| Synthetic Trapeze Lines #216078 07/19/10 10:53 AM 07/19/10 10:53 AM |
Posts: 129 Austin, TX | I have heard that the F18 class rules now allow the use of synthetic shrouds. Does anyone know if this rule change goes into effect now or in 2011?
Thanks!
Bo Kersey Corsair 31-1D 276 | | | Re: Synthetic Trapeze Lines
[Re: BoK]
#216079 07/19/10 11:15 AM 07/19/10 11:15 AM |
Posts: 3,906 Clermont, FL, USA | The F18 class rules will NOT allow synthetic shrouds. Synthetic trap lines have been proposed and will be voted on December 2010 (next World Council meeting)
Below is from the DRAFT form of the 2010 WC minutes held at Worlds.
5. SCR Class rules review (All). Clarification to current class rules • Bow sprit bridles material : textile material with a minimum diameter of 3mmm is allowed. • The upper mast height point value (8980 mm) in F.3.2 class rules will be deleted. The maximum mast length remain 9100 mm from the beam. • Trapezes cable wires : a proposal including cable and textile with a minimum diameter of 2.5mm for trapeze will be presented to December 10 World Council.
The WC minutes are still in draft form and will be finalized next week. Once I have the final copy in hand I'll send them to the fleet and post it on the NAF18 website.
[Re: David Ingram]
#216090 07/19/10 01:13 PM 07/19/10 01:13 PM |
Posts: 129 Austin, TX | Right... I meant to say trap lines but you anticipated my question.
Hope they pass the synthetic trap line proposal. Sure will make rigging, storing & getting custom lengths done much cheaper and easier.
Thanks!
[Re: David Ingram]
#216122 07/19/10 06:12 PM 07/19/10 06:12 PM |
Posts: 71 | 5. SCR Class rules review (All). Clarification to current class rules • Bow sprit bridles material : textile material with a minimum diameter of 3mmm is allowed. • The upper mast height point value (8980 mm) in F.3.2 class rules will be deleted. The maximum mast length remain 9100 mm from the beam. • Trapezes cable wires : a proposal including cable and textile with a minimum diameter of 2.5mm for trapeze will be presented to December 10 World Council.
I am all for textile trapezes. It would be so much easier to replace them or change the height. I'd even ask to be able to use textiles for the rest of the standing rigging. It doesn't corrode, it's easy to replace, and it doesn't need expensive swaging. Wire, UHMW, and Vectran all cost about $.50 / foot. If the standing rigging wasn't steel, boats could be made without mast corrosion caused by steel and aluminium touching in the presence of salt water. I'd recommend limiting the type of rope to UHWM and vectran, because PBO and carbon fiber are too expensive and difficult to work with. I would rather they did not set the minimum bow sprit bridle to 3mm. It will be hard to enforce because of the difficulty in measuring the thickness of a rope (they compress and are not perfectly smooth). It's not a clarification. It's a new rule. Plus mine are 2.5 mm... | | | Re: Synthetic Trapeze Lines
[Re: F18_VB]
#216134 07/19/10 10:30 PM 07/19/10 10:30 PM |
Posts: 586 Hobart, Tasmania, Oz. | Funny this should come up now, I was going to replace my traplines this winter with dyneema. for club racing who cares, plus they are cheaper and last better.
[Re: maritimesailor]
#216165 07/20/10 09:08 AM 07/20/10 09:08 AM |
Posts: 3,906 Clermont, FL, USA | There is nothing in the WC Meeting minutes referencing GPS aided compasses but the rumor is that it is in the works. I'm not a part of the technical committee (although I do know people) so I don't have the latest and greatest on this issue. If this item is in the works it will probably go up for a vote at the next WC meeting in December.
Now your question regarding wire traps and wire length minimums, no the current rule does not specfically call out trap wire length minimums but if you were called into the room I suspect you would get tossed because the intent of the rule is pretty clear (yes I know, that's easily argued). I also suspect that the class measurer would not find your 1 foot wire trap acceptable and would not sign off on your cert. Of course this is just my opinion. All this is moot anyway, textile traps will in all likelyhood pass easily in December.
[Re: David Ingram]
#216176 07/20/10 10:10 AM 07/20/10 10:10 AM |
Posts: 3,293 Long Beach, California | Hi folks -
Half the reason the synthetic trap lines will be allowed is because the wording of the rules to keep them wire is so tangled - a minimum length of wire was proposed as a rule clarification, but it spun up into something ridiculous in volume so quickly...
The other half is the safety issue. We don't talk about it much, but the drowning death of a young Tornado sailor still casts a pall over any conversation about trap wires.
The Technical Committee recommended to the World Council to drop wires - Greg Goodall is writing the proposal that will, as Dave noted, be voted upon in December. Expect passage as described above - wire or textile trapeze lines of 2.5mm minimum diameter.
I get to write the proposal to allow newer technology on F18s, including Velocitek-type devices like the SpeedPuk. There was significant support around the table since they are already proven to be valuable in training, replaying races, etc. I certainly don't mind hearing input on the proposal or wording for the rule. Expect passage of this rule as well in December.
F18 is seriously vibrant and moving forward. I got a real eye-opener in France.
[Re: John Williams]
#216184 07/20/10 11:05 AM 07/20/10 11:05 AM |
Posts: 120 | John, glad to hear both the safety issue for textile trap wires as well as the "lets stay on the bleading edge" for GPS / Velocitek like gadgets.
On the safety, I have coached 29ers and 420s before and had to jump in the water to help a junior get off the trap, any "newer" style harness that has either the ball and socket or quick release function is okay, but when all else fails its nice to be able to cut the line with a knife, especially with specific "cut yourself proof" knifes available (I have one on my when sailing).
As for GPS, I would word it such that it allows only GPS assisted heading and speed, but specifically disallowing any fixed position referencing (i.e using the GPS to track mark locations).
Grey areas I would foresee: - heading references (i.e you are being knocked or lifted, which a magnetic compas can already tell you, so maybe a null point) - VMG (that is class call, I would disallow, as it leads to more advanced tech) - Fixed positioning / mapping (tracking where marks are relative to you). No Velocitek product can do this (yet), but it is only a matter of time before you have products like Deckman in better form factors then they are now. (FYI Deckman is what "the big boats use" to tell them distance to line, distance to layline, angles between marks, etc after they have inputed them into their nav comp).
We sail with a speedpuck, favourite part of the day / training / is looking at everyone's max speed, adds to the excitement factor (could also be a side prize at regattas). I think they are fantastic and are a step towards making sailing more fun / approachable to sailors and non sailors alike.
Cheers, -Patrick
[Re: John Williams]
#216193 07/20/10 01:03 PM 07/20/10 01:03 PM |
Posts: 297 | Hi folks -
F18 is seriously vibrant and moving forward. I got a real eye-opener in France. John, A few of us in the NE fleet have discussed synthetic lines. With that, is there any procedure that would enable international ad hoc mandate provision to allow synthetic dyneema/synthetic rope trap lines in advance of the official December ruling? It's a long time to wait for a common sense ruling that seems obvious for both safety and performance reasons.
Nacra F18 #856
#216203 07/20/10 02:32 PM 07/20/10 02:32 PM |
Posts: 71 | - Fixed positioning / mapping (tracking where marks are relative to you). No Velocitek product can do this (yet), but it is only a matter of time before you have products like Deckman in better form factors then they are now. (FYI Deckman is what "the big boats use" to tell them distance to line, distance to layline, angles between marks, etc after they have inputed them into their nav comp). Velocitk and Rock Box can both do distance (and time) to the start line. Rock Box can at least do distance and heading to marks maybe to laylines as well. | | | Re: Synthetic Trapeze Lines
[Re: rexdenton]
#216280 07/21/10 05:15 PM 07/21/10 05:15 PM |
Posts: 1,021 Australia | Hi folks -
F18 is seriously vibrant and moving forward. I got a real eye-opener in France. John, A few of us in the NE fleet have discussed synthetic lines. With that, is there any procedure that would enable international ad hoc mandate provision to allow synthetic dyneema/synthetic rope trap lines in advance of the official December ruling? It's a long time to wait for a common sense ruling that seems obvious for both safety and performance reasons. Actually, the rule currently does not specify the length of the wire... So you could have a short wire section at the top (say 20cm) and then the rest could be in dyneema. | | | Re: Synthetic Trapeze Lines
[Re: macca]
#216283 07/21/10 06:21 PM 07/21/10 06:21 PM |
Posts: 3,906 Clermont, FL, USA | Even though the rule does not specify length I doubt it would hold up in the room. It would be pretty clear you're trying to get around a rule.
[Re: David Ingram]
#216286 07/21/10 07:28 PM 07/21/10 07:28 PM |
Posts: 586 Hobart, Tasmania, Oz. | is there an echo in the room????
still would be interesting for some one to do it and see the outcome. I guess it would depend on who is in the room at the time.
[Re: macca]
#216305 07/22/10 06:53 AM 07/22/10 06:53 AM |
Posts: 246 Kiel, Germany | I wonder how the height adjustment might be done, will there be a different system than the one we're using now?
F18: C2 / A-Cat: Minelli
[Re: Baltic]
#217794 08/18/10 07:10 PM 08/18/10 07:10 PM |
Posts: 586 Hobart, Tasmania, Oz. | I finished making mine last weekend, cost $12 per line and 30 mins worth of splicing and measuring.
the weight difference was surprising, now the handle, no miss ring, shackle and line weigh the same as just the wire did.
Baltic, you will use most of the gear you have now, just need a couple of extra shackles at the hounds to stop the chaffing.
[Re: macca]
#219962 09/20/10 07:48 PM 09/20/10 07:48 PM |
Posts: 172 Anacortes | The "room" would not come into it. the ISAF version of the rules requires you to remove the "spirit" clause. So it comes down to the actual wording of the rule and as long as you can show that the trapeze wires are actually composed of wire at some point then you are in the clear.
Would this not be the same for standing rigging? Rule says only that it must be composed of 1x19 or 1x7 wire min dia 3mm. Similar wording to the trap wires. Just asking.
Anacortes Rigging.com Rigging and Yacht Services
[Re: rhodysail]
#220107 09/22/10 06:16 PM 09/22/10 06:16 PM |
Posts: 172 Anacortes | 2.5mm minimum is plenty strong. 3mm if you cant find 2.5. I have 2.5mm Plasma (Spectra similar to DUX) available at 24 cents/foot.
4,636
guests, and 1,000
