| Re: Infusion port daggerboard pull up line
[Re: CatSailingHu]
#207139 03/30/10 09:12 AM 03/30/10 09:12 AM |
Posts: 3,906 Clermont, FL, USA | I'd like some of that too please.
[Re: wildtsail]
#207162 03/30/10 12:34 PM 03/30/10 12:34 PM |
Posts: 12,310 South Carolina | it's nylon webbing and the Capricorn uses it for the boards.
In many cases (on the a-cats anyway) there is a recess in the daggerboard trunk to allow clearance for the knot end of the line. If that recess/slot isn't there, I have seen some folks run the thin nylon webbing straight through board and tie back onto the deck (it gives you 2:1 purchase on lifting the board). Probably need to glue in some sort of nylon hard spot in the board to prevent sawing through the laminate.
Granted, I'm shorthanded on the A - but I wouldn't sail without it there. Its a great system on any boat.
Jake Kohl | | | Re: Infusion port daggerboard pull up line
#207166 03/30/10 01:07 PM 03/30/10 01:07 PM |
Posts: 126 Southampton UK | Offical name is the up fuker.
You dont need webbing, we use a bit of tapered 4mm. In the board you need to drill a hole all the way through the board (just big enough to fit the line through) then on the port side you need drill a fairly large holl a few mm in to the board so that the knot can sit in it and not obsrtuct the board. In the case cut away abit of the carpet where the line runs into the slot.
On our infusion we run the line under the tramp and have a eyelet on the starboard side where it comes out and then goes through a block and ties off on the toe strap.
[Re: NacraKid]
#207168 03/30/10 01:17 PM 03/30/10 01:17 PM |
Posts: 3,293 Long Beach, California | ****" on the Capricorn, Viper and C2.
[Re: ksurfer2]
#207172 03/30/10 01:46 PM 03/30/10 01:46 PM |
Posts: 439 Memphis, TN | How about if your singlehanded on an F16 in heavy air... You say "Phuck IT, I got to much going on to worry about the boards."
Viper USA 132
1984 Hobie 18
[Re: CatSailingHu]
#207381 04/01/10 04:15 PM 04/01/10 04:15 PM |
Joined: Jun 2005 Posts: 133 The Netherlands Kennethsf
Posts: 133 The Netherlands | ask the Hungary dealer {www.nacra.hu]- he should be able to get you a line & webbing set from Nacra Europe
4,751
guests, and 1,030
