| Re: What do you do when your bow stuffs?
[Re: wildtsail]
#208561 04/15/10 08:49 PM 04/15/10 08:49 PM |
Posts: 829 Charleston, SC | I generally drop my traveller a foot or two and then quickly pull it back in as soon as the bows start to rise.
Trey
[Re: NCSUtrey]
#208563 04/15/10 09:03 PM 04/15/10 09:03 PM |
Posts: 2,921 Michigan | I generally drop my traveller a foot or two and then quickly pull it back in as soon as the bows start to rise. yeah, what he said | | | Re: What do you do when your bow stuffs?
[Re: PTP]
#208564 04/15/10 09:07 PM 04/15/10 09:07 PM |
Posts: 3,224 Roanoke Island ,N.C. | Trim in to stall and drop the traveler. Swim is the other option.
[Re: Team_Cat_Fever]
#208565 04/15/10 09:09 PM 04/15/10 09:09 PM |
Posts: 2,921 Michigan | I understand the premise of trimming in to stall but I am more a believer in blowing the thing. the apparent wind changes a lot when you slow down that much. It changes how much? probably at least 90 degrees? likely more
[Re: wildtsail]
#208569 04/15/10 09:14 PM 04/15/10 09:14 PM |
Posts: 12,310 South Carolina | When sailing downwind with your spinnaker and your bow stuffs hard, like up to crossbeam, presuming your crew is locked in on the wire... what should be done with the spinnaker... should it be blown to reduce momentum? OR held tight to hopefully lift the bows? OR is it too late to do anything and just cross your fingers? We've tried the first two and found about the same success rate but i'm leaning towards the idea of staying trimmed in... any other methods? How about trimming the spinnaker in to reduce flow but still keep generating lift? Skipper to crew: "why did you quit trimming?"
Jake Kohl | | | Re: What do you do when your bow stuffs?
[Re: Don_Atchley]
#208578 04/15/10 10:45 PM 04/15/10 10:45 PM |
Posts: 6,049 Sebring, Florida. | I usually go straight to the Swim option, like the Marines say when they enter a bar on Shore Leave, "Go Ugly Early, avoid the rush..."
I look for a soft spot to land so I don't break anything and then I can get busy snuffing the spin to right the boat...I'm getting pretty quick at it really.
Blade F16 #777
[Re: wildtsail]
#208582 04/16/10 03:59 AM 04/16/10 03:59 AM |
Posts: 246 Kiel, Germany | I am afraid to risk the mast (Capricorn), so I neither touch main-sheet or -traveller. The crew eases the spi by one or two armlengths, but if you're already stuffed till the frontbeam, it's usually too late anyway ...
F18: C2 / A-Cat: Minelli
[Re: Baltic]
#208583 04/16/10 04:15 AM 04/16/10 04:15 AM |
Posts: 3,528 Looking for a Job, I got credi... | Sailing the F16 with T foils; it's only happened once and I just sailed thru the wave.
If I have to do something (Had an Inter 17 before the F16) I would sheet the Kite IN to stall it further and then ease as soon as the bows came up.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: What do you do when your bow stuffs?
[Re: Timbo]
#208587 04/16/10 07:08 AM 04/16/10 07:08 AM |
Posts: 5,525 | http://www.youtube.com/watch?v=-y1bzMljkwMIt looks like dropping the traveler would work. Finding the time might be a problem.
Pete Pollard Blade 702
[Re: pgp]
#208593 04/16/10 08:04 AM 04/16/10 08:04 AM | andrewscott
| andrewscott
Unregistered | according to Pete's video... send the crew out to the forestay to manually push the spin back in the tube... | | | Re: What do you do when your bow stuffs?
[Re: wildtsail]
#208606 04/16/10 09:03 AM 04/16/10 09:03 AM |
Posts: 1,152 tampa, fl | Correct me if I'm wrong, but won't dropping the traveler only make the situation worse????? When the bows stuff, the boat stops and the aparent wind moves WAAAAY aft. Dropping the traveler will now expose more sail area to the new apparent wind making a bad situation worse. I've always dealt with it by keeping weight back (as soon as bodies start going forward, it's all over), driving down (assuming rudders are still in the water), and praying!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: What do you do when your bow stuffs?
[Re: ksurfer2]
#208608 04/16/10 09:07 AM 04/16/10 09:07 AM |
Posts: 5,525 | look at the very last few seconds of the video. Isn't it the main that actually takes the boat over?
[Re: pgp]
#208611 04/16/10 09:13 AM 04/16/10 09:13 AM |
Posts: 6,049 Sebring, Florida. | In the end, it's always the main that takes it over, the spin is flogging by then. I doubt if anyone's got time to play with the traveler, when it happens, it happens fast!
Blade F16 #777
2,787
guests, and 979
