| Re: Anyone have1990 Reg White Tornado rigging diagrams?
[Re: Chris_A]
#207667 04/06/10 03:14 PM 04/06/10 03:14 PM |
Posts: 1,200 Vancouver, BC | Hi Chris, What do you need? Though not a Reg boat, my SailCraft of Canada rigging pics can be seen here: Classic rig
[Re: Tornado]
#207675 04/06/10 04:05 PM 04/06/10 04:05 PM |
Posts: 1,203 uk | I will see Rob White later in the week if you have any specific questions
[Re: Chris_A]
#207698 04/07/10 02:07 AM 04/07/10 02:07 AM |
Posts: 1,203 uk | has it got the massive ankle breaker rotator at the base?
[Re: TEAMVMG]
#207722 04/07/10 04:55 PM 04/07/10 04:55 PM |
Posts: 16 Alberta | | | | Re: Anyone have1990 Reg White Tornado rigging diagrams?
[Re: Chris_A]
#208185 04/13/10 12:20 PM 04/13/10 12:20 PM | andrewscott
| andrewscott
Unregistered | Mike, question for ya... in this pic, it seems to me the 4 way cross wire has a ton of slack. this leads to the block sitting 1' (give or take) above the tramp. would it matter / be better if it was tight/lowering the blocks or do you just adjust the fore/aft position to adjust for this? | | | Re: Anyone have1990 Reg White Tornado rigging diagrams?
[Re: ]
#208216 04/13/10 04:18 PM 04/13/10 04:18 PM |
Posts: 1,200 Vancouver, BC | Andrew.
Your pic didn't load, but I think you are talking about the jib "horse" cable across the tramp. The ends of the cable attach to sliders running in alu tracks rivetted to the inner gunwales.If the cable is not slack, the loading from the jib block will tend to pry the tracks off the hull. If the cable were completely tight/straight across the tramp, the mechanical advantage when a 90 degree force is applied becomes huge. By have what appears as a very slack cable, the force is much better controlled/angled, dispersing the loading at the track.
Fore/aft sheeting angle on the sail is easily achieved by sliding the cable ends back & forth where needed. Inboard/outboard "slot" adjustment is made with the block adjustment lines (green) along the cable. System works quite will, although the horse is a problem while tacking.
[Re: Tornado]
#208295 04/14/10 08:30 AM 04/14/10 08:30 AM | andrewscott
| andrewscott
Unregistered | gotcha, makes perfect sense. my mystere has a very similar system, with the exception.. my tracks are partially pulled out (due to the force you mention).
my "horse" is vectran and semi lose... i was going to tighten it up... but now i think not!
thanks Mike | | |
394
guests, and 187
