Singlehanded boat setup #208979
04/20/10 04:43 PM
04/20/10 04:43 PM
M
MarkMT
MarkMT
M
I'm getting close to ordering a replacement for my '05 Blade. I'm curious whether there are any new tricks other singlehanded sailors are using in the way their boats are set up to make life easier. e.g. any differences in spinnaker halyard/snuffer/tackline management compared with 2-up sailing? Rotator, downhaul, rudder, daggerboard management?
Re: Singlehanded boat setup [Re: ] #208980
04/20/10 05:23 PM
04/20/10 05:23 PM
I rigged my Viper with a seperate tack/halyard line. The cleat is mounted on the mast, and pulling the halyard on the tramp releases both the tack and the halyard at once. You kinda gotta see it to understand it, or at least I don't feel like typing a book to describe it.
Another thing is my halyard runs mostly under the tramp, there is hardly anything above.
Don't get too trigger happy until you see my boat and take it for a spin.
Re: Singlehanded boat setup [Re: Karl_Brogger] #208988
04/20/10 06:32 PM
04/20/10 06:32 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Karl, what do you do when you get a tangle under the tramp? sounds like an internal down-haul, fine until something goes wrong...
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Singlehanded boat setup [Re: Dazz] #208991
04/20/10 07:08 PM
04/20/10 07:08 PM
Had a few hockles, nothing too serious though, and I think they were to blame from some things being run in a stupid manner, and have since been straightened out.
The tack line has a shockcord spliced into the end of it to keep tension on it at all times, the halyard runs through a pair of rings that are on shockcords that eat up the slack in the halyard. One of the rings is for keeping tension on the righting line, the other is the end of the shockcord for the tack line. Its complicated as hell to setup, (took me damn near an entire day), but pretty simple once you get the picture.
Re: Singlehanded boat setup [Re: Karl_Brogger] #209058
04/21/10 11:27 AM
04/21/10 11:27 AM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Something handy is to run the main sail halyard through 2 holes in the mast at about 1m from the bottom. There the halyard comes out of the mast and a couple of centimeters later goes back in. This enables you to stand at the front beam to rig the sail and still be able to pull downwards at the halyard. Saves time as you don't have to walk back and forth all the time.
Also the daggerboard pull up system installed on the Falcon and Blade is handy (I dont know if your boat had it already).
A seperate tack line is convenient indeed as it gives you time to steer in between the hoist. Same for dousing.
Improvement between the Blade and Falcon is the tramp allowing you to run things below it from the side (I don't know the Viper/Stealth tramp setup). In that way you can run lines to the side stay and then bungee them below the tramp. Clean!
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: Singlehanded boat setup [Re: Gilo] #209067
04/21/10 01:17 PM
04/21/10 01:17 PM
France
pepin Offline
pepin  Offline
France
On my boat the halyard goes down inside the mast track, and exit from it under the boom gooseneck. That's a perfect place to push down on it when standing in front of the beam. I never walk back and forth with this arrangement.
I don't understand this one? One line is definitely simpler, pull one side the spi goes up, uncleat and pull the other side to get it in. Two lines give you twice the chance of a foul, and an additional cleat. I prefer the one line system solo. Duo is another story, separate lines allow the crew to pop the spi faster as it is already partially out before the turn.
Re: Singlehanded boat setup [Re: pepin] #209075
04/21/10 02:32 PM
04/21/10 02:32 PM
Gilo Offline
Gilo  Offline
Pepin,
I find the seperate tack also interesting for single handlers. Especially when dousing in a race at the gate a seperate tack is handy. If you douse the head only the spin cannot get caught below the hull anymore if you have to steer up suddenly.
Ofcourse it takes more time..., but so does a spin below the hull. Ask Mark :-)
Falcon F16 - BEL666
Re: Singlehanded boat setup [Re: Gilo] #209104
04/21/10 06:55 PM
04/21/10 06:55 PM
Its faster to have a seperate tack/halyard. You can pull the tack before the offset/windward mark that way. With the combo system you're pulling a bunch more line.
-The way mine is set up the tack line is cleated with a Spinlock underneath the tramp and mounted on the backside of the front beam. I drilled a hole through the top edge and tied off a piece of tiny line. The other end of the tiny line goes under the tramp and comes out through a grommet where it is tied off to a ring.
-The spinnaker halyard comes down the mast, through a cleat, then down to the front beam where it runs through a eyestrap, then through the ring that is connected to the spinlock. The halyard then goes through a grommet and underneath the tramp where it goes through the two rings attached to bungees, one of which is the tail end of the tackline. Then it comes up through the tramp, then through a block, then through a hole in the tramp, and onto the spinnaker patches. Behind the block, and forward of the grommet where the halyard comes topside is where you grab it for dousing.
When dousing you just pull the halyard from the tramp, it releases the both the tack and the halyard at the same time, or you could grab it at the cleat to leave the tack cleated. All the benifits of the simple dousing combo line, but you can set the tack seperatly.
The bulk of my halyard is just cover/no core as well, with a section of dyneema above the cleat to the head. Its a copy of how Robbie Daniel's boat is setup, he made the halyard/tack line for me as well.
Don't forget that the doubling block can cause issues as well, whether its mounted on the mast, or the spinnaker pole.
Re: Singlehanded boat setup [Re: Karl_Brogger] #209110
04/21/10 08:07 PM
04/21/10 08:07 PM
M
MarkMT
MarkMT
M
Not sure I followed all that, but what I see on p12 of the Viper Tuning Guide seems essentially similar to what I think I'm seeing on Gill's boat -
If I'm not mistaken, I think the red handle on the tramp is attached to the small line connected to the spinlock on the rear of the main beam that you mention - which I think is the same as what the Infusion has.
The separate tack line seems reasonable to me.
Re: Singlehanded boat setup [Re: ] #209119
04/21/10 08:45 PM
04/21/10 08:45 PM
They're showing a cam cleat like the infusion uses, I think that may be a better setup as the Spinlocks are unreliable at best.
Mine is only slightly different from whats in the guide. I think that's how all of the new boats are coming. Mines just an old 09'.....
Re: Singlehanded boat setup [Re: Karl_Brogger] #209143
04/22/10 03:47 AM
04/22/10 03:47 AM
I want to see you do that singlehanded in a contested fleet.
Re: Singlehanded boat setup [Re: Wouter] #209148
04/22/10 05:22 AM
04/22/10 05:22 AM
Mark P Offline
Mark P  Offline
Wouter, you can do it from the wire. You just have your tack line fed to the outside of the front beam and then set parallel to the starboard hull with a bunjee take up. Trust me
I used this system at the UK 2007 Nationals. However, I found it a bit to unreliable especially when you happen to trip the tack whilst gybing!! It's also a bit scary if you get a bit carried away with your new toy and pull the tack out a bit to soon and the spi starts to fill backwards whilst creeping out of the chute prior to the mark rounding. Therefore, I think the double line system suits the two up's better and due to the simplicity of the single line system it benefits the singlehander.
Scooby enjoys tinkering with various elaborate systems I wonder what his preference is?
MP*MULTIHULLS
Re: Singlehanded boat setup [Re: Mark P] #209149
04/22/10 05:44 AM
04/22/10 05:44 AM
Dunedin Causeway, FL
David Parker Offline
AHPC seems to have settled on having a single line halyard/tack system with the head-to-head block up the mast rather than on the spin pole. What are the advantages of the location on the mast?
Re: Singlehanded boat setup [Re: David Parker] #209153
04/22/10 06:03 AM
04/22/10 06:03 AM
France
pepin Offline
pepin  Offline
France
We had a whole discussion a while back about the merits of the various possible single line systems.
Re: Singlehanded boat setup [Re: David Parker] #209157
04/22/10 07:37 AM
04/22/10 07:37 AM
Its the only way you can run a internal tack line, with a combo line.
Re: Singlehanded boat setup [Re: Karl_Brogger] #209161
04/22/10 08:18 AM
04/22/10 08:18 AM
Karl, with your system, have you ever accidently -tripped- the halyard [and tack line] loose with your feet, during a gybe?
Re: Singlehanded boat setup [Re: pepin] #209162
04/22/10 08:19 AM
04/22/10 08:19 AM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
Whatever system you use is mostly a matter of what you are used to.
I sailed always with a single sytem solo and the split system 2-up. After I got used to the split system solo, I much prefer it now.
There are 2 different lines to to pull, but there is less line. The biggest advantage is that you can do the hoiste and the dowse in stages, greatly improving your ability to keep control of the boat when things get bussy.
Re: Singlehanded boat setup [Re: Matt M] #209165
04/22/10 08:27 AM
04/22/10 08:27 AM
Ditto, I've tried it both ways and I prefer two lines both solo and two up. As Gilo said, it keeps the spin from going under the bow if you've got to stop snuffing to steer!
Re: Singlehanded boat setup [Re: Mark P] #209224
04/22/10 01:23 PM
04/22/10 01:23 PM
Single line for me. Just pull and it goes up; juys pull and it comes down....
I do however have some clever stuff on the mast rotation adjustment....
Pull a line on the boom and the rotation is let "fully off". As the kite goes into the bag; it's re-set to the same place it was when it was let "fully off".
Re: Singlehanded boat setup [Re: scooby_simon] #209239
04/22/10 02:06 PM
04/22/10 02:06 PM
pgp Offline
pgp  Offline
Pics?
Pete Pollard
Blade 702
0 registered members (), 20,501 guests, and 1,028 spiders.
Most Online22,490
2 hours ago
