Cat Trax Tires #207387
04/01/10 05:25 PM
04/01/10 05:25 PM
V
Ventucky Red Offline OP
V
Anyone have a line on where I can get JUST the tire? Check Rick's store, N/A need to get tire and rim.
Thanks
Re: Cat Trax Tires [Re: Ventucky Red] #207389
04/01/10 06:16 PM
04/01/10 06:16 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Florida
sailcraft 954=523=9222
Re: Cat Trax Tires [Re: Hullflyer1] #207392
04/01/10 06:35 PM
04/01/10 06:35 PM
V
V
Originally Posted by Hullflyer1
Florida
Same thing, tire and rim only. And Murray's too.
Re: Cat Trax Tires [Re: Ventucky Red] #207395
04/01/10 07:08 PM
04/01/10 07:08 PM
M
MarkMT
MarkMT
M
The only thing I can suggest is what used to be Hedlund Marine in Evanston, IL. I know they have stocked cat trax in the past.
Re: Cat Trax Tires [Re: Ventucky Red] #207403
04/01/10 08:15 PM
04/01/10 08:15 PM
Annapolis Md.
LuckyDuck Offline
LuckyDuck  Offline
Annapolis Md.
Maybe check on agriculture/farm supply web sites? Ed
F-16 Falcon #212
Re: Cat Trax Tires [Re: LuckyDuck] #207412
04/02/10 02:13 AM
04/02/10 02:13 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
https://store.catsailor.com/pc/viewPrd.asp?idproduct=14568&idcategory=287
fsc-tireonly Cat Trax tire Only, (Subtract $45.00 from Listeed Price)
so what do I win?
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Cat Trax Tires [Re: Dazz] #207443
04/02/10 09:57 AM
04/02/10 09:57 AM
RickWhite Offline
RickWhite  Offline
I was going to say, we have the tire ONLY,
Rick
Rick White
www.onlinemarinestore.com
Re: Cat Trax Tires [Re: RickWhite] #207449
04/02/10 11:26 AM
04/02/10 11:26 AM
brucat Offline
brucat  Offline
I don't know if it's BS or not, but I was told by my dealer that the newer tires weren't compatable with older rims (my Cat Trax are from 97, I replaced the tires with rims sometime around 2006).
I've also seen some discussion here about getting tubes if the tires are basically OK just not holding air.
Hope this helps.
Re: Cat Trax Tires [Re: brucat] #207450
04/02/10 11:43 AM
04/02/10 11:43 AM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Hope this helps.
If your tires are even in marginal shape, tubes will solve the problem. Make sure to get the ones with stainless valve stems, and dab a little Lanocote where the rim comes into contact with the stem. Once you get the tire off of the axle, set the rim on its side hold onto something and stomp on the bead with your foot to break it. Install tube, and off you go.
Re: Cat Trax Tires [Re: brucat] #207461
04/02/10 03:36 PM
04/02/10 03:36 PM
RickWhite Offline
RickWhite  Offline
I put tubes in both my Cat Trax and Euros (plastic Rim) and my headaches disappeared. Otherwise they were always going flat.
We sell the tubes also, by the way, and fit both.
Rick
Rick White
Re: Cat Trax Tires [Re: SurfCityRacing] #207464
04/02/10 04:42 PM
04/02/10 04:42 PM
Yeah, if you're a 6'4" freak that works. I used the bucket of the skidloader to bust the bead on a set I had.
If the tire is still there, a tube is a pretty good way to fix it.
Re: Cat Trax Tires [Re: Karl_Brogger] #207465
04/02/10 04:50 PM
04/02/10 04:50 PM
V
V
Just did it, busted the bead that is. Now about that diet I have been meaning to get on.
Re: Cat Trax Tires [Re: Ventucky Red] #207466
04/02/10 04:52 PM
04/02/10 04:52 PM
TeamChums Offline
TeamChums  Offline
The Ventura boat ramp not working anymore John?
Lee
Re: Cat Trax Tires [Re: Karl_Brogger] #207468
04/02/10 05:06 PM
04/02/10 05:06 PM
Santa Cruz, CA
Santa Cruz, CA
grin
It helps for sure.
I showed up to a meeting at a Yacht Club the other day full of people that were talking smack on something I wrote. Several of them PM'd me with a big F-off. I sat in the back sipping a rum and coke, just listening. When the commodore introduced me to the group, their jaws dropped, their eyes bugged, out and the **** immediately stopped slinging. Another instance where being big is an advantage. Bad for cat sailing though.
If you've met me in person you'd know that half the stuff I type is with a smile and a twinkle in my eye. No sense in being too serious, you know.
Hijack off. Good luck with the wheel dilemma.
j
Re: Cat Trax Tires [Re: SurfCityRacing] #207471
04/02/10 06:29 PM
04/02/10 06:29 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
He's just a long haired red headed Baby Hughey
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Cat Trax Tires [Re: Ventucky Red] #207472
04/02/10 06:30 PM
04/02/10 06:30 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Johnm-Boy, If you're ordering a set of tubes...I'd like to double it wit ya...got a slow leak on one tire...
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Cat Trax Tires [Re: Tornado] #207473
04/02/10 06:56 PM
04/02/10 06:56 PM
V
V
Check your PM.
Santa Barabara!!!!!!!
Re: Cat Trax Tires [Re: Ventucky Red] #207493
04/03/10 07:14 AM
04/03/10 07:14 AM
RickWhite Offline
RickWhite  Offline
Hmm! Guess I am a candy butt. Took mine to the local garage.., cost $5.
Had I done it myself, I probably would have destroyed the tire, tube and rim in the process, and would have cost a lot more.
Rick
Rick White
Re: Cat Trax Tires [Re: RickWhite] #207943
04/11/10 06:59 PM
04/11/10 06:59 PM
Nimrod Offline
Nimrod  Offline
Try changing out your valve stems first. They only cost about $3.00 and with a little soapy water and some effort you can probably fix the problem if its a slow leak.
Did it with one that came with my boat, the schrader valve was corroded and wouldn't seal completely. Cut the old ones off, slapped some new ones in and haven't had a problem since.
Re: Cat Trax Tires [Re: Nimrod] #208014
04/12/10 10:13 AM
04/12/10 10:13 AM
Houston
carlbohannon Offline
Houston
The last time I had a leaky tire I pulled the old valve stem out, dumped a 16 oz bottle of Slime in, and put the new valve stem in. When I inflated the tire, green stuff came out from the bead, for while. That was 6 years ago. No leaks since
0 registered members (), 336 guests, and 43 spiders.
