| UV protection for tramps and other fabrics? #218070 08/23/10 10:09 PM 08/23/10 10:09 PM |
Joined: Jun 2001 Posts: 1,911 South Florida & the Keys arbo06 OP
Posts: 1,911 South Florida & the Keys | Is there a product out there other than tarp that can be applied to tramps to protect from UV?
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: UV protection for tramps and other fabrics?
[Re: Karl_Brogger]
#218084 08/24/10 07:53 AM 08/24/10 07:53 AM | andrewscott
| andrewscott
Unregistered | there is a product called 303 High Tech Fabric Guard. i have used their other product on my hulls. it works well but i have never tried the fabric guard. i am sure it works but i am not sure if it is slippery (a very bad thing on a tramp) after applied.
#218179 08/24/10 10:09 PM 08/24/10 10:09 PM |
Posts: 1,911 South Florida & the Keys | Thanks Jake! That was exactly what I was looking for. Problem solved, I'll just build a roof. What is best? Tile, shingle or gravel? What pitch do you suggest for the South Florida weather? I would lean towards hot process but I am open to other methods. Maybe I could use epoxy with carbon frickin fibre attached to 4' lolly columns and 2' rafter sections. Or, spray with the 303 Andrew suggested.
[Re: arbo06]
#218203 08/25/10 08:39 AM 08/25/10 08:39 AM | andrewscott
| andrewscott
Unregistered | Thanks Jake! That was exactly what I was looking for. Problem solved, I'll just build a roof. What is best? Tile, shingle or gravel? What pitch do you suggest for the South Florida weather? I would lean towards hot process but I am open to other methods. Maybe I could use epoxy with carbon frickin fibre attached to 4' lolly columns and 2' rafter sections. Or, spray with the 303 Andrew suggested. I think over time the roof will degrade... better off digging a bunker for it  | | | Re: UV protection for tramps and other fabrics?
[Re: ]
#218303 08/25/10 08:28 PM 08/25/10 08:28 PM |
Posts: 1,911 South Florida & the Keys | Is the bunker cheaper than the 303? I may have to consult Todd on the bunker construction. If I have to build a bunker it is going to have twin 50cal turret on the top.
[Re: Capt_Cardiac]
#218387 08/27/10 07:10 AM 08/27/10 07:10 AM | andrewscott
| andrewscott
Unregistered | I can tell you from first hand knowledge to avoid 303 on the tramp. Althogh it looks GREAT! its slick as snot! No one got hurt but it was 'bambi on ice' for a couple of go rounds. we laughed till our guts wanted to bust. it was so funny watching us slide around. If only i could have grabbed the ring and hooked up as i shot across the tramp. we could have had some 3 sec tacks!!! i'm laughing again thinking about that... you could bring some along to your next race and use it on your buddies tramp was this 303 Aerospace Protectant or the 303 High Tech Fabric Guard? | | |
747
guests, and 291
