| Dart 18 specs #216580 07/28/10 10:42 AM 07/28/10 10:42 AM |
Joined: Sep 2004 Posts: 126 southern Ontario Twister OP
Posts: 126 southern Ontario | Anyone with a Dart 18 know the distance between the center point of the holes for the tiller arm pins on the rudder crossbar? Trying to make a new one. Thanks
Ryan Dart 18 #4860
| | | Re: Dart 18 specs
[Re: Twister]
#216596 07/28/10 06:53 PM 07/28/10 06:53 PM |
Joined: Nov 2001 Posts: 138 Florida, Pnellas, USA dartfast
Posts: 138 Florida, Pnellas, USA | Print DR 250 only states "1950 Max" cross barlength of rod and holes to fit DR 237 pins "to fit assembly". Mine measures bar at 72 5/8 inches with hole centers at 69 5/8 inches.
To firm and minor adjust Stu made two 1.75" long wood dowel inserts with through holes for the pins and slides the dowels inside the cross bar ends and uses a screw to make the dowles firm. Reduces play and wear.
Terry
Terry | | | Re: Dart 18 specs
[Re: dartfast]
#216602 07/28/10 08:16 PM 07/28/10 08:16 PM |
Joined: Apr 2006 Posts: 699 SE Pa. or Chesapeak Bay HMurphey
Posts: 699 SE Pa. or Chesapeak Bay | Hi,
Find Mark Schnieder ..... send him a PM ....
Oh, Mark's origonal sailing nickname .... "Dartman"
And he still has his .....
Harry
| | | Re: Dart 18 specs
[Re: Twister]
#216655 07/29/10 11:23 AM 07/29/10 11:23 AM |
Posts: 1,203 uk | Had a wander around the boat park today, there is usually at least one slacker on a Dart 18 that can't be bothered to take his rudders off. But, wouldn't you know it, no rudders to be seen!
no use - sorry!
| | | Re: Dart 18 specs
[Re: Twister]
#219007 09/08/10 11:34 AM 09/08/10 11:34 AM |
Posts: 126 southern Ontario | Are the backing plates and hardware for the chainplates and bridle attachment points glassed in place from the inside. I am wondering since I am planning on refinishing the hulls and would like to remove these fittings unless they will be difficult to replace.
Ryan Dart 18 #4860
| | | Re: Dart 18 specs
[Re: Smiths_Cat]
#219028 09/08/10 02:29 PM 09/08/10 02:29 PM |
Posts: 126 southern Ontario | Is there anything holding the backing plate and hardware in place, like epoxy? There are no inspection port access, so I dont want to have any hardware dislodge when I remove them.
Ryan Dart 18 #4860
5,791
guests, and 700
