Mast rake inter 20 nacra #218937
09/07/10 03:06 PM
09/07/10 03:06 PM
Chesapeake va
C
catsailor2032 Offline OP
C
Chesapeake va
I have an 1998 inter 20. Need to know the best the best mast rake position and how to measure it. Thanks.
Sailing catana411. i20
Re: Mast rake inter 20 nacra [Re: catsailor2032] #218938
09/07/10 03:23 PM
09/07/10 03:23 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
For light to medium wind conditions, I run mine at the top of the transom. For heavier wind, I'll take it back to the top rudder gudgeon.
To measure, untie one of your trapeze lines and attach another length of line to it. Walk to the front of the boat and draw the trap line tight in line with the hull attachment for your bridle wire. Mark that point on the line. Walk the trap wire to the back of the boat and see where that mark falls on the rear of the boat.
Trey
Re: Mast rake inter 20 nacra [Re: NCSUtrey] #218962
09/07/10 11:59 PM
09/07/10 11:59 PM
Will_R Offline
Will_R  Offline
Depends on the conditions. Most I20's I've sailed have shorter shrouds and longer forestay than stock to get more rake. The boat likes it WAY back if it's blowing... like WAY WAY WAY back.
Probably you can put the forestay in the top hole and be good.
Re: Mast rake inter 20 nacra [Re: Will_R] #218976
09/08/10 07:57 AM
09/08/10 07:57 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I'm 1" in front of the transom.
About 3 years ago, a lot of people were raking backwards a lot. People would use double chainplates on the front. I don't see that happening as much anymore from wht I can tell.
I don't rake much at all because I'm heavy as sin usually. I find that the boat is much more powered up with that stick up there. The rudders do like to stall more with the mast up there. You just have to be good about your bear aways.
Re: Mast rake inter 20 nacra [Re: ThunderMuffin] #218995
09/08/10 09:37 AM
09/08/10 09:37 AM
TeamChums Offline
TeamChums  Offline
I run a 3" longer forestay and 1.5 " shorter shrouds. In 20 knots plus, I'll run the forestay in the top hole. If the wind drops, I'm screwed. My measurement usualy is about 20" or so back on the rudder or about halfway down the transom. That's what JC told me to run it when I got it. Maybe I should stand it up a little more since I rarely win any races.
Lee
Re: Mast rake inter 20 nacra [Re: TeamChums] #219945
09/20/10 01:30 PM
09/20/10 01:30 PM
Will_R Offline
Will_R  Offline
You're just not sailing in any regattas with enough wind!!
I remember us raking back even further for the crazy days.
0 registered members (), 2,698 guests, and 788 spiders.
4 hours ago
