| Re: Still looking for Condor info
[Re: BrianH64]
#217318 08/08/10 06:14 PM 08/08/10 06:14 PM |
Posts: 3,528 Looking for a Job, I got credi... | Brian
The H49 was a Condor re-branded. I THINK Reg carried over some of the Hurricane/White Formula parts and upgraded the beams to stiffer ones; Some downhaul changes were made (I think) and I this sails were made of Mylar.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Still looking for Condor info
[Re: Cheshirecatman]
#217325 08/09/10 05:24 AM 08/09/10 05:24 AM |
Posts: 1,382 Essex, UK | The differences between the Condor and 4.9 have pretty much been answered. To replace your bowbeam, strut and bridle it's just a case of measuring up. The tube was 6061 aluminium 1.25" dia with a 0.25" wall. The compression strut was 600mm so it's a simple case of a bow beam that goes from bow tang to bow tang (allow an overlap of approx 5mm beyond the tang) slotted to take the tang at each end. A large s/s deck eye is rivetted in the centre of the beam and the compression strut has it's base slotted to allow it to sit over the eye. A bolt then passes through the strut to secure it to the eye on the beam, the bolt also secures a s/s loop to take the tack of the jib. The top of the strut is again slotted but this time to take a 2" dia s/s ring - again retained by a 5mm s/s bolt - which has the bridle wires attached and to which the forestay is tensioned. HTH
PS No, I can't build you any hulls .....
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Still looking for Condor info
[Re: BrianH64]
#217358 08/10/10 07:11 AM 08/10/10 07:11 AM |
Posts: 1,382 Essex, UK | On the early boats (pre 350ish) there were issues with the beam trays (if that's what you are referring to). Later boats were re-inforced in the tray area. Separating deck/hull joins at the beam trays in later boats wasn't an issue that was at all common. The decks are bonded to the hulls via a lip that is approx 1" - 1.5" wide as part of the hull side moulding and held down with a strong resin mixed with microballoons. If a section of deck is coming off it's invariably best to remove the deck and re-stick it than to try and get a paste into the opened crack.
It sounds like you have one of the earlier boats. Post up a pic or two of the damage and we'll see if we can advise.
14,964
guests, and 652
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online16,046 Yesterday at 04:24 PM | | |
