Page 1 of 3 1 2 3
What do you do when your bow stuffs? #208560
04/15/10 08:40 PM
04/15/10 08:40 PM
Newport, RI
wildtsail Offline OP
Newport, RI
When sailing downwind with your spinnaker and your bow stuffs hard, like up to crossbeam, presuming your crew is locked in on the wire... what should be done with the spinnaker... should it be blown to reduce momentum? OR held tight to hopefully lift the bows? OR is it too late to do anything and just cross your fingers?
We've tried the first two and found about the same success rate but i'm leaning towards the idea of staying trimmed in... any other methods? How about trimming the spinnaker in to reduce flow but still keep generating lift?
Re: What do you do when your bow stuffs? [Re: wildtsail] #208561
04/15/10 08:49 PM
04/15/10 08:49 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
I generally drop my traveller a foot or two and then quickly pull it back in as soon as the bows start to rise.
Trey
Re: What do you do when your bow stuffs? [Re: wildtsail] #208562
04/15/10 08:55 PM
04/15/10 08:55 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
... sound the diving klaxon(horn).....
Aoooga, Aoooga, Aoooga .... dive, dive, dive
Just don't "blow" the main if you wish to keep your stick ....
I don't believe that there is one correct solution as it depends on many factors .....
Re: What do you do when your bow stuffs? [Re: NCSUtrey] #208563
04/15/10 09:03 PM
04/15/10 09:03 PM
yeah, what he said
Re: What do you do when your bow stuffs? [Re: PTP] #208564
04/15/10 09:07 PM
04/15/10 09:07 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Trim in to stall and drop the traveler. Swim is the other option.
Isak Dinesen
E. B. White
Re: What do you do when your bow stuffs? [Re: Team_Cat_Fever] #208565
04/15/10 09:09 PM
04/15/10 09:09 PM
I understand the premise of trimming in to stall but I am more a believer in blowing the thing.
the apparent wind changes a lot when you slow down that much. It changes how much? probably at least 90 degrees? likely more
Re: What do you do when your bow stuffs? [Re: wildtsail] #208569
04/15/10 09:14 PM
04/15/10 09:14 PM
Skipper to crew: "why did you quit trimming?"
Re: What do you do when your bow stuffs? [Re: Jake] #208571
04/15/10 10:17 PM
04/15/10 10:17 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
pump the spin. let an arm length out then take 2 arms in
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: What do you do when your bow stuffs? [Re: F-18 5150] #208574
04/15/10 10:35 PM
04/15/10 10:35 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I know not of this "stuffing the bows" that you speak of.
*eats another cheeseburger*
Re: What do you do when your bow stuffs? [Re: ThunderMuffin] #208576
04/15/10 10:39 PM
04/15/10 10:39 PM
Seattle,Wa
Don_Atchley Offline
Don_Atchley  Offline
Seattle,Wa
I'll gladly pay you Tuesday...
Hobie Tiger 2003
Re: What do you do when your bow stuffs? [Re: Don_Atchley] #208578
04/15/10 10:45 PM
04/15/10 10:45 PM
I usually go straight to the Swim option, like the Marines say when they enter a bar on Shore Leave, "Go Ugly Early, avoid the rush..."
I look for a soft spot to land so I don't break anything and then I can get busy snuffing the spin to right the boat...I'm getting pretty quick at it really.
Re: What do you do when your bow stuffs? [Re: wildtsail] #208582
04/16/10 03:59 AM
04/16/10 03:59 AM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
I am afraid to risk the mast (Capricorn), so I neither touch main-sheet or -traveller. The crew eases the spi by one or two armlengths, but if you're already stuffed till the frontbeam, it's usually too late anyway ...
F18: C2 / A-Cat: Minelli
Re: What do you do when your bow stuffs? [Re: Baltic] #208583
04/16/10 04:15 AM
04/16/10 04:15 AM
Sailing the F16 with T foils; it's only happened once and I just sailed thru the wave.
If I have to do something (Had an Inter 17 before the F16) I would sheet the Kite IN to stall it further and then ease as soon as the bows came up.
Re: What do you do when your bow stuffs? [Re: scooby_simon] #208586
04/16/10 06:51 AM
04/16/10 06:51 AM
Ask Seth:
http://picasaweb.google.com/115536799553525989336/GYCMultihullRegattaDay3#5460114203764123234
Who's on that boat in the background applauding...?
Re: What do you do when your bow stuffs? [Re: Timbo] #208587
04/16/10 07:08 AM
04/16/10 07:08 AM
pgp Offline
pgp  Offline
http://www.youtube.com/watch?v=-y1bzMljkwM
It looks like dropping the traveler would work. Finding the time might be a problem.
Pete Pollard
Blade 702
Re: What do you do when your bow stuffs? [Re: pgp] #208593
04/16/10 08:04 AM
04/16/10 08:04 AM
andrewscott
andrewscott
according to Pete's video... send the crew out to the forestay to manually push the spin back in the tube...
Re: What do you do when your bow stuffs? [Re: ] #208603
04/16/10 08:52 AM
04/16/10 08:52 AM
Newport, RI
Newport, RI
Keeping it sheeted or pump seem to be the way to go.
The traveler idea opens up another can of worms... i've heard two schools of thought..
1)Dropping the traveler drives the bow down
2)Dropping the traveler lifts the bows
Which is it?
Re: What do you do when your bow stuffs? [Re: wildtsail] #208606
04/16/10 09:03 AM
04/16/10 09:03 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Correct me if I'm wrong, but won't dropping the traveler only make the situation worse????? When the bows stuff, the boat stops and the aparent wind moves WAAAAY aft. Dropping the traveler will now expose more sail area to the new apparent wind making a bad situation worse. I've always dealt with it by keeping weight back (as soon as bodies start going forward, it's all over), driving down (assuming rudders are still in the water), and praying!
Re: What do you do when your bow stuffs? [Re: ksurfer2] #208608
04/16/10 09:07 AM
04/16/10 09:07 AM
pgp Offline
pgp  Offline
look at the very last few seconds of the video. Isn't it the main that actually takes the boat over?
Pete Pollard
Blade 702
Re: What do you do when your bow stuffs? [Re: pgp] #208611
04/16/10 09:13 AM
04/16/10 09:13 AM
In the end, it's always the main that takes it over, the spin is flogging by then. I doubt if anyone's got time to play with the traveler, when it happens, it happens fast!
Page 1 of 3 1 2 3
0 registered members (), 5,361 guests, and 684 spiders.
Most Online7,274
4 hours ago
