| Re: Cat Trax Tires
[Re: Hullflyer1]
#207392 04/01/10 06:35 PM 04/01/10 06:35 PM |
Posts: 1,403 | Florida sailcraft 954=523=9222 Same thing, tire and rim only. And Murray's too. | | | Re: Cat Trax Tires
[Re: Ventucky Red]
#207395 04/01/10 07:08 PM 04/01/10 07:08 PM | MarkMT
| MarkMT
Unregistered | The only thing I can suggest is what used to be Hedlund Marine in Evanston, IL. I know they have stocked cat trax in the past. | | | Re: Cat Trax Tires
[Re: Ventucky Red]
#207403 04/01/10 08:15 PM 04/01/10 08:15 PM |
Posts: 396 Annapolis Md. | Maybe check on agriculture/farm supply web sites? Ed
Still hazey after all these beers. F-16 Falcon #212
| | | Re: Cat Trax Tires
[Re: RickWhite]
#207449 04/02/10 11:26 AM 04/02/10 11:26 AM |
Posts: 3,969 | I don't know if it's BS or not, but I was told by my dealer that the newer tires weren't compatable with older rims (my Cat Trax are from 97, I replaced the tires with rims sometime around 2006).
I've also seen some discussion here about getting tubes if the tires are basically OK just not holding air.
Hope this helps.
| | | Re: Cat Trax Tires
[Re: brucat]
#207450 04/02/10 11:43 AM 04/02/10 11:43 AM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | I've also seen some discussion here about getting tubes if the tires are basically OK just not holding air.
Hope this helps.
If your tires are even in marginal shape, tubes will solve the problem. Make sure to get the ones with stainless valve stems, and dab a little Lanocote where the rim comes into contact with the stem. Once you get the tire off of the axle, set the rim on its side hold onto something and stomp on the bead with your foot to break it. Install tube, and off you go. | | | Re: Cat Trax Tires
[Re: SurfCityRacing]
#207464 04/02/10 04:42 PM 04/02/10 04:42 PM |
Posts: 4,119 Northfield Mn | Once you get the tire off of the axle, set the rim on its side hold onto something and stomp on the bead with your foot to break it. Install tube, and off you go. Yeah, if you're a 6'4" freak that works. I used the bucket of the skidloader to bust the bead on a set I had. If the tire is still there, a tube is a pretty good way to fix it. | | | Re: Cat Trax Tires
[Re: Karl_Brogger]
#207465 04/02/10 04:50 PM 04/02/10 04:50 PM |
Posts: 1,403 | Once you get the tire off of the axle, set the rim on its side hold onto something and stomp on the bead with your foot to break it. Install tube, and off you go. Yeah, if you're a 6'4" freak that works. I used the bucket of the skidloader to bust the bead on a set I had. If the tire is still there, a tube is a pretty good way to fix it. Just did it, busted the bead that is. Now about that diet I have been meaning to get on. | | | Re: Cat Trax Tires
[Re: Karl_Brogger]
#207468 04/02/10 05:06 PM 04/02/10 05:06 PM |
Posts: 749 Santa Cruz, CA | Yeah, if you're a 6'4" freak that works. I used the bucket of the skidloader to bust the bead on a set I had.
 It helps for sure. I showed up to a meeting at a Yacht Club the other day full of people that were talking smack on something I wrote. Several of them PM'd me with a big F-off. I sat in the back sipping a rum and coke, just listening. When the commodore introduced me to the group, their jaws dropped, their eyes bugged, out and the **** immediately stopped slinging. Another instance where being big is an advantage. Bad for cat sailing though. If you've met me in person you'd know that half the stuff I type is with a smile and a twinkle in my eye. No sense in being too serious, you know. Hijack off. Good luck with the wheel dilemma. j | | | Re: Cat Trax Tires
#207471 04/02/10 06:29 PM 04/02/10 06:29 PM |
Posts: 1,430 california | He's just a long haired red headed Baby Hughey
| | | Re: Cat Trax Tires
[Re: Ventucky Red]
#207472 04/02/10 06:30 PM 04/02/10 06:30 PM |
Posts: 1,200 Vancouver, BC | Johnm-Boy, If you're ordering a set of tubes...I'd like to double it wit ya...got a slow leak on one tire... Once you get the tire off of the axle, set the rim on its side hold onto something and stomp on the bead with your foot to break it. Install tube, and off you go. Yeah, if you're a 6'4" freak that works. I used the bucket of the skidloader to bust the bead on a set I had. If the tire is still there, a tube is a pretty good way to fix it. Just did it, busted the bead that is. Now about that diet I have been meaning to get on.
| | | Re: Cat Trax Tires
[Re: Tornado]
#207473 04/02/10 06:56 PM 04/02/10 06:56 PM |
Posts: 1,403 | Johnm-Boy, If you're ordering a set of tubes...I'd like to double it wit ya...got a slow leak on one tire... Check your PM. The Ventura boat ramp not working anymore John? Santa Barabara!!!!!!!
| | | Re: Cat Trax Tires
[Re: Ventucky Red]
#207493 04/03/10 07:14 AM 04/03/10 07:14 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Hmm! Guess I am a candy butt. Took mine to the local garage.., cost $5. Had I done it myself, I probably would have destroyed the tire, tube and rim in the process, and would have cost a lot more. Rick | | | Re: Cat Trax Tires
[Re: RickWhite]
#207943 04/11/10 06:59 PM 04/11/10 06:59 PM |
Posts: 338 | Try changing out your valve stems first. They only cost about $3.00 and with a little soapy water and some effort you can probably fix the problem if its a slow leak.
Did it with one that came with my boat, the schrader valve was corroded and wouldn't seal completely. Cut the old ones off, slapped some new ones in and haven't had a problem since.
619
guests, and 44
