problem. You put weight on the hull all you are doing is unloading the tramp. The weight on the hull is virtually the same because the tramp is also riding on the hull. Also, the pylons connection between the hulls and the trampoline is very solid. Even if the hulls were just hanging from the trampoline frame it would support plenty of weight without problem.
As far as delamination issues there... the area along the rail, that you could stand on, is solid glass. No foam.
In other areas that have foam... just be somewhat careful. Compression, heat, moisture, bad foam, bad resin and other things could cause delamination. Seems like the really hot areas have more problems. I have had plenty of 16s which I walked on, sat on, layed on without problem.
If you do get a soft spot in the deck forward of the front pylon, you have to get it fixed before sailing. There is allot of stress there from the bridles pulling in on the bows while sailing. | | |
2,093
guests, and 271
