Season comes to an end #207532
04/03/10 07:08 PM
04/03/10 07:08 PM
Simon C Offline OP
Simon C  Offline OP
I was doing my usual pre put in the garage inspection and found this crazy Other side as well though not quite as bad... Lucky to make it back to the beach I reckon. And so, the winter repairs start early cry
Simon
Taipan AUS341
Re: Season comes to an end [Re: Simon C] #207567
04/04/10 11:42 PM
04/04/10 11:42 PM
Melbourne
Nic M Offline
Nic M  Offline
Melbourne
That is too bad Simon.....was that on Sat ?? A great days sailing at Rye on Sat and I bet McCrae was just as good.
Nic Maan
Sanity 1815
Re: Season comes to an end [Re: Nic M] #207572
04/05/10 03:58 AM
04/05/10 03:58 AM
Gippsland Lakes
mitchellsailor Offline
Gippsland Lakes
Is this an internal radius beam, or more recent?
The more common/popular way of attatching beams is a bolt and washer on the top with an aluminium sleeve in between to stop the beam compressing therefore using the top and bottom bit of the beam and spreading the load. incase anyone was wondering smile
Mosquito 1750 Bonnie-GLYC / Peninsula
The plan was simple.... Like my brother in law Phil, except this plan just might work!
Re: Season comes to an end [Re: mitchellsailor] #207574
04/05/10 04:11 AM
04/05/10 04:11 AM
Simon C Offline OP
Simon C  Offline OP
Yep. The hole you're looking at provides access to the bolt which tightens against the bottom of the beam. Looking at the other one which has just started to crack, they failed from the top down, suggesting that the oversized access whole was the "design flaw" Glad it wasn't blowing 30 crazy
Simon
Taipan AUS341
Re: Season comes to an end [Re: Simon C] #207635
04/06/10 05:17 AM
04/06/10 05:17 AM
Peter_Foulsum Offline
Hi Simon,
How old are the beams or do they pre-date your ownership ?
See, pushing the Mozzie harder and harder has its price. shocked
Peter
Mosquito 1814
Macka Mozzie
Re: Season comes to an end [Re: Peter_Foulsum] #207641
04/06/10 08:41 AM
04/06/10 08:41 AM
Simon C Offline OP
Simon C  Offline OP
Hi Peter,
Yes the beams do pre date my ownership. Had a couple of good wins though... Hard not to push .. I reckon it's the most fun you can have with your pants on and worth the repairs grin
Simon
Taipan AUS341
Re: Season comes to an end [Re: Simon C] #207700
04/07/10 03:15 AM
04/07/10 03:15 AM
NQLD, Australia
Learning to Fly... Offline
NQLD, Australia
Simon,
The radius on the hole was as much as the blame as the diameter of the hole. Ideally the hole edge should have been sanded back to a radius of half the material thickness on the upper and lower sides of the hole.
The current hole has a sharp edge to the hole cut-out, this along with a small defect would have caused a stress concentration point. Suggest you drop a hole size and radius the hole with corrosion protection where you have removed the anodising.
Jon
0 registered members (), 3,832 guests, and 100 spiders.
09:43 PM
