| Re: Infusion rudder tuning
[Re: uogecko]
#213173 06/08/10 08:44 PM 06/08/10 08:44 PM |
Posts: 3,293 Long Beach, California | The other side is exactly the same! Well there's your problem... you have two starboard rudders.
[Re: uogecko]
#213193 06/09/10 01:35 AM 06/09/10 01:35 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | That's that nice Nacra quality. I got some new rudder arms for my Nacra 20 and one was 4 inches longer than the other one! 4 inches! Christ, that's not just a little mistake. I measured them with my existing ones and luckily the longer one was the wrong size and just a simple cut was all that was needed. Do like Dave said and cut your tiller arms a little and re-drill.
Lee
[Re: uogecko]
#213455 06/10/10 01:54 PM 06/10/10 01:54 PM |
Posts: 1,203 uk | Just a thought before you get the hacksaw out.....
Check that you are measuring the toe of the rudders at points front and back of the blades that are parallel to the water line because the rudders are canted
[Re: uogecko]
#213465 06/10/10 03:46 PM 06/10/10 03:46 PM |
Joined: May 2006 Posts: 96 Budapest, Hungary, Europe CatSailingHu
Posts: 96 Budapest, Hungary, Europe | I'm not sure it is the right method, but:
I'm usually strain a small rope or bungee under the crossbeam, and at the middle the distance between the line and crossbeam should be 5-10 mm (the half of the height of the nut)
19,794
guests, and 1,094
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 15 hours ago | | |
