Anyone have1990 Reg White Tornado rigging diagrams? #207628
04/05/10 10:32 PM
04/05/10 10:32 PM
Alberta
C
Chris_A Offline OP
Chris_A  Offline OP
C
Alberta
Could any body steer me to some pics? Thanks
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: Chris_A] #207667
04/06/10 03:14 PM
04/06/10 03:14 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Hi Chris,
What do you need? Though not a Reg boat, my SailCraft of Canada rigging pics can be seen here:
Classic rig
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: Tornado] #207675
04/06/10 04:05 PM
04/06/10 04:05 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
I will see Rob White later in the week if you have any specific questions
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: Tornado] #207695
04/06/10 11:39 PM
04/06/10 11:39 PM
Alberta
C
Chris_A Offline OP
Chris_A  Offline OP
C
Alberta
Hello Mike, I am looking for details at the foot of the mast, mail sail and jib downhaul and mast rotator setup, a neighbor of mine bought a 1990 Reg White and it is different to my 1978 sailcraft of Canada T.
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: Chris_A] #207698
04/07/10 02:07 AM
04/07/10 02:07 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
has it got the massive ankle breaker rotator at the base?
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: TEAMVMG] #207722
04/07/10 04:55 PM
04/07/10 04:55 PM
Alberta
C
Chris_A Offline OP
Chris_A  Offline OP
C
Alberta
That's the one.
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: Tornado] #208151
04/13/10 10:45 AM
04/13/10 10:45 AM
Alberta
C
Chris_A Offline OP
Chris_A  Offline OP
C
Alberta
Hi Mike, great pics and descriptions of the classic rig!
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: Chris_A] #208185
04/13/10 12:20 PM
04/13/10 12:20 PM
andrewscott
andrewscott
Mike, question for ya... in this pic, it seems to me the 4 way cross wire has a ton of slack. this leads to the block sitting 1' (give or take) above the tramp.
would it matter / be better if it was tight/lowering the blocks or do you just adjust the fore/aft position to adjust for this?
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: ] #208216
04/13/10 04:18 PM
04/13/10 04:18 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Andrew.
Your pic didn't load, but I think you are talking about the jib "horse" cable across the tramp. The ends of the cable attach to sliders running in alu tracks rivetted to the inner gunwales.If the cable is not slack, the loading from the jib block will tend to pry the tracks off the hull. If the cable were completely tight/straight across the tramp, the mechanical advantage when a 90 degree force is applied becomes huge. By have what appears as a very slack cable, the force is much better controlled/angled, dispersing the loading at the track.
Fore/aft sheeting angle on the sail is easily achieved by sliding the cable ends back & forth where needed. Inboard/outboard "slot" adjustment is made with the block adjustment lines (green) along the cable. System works quite will, although the horse is a problem while tacking.
Mike Dobbs
Re: Anyone have1990 Reg White Tornado rigging diagrams? [Re: Tornado] #208295
04/14/10 08:30 AM
04/14/10 08:30 AM
andrewscott
andrewscott
gotcha, makes perfect sense. my mystere has a very similar system, with the exception.. my tracks are partially pulled out (due to the force you mention).
my "horse" is vectran and semi lose... i was going to tighten it up... but now i think not!
thanks Mike
0 registered members (), 658 guests, and 467 spiders.
