Beach Wheels #216616
07/29/10 03:36 AM
07/29/10 03:36 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
So, one of my beach wheels was a little soft, so I stuck it in the car, drove it to the gas station. The cap hadnt been removed in quite a while, it had corroded onto the brass fitting in the valve stem. I applied a little muscle and ended up twisting the brass fitting in the valve stem out of the valve stem. It actually came out rather easily.
Now I'm wondering if I can glue the brass fitting back in, or if I need a new valve stem.
The gas station couldnt install the valve stem, said I needed to go the tire store.
I will probably end up at the tire store, unless someone has a easy way to fix the valve stem.
Re: Beach Wheels [Re: bvining] #216620
07/29/10 06:40 AM
07/29/10 06:40 AM
I once used contact cement to put one back in and it held for a year until I sold the boat later.
However, an inner tube is the real solution - I think Rick has them here on the site somewhere (they are an odd size).
Re: Beach Wheels [Re: Jake] #216623
07/29/10 07:45 AM
07/29/10 07:45 AM
RickWhite Offline
RickWhite  Offline
Here is the link
https://store.catsailor.com/pc/viewPrd.asp?idproduct=20045&idcategory=0
I had a set of Cat Trax and a set of Euro Trax and both began to lose air on a regular basis. Installed the tubes and they have been fine for a couple of years now.
Rick
Rick White
www.onlinemarinestore.com
Re: Beach Wheels [Re: RickWhite] #216630
07/29/10 08:52 AM
07/29/10 08:52 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
+1 on the tubes from Rick.
Isak Dinesen
E. B. White
Re: Beach Wheels [Re: Team_Cat_Fever] #216646
07/29/10 10:00 AM
07/29/10 10:00 AM
Buzz258 Offline
Buzz258  Offline
I recently paid $5 to have a rubber valve stem installed in a beach wheel.
Buzz
Re: Beach Wheels [Re: bvining] #216647
07/29/10 10:19 AM
07/29/10 10:19 AM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Not worth fixing a broken valve stem - they are about $2 for a new valve from the auto parts store. Flatten the tire (sounds like you already have), break the bead (easy enough by hand on these little suckers, change the valve, reinflate. Remove the valve core to increase air flow and make it easier to reseat the bead. Dish soap on the shoulder of the rim also helps get it to 'grab' and begin pushing the tier up the shoulder. Then put back in the valve core and reinflate to the desired pressure (less than 10 psig I recall)
Inner tubes are not necessary - just make sure the rim and tire bead is clean and smooth. Check for leaks with soapy water and address as required. Looks like two tubes will cost you $60 plus installation vs. $2 for a new valve.
Re: Beach Wheels [Re: flumpmaster] #216676
07/29/10 12:52 PM
07/29/10 12:52 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I was in a fix once with a leaky tire at a regatta. I used goop and put the insert back in. It held for a long time, more than a year, but the best thing is to replace the stem as Flump mentioned.
Re: Beach Wheels [Re: Dan_Delave] #216686
07/29/10 01:39 PM
07/29/10 01:39 PM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
You don't have to break the tire seal on the rim. Cut the old stem off and jam it back into the rim. The use some liquid soap and a screw driver to work the new stem in from the outside. Not easy but can be done. Sometimes easier than breaking the tire seal.
Re: Beach Wheels [Re: orphan] #216687
07/29/10 01:41 PM
07/29/10 01:41 PM
V
Ventucky Red Offline
V
Just did this an breaking the seal is not a big deal. You don't even have to take the tire of the rim to do it either. I tried it both ways, and letting all of the air out of the tire, cutting the stem, breaking the seal, and putting in a new valve was easier to me.
Re: Beach Wheels [Re: Ventucky Red] #216696
07/29/10 02:27 PM
07/29/10 02:27 PM
RickWhite Offline
RickWhite  Offline
Actually, both Cat Trax and Euros have told me that the leakage can also be the rim.., so yes, tubes may be necessary.
Had brand new Cat Trax leak, and it was not the stem.
Rick
Rick White
Re: Beach Wheels [Re: RickWhite] #216747
07/29/10 08:50 PM
07/29/10 08:50 PM
I think I paid $11 each through a local motorcycle dealership. They had to be ordered as it is a really goofy size.
Sorry Rick!
0 registered members (), 1,062 guests, and 43 spiders.
