Outhaul #204142
02/23/10 12:45 AM
02/23/10 12:45 AM
Melbourne
Nic M Offline OP
Nic M  Offline OP
Melbourne
Hi All,
I am giving up on my current outhaul set up on the boom (an external loop) and am wanting to go to the car system that most mossies seem to go for as there is too much friction when it gets windy.
Could anyone point me in the direction of where I might purchase one of the outhaul cars for the boom ??
Thanks in advance.
Nic Maan
Sanity 1815
Re: Outhaul [Re: Nic M] #204147
02/23/10 03:21 AM
02/23/10 03:21 AM
thricebitten
thricebitten
Hi Nick,
as far as I know they can not be purchased any more. frown
There was a guy in Gippsland custom making a similar unit, but he has stopped also. frown
I found some second hand units off old A class's smile after I had set up I beam on my new boom frown , so local boy's are using those cry .
I am using a short section of I beam, with roller car. A lot heavier, but it certainly works under load, mind you I am using 4 to 1 purchase on it whistle .
Windslyce make a low profile recirculating ball car and track for outhaul similar to mainsheet track, that may also be a option.
Re: Outhaul [Re: ] #204151
02/23/10 04:26 AM
02/23/10 04:26 AM
Matt_Stone Offline
Matt_Stone  Offline
hey
i made my own car inside the boom and works realy well and its only 2 to 1 purchase, the wheels are made out of nylon material with washers welded on so they dont fall off and it rolls inside the boom with the plate of stainless poking out of the slot in the boom, the the outhaul is internal too
Matt UNKO 1816
Re: Outhaul [Re: Matt_Stone] #204152
02/23/10 05:15 AM
02/23/10 05:15 AM
Melb. Aust
Trevor Offline
Trevor  Offline
Melb. Aust
Hi Nic,
I have an old Cobra boom with internal car under the house somewhere you can have.
Let me know and I will dig it out and bring it to the States.
Trevor
Mozzie 1828
Sugarloaf Sailing Club
Melbourne
Re: Outhaul [Re: Trevor] #204155
02/23/10 06:36 AM
02/23/10 06:36 AM
Melbourne
Nic M Offline OP
Nic M  Offline OP
Melbourne
Guys, thanks for the advice. Trev if I could take you up on your offer that would be great. If all else fails I will go with your version Matt.
Many thanks guys.
Nic Maan
Sanity 1815
Re: Outhaul [Re: Nic M] #204218
02/23/10 11:04 PM
02/23/10 11:04 PM
greymatter Offline
greymatter  Offline
Peter Cobden was making cars for the boom, could give him a call and see if he has any left.
Re: Outhaul [Re: greymatter] #204352
02/25/10 04:06 PM
02/25/10 04:06 PM
First_Try Offline
First_Try  Offline
Hi Nic,
Give me a call
0427 352972
Peter
Peter
First Try
Re: Outhaul [Re: First_Try] #204524
02/28/10 04:27 AM
02/28/10 04:27 AM
Parkdale, Vic
N
NixonJr Offline
NixonJr  Offline
N
Parkdale, Vic
Hey Trevor,
What other cobra bits do you have lieing around? smile
Rob.
Robert Nixon
Cobra 581 - Sweet Dreams
Stingray 582
Cobracat.com
Re: Outhaul [Re: NixonJr] #204595
03/01/10 06:53 AM
03/01/10 06:53 AM
Melb. Aust
Trevor Offline
Trevor  Offline
Melb. Aust
Hi Rob,
I have a mast sitting under my deck that is free to a good home (it has diamonds attached), plus all the shrouds etc and beams.
Basically everything from my old Cobra - Incognito - Stuart Scott built.
The starboard hull failed at the main beam about 13 years ago and it was scrapped and I have everything that wouldnt rot.
Trevor
Mozzie 1828
Melbourne
0 registered members (), 429 guests, and 44 spiders.
