| Re: See the F20c in person
[Re: pitchpoledave]
#222239 10/21/10 02:14 AM 10/21/10 02:14 AM |
Posts: 1,021 Australia | Macca can you talk a bit about the development process? On boats that were built prior with curved foils, what didn't work and how are these foils a step forward from prior attempts? I will put a story on the development together in the next day or so. I am on my way to Australia today and i'm sure to have time to write it up on the trip... | | | Re: See the F20c in person
[Re: mikekrantz]
#222240 10/21/10 02:20 AM 10/21/10 02:20 AM |
Posts: 1,021 Australia | I don't have enough time on the boat in heavy air to comment just yet. However, Macca should chime in with some real time experience in those conditions and comparisons. At the moment we have a lot of heavier crews sailing the boat, but Fergie and I are just on 150kg combined and have been sailing a lot on the boat in all sorts of weather. Recently we sailed in Hyeres in full mistal conditions (30-40kts) and despite the terrifying ride we were really happy with the control we had over the boat. As for competitive weight ranges I think in time we will see the weights come down to just above the ideal F18 weight. The hulls can for sure carry more volume than an F18 and the rig is massive when you compare them, but the 3.2m beam is a lot of RM to play with and as such the lighter teams can keep the boat moving even in the big wind. | | | Re: See the F20c in person
[Re: ThunderMuffin]
#222257 10/21/10 07:33 AM 10/21/10 07:33 AM |
Posts: 1,021 Australia | For sure it will handle 200kg crew better than an F18, or I20. Simply due to the larger volume hulls, lifting foils and bigger rig.
As to the best crew weight once we have all worked out how to sail these things at full pace all the time.... We have to wait and see.
[Re: ThunderMuffin]
#222310 10/21/10 03:04 PM 10/21/10 03:04 PM |
Posts: 1,307 Asuncion, Paraguay | The extra width is also needed for the curved boards since the lift forces on the curved boards decrease righting moment via the leward board.
Eh? The leeward board is pushing the hull up, thus increasing RM!!! Yeah but since the board is also curved - some of that force directed upwards at the tip end of the board is going to result in a "torquing" of the hull, meaning that its effectively going to rotate the leward hull outboards.. increasing the amount of capsize moment. You might be right though that the effect of the board lifting overall would equalize the effect of the boat spinning the leward hull outwards. AFAIK, the issue here is the balance between transversal and longitudinal stability. Suppose we start with a traditional 2/1 L/B ratio catamaran, that reaches both stability limits simultaneously at a given wind speed. We can increase its righting moment by making it wider and then it will be able to carry more sail area. However, since its longitudinal stability remained the same, the extra sail area will make it pitchpole earlier then before, so it will not reach the full speed potential of the enlarged sailplan. Lifting foils placed forward of the CG increase the longitudinal stability at speed, solving the problem - granted, at the expense of a fraction of the extra righting moment. Conclusion: keeping hull shapes unchanged, curved foils allow a cat to be wider and to carry more sail area, so it becomes faster then before. Check: the new AC cats have curved foils and their L/B is 1.5:1 Check: the tris with even smaller L/B (1:1) are where curved foils were developed, for they need them badly. Without those foils they reach their longitudinal stability limit a lot earlier than their capsize limit. You certainly remember how the first 1:1 tris were pitchpole prone. Cheers,
Luiz
[Re: macca]
#222317 10/21/10 04:12 PM 10/21/10 04:12 PM |
Posts: 3,528 Looking for a Job, I got credi... | The extra width is also needed for the curved boards since the lift forces on the curved boards decrease righting moment via the leward board.
Eh? The leeward board is pushing the hull up, thus increasing RM!!! reduced RM... look where the COE of the board is in relation to the hull centerline. OK: can understand that once the foils are starting to lift the boat will pivot about (or roughly about) the COE of the board; but is this still true in "non flying modes" as the boat is then pivoting about the leeward hull. I'm no boat builder, just keen to understand this bit that I do not appear to....
Last edited by scooby_simon; 10/21/10 05:50 PM. Reason: getting comments in the right place.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: See the F20c in person
[Re: scooby_simon]
#222348 10/22/10 10:22 AM 10/22/10 10:22 AM |
Erase all this. Lift from the foil replaces part of hull flotation at speed, so righting moment drops with speed simply because the foil's center of lift is more inboard (closer to the mast) than the float. Cheers, Luiz
Luiz
[Re: Luiz]
#222773 10/27/10 08:12 AM 10/27/10 08:12 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Macca, (Kevin) What's the latest? YOu still 'down under'? Speaking for myself, It would be cool if you posted your latest excursion, events, etc. on a regular basis. It would be nice if some of the other 'Rock Stars' would as well. For me, being in WI now, winter is beginning to set in. I did get to do some excellent one design racing in Milwaukee harbor last Sunday. It was nice, even though it was on a Pearson Ensign! http://www.ensignclass.com/images/stories/pdf/EnsignBrochure.pdf
F-18 Infusion #626- SOLD it!
[Re: Luiz]
#223304 11/04/10 10:55 AM 11/04/10 10:55 AM |
Posts: 308 Reno NV |
Cheers, Luiz
This may be a dumb question, but why not have the boards bend the other way (i.e. the tip extending outboard when down)? In other classes there's a max width, but that shouldn't be a problem here. | | | Re: See the F20c in person
[Re: Rhino1302]
#223456 11/06/10 03:49 PM 11/06/10 03:49 PM |
Posts: 932 Solomon's Island, MD | Having not sailed the F20c or any other curved foiled boat, I won't speak to why they placed the boards under the boat from a performance aspect.
I will speak of one good maintenance reason however. If you have a 10.5 ft wide boat sailing along at 25 kts in 20 kts of breeze up the Florida keys, hugging the coast as that is minimum distance, you likely can't see the water very clearly under the leeward hull. Now the keys have lots of these things called shoals, usually made of rock hard coral that will take your boat from 25 kts to 0 kts in about 3 seconds if you hit one. Imagine your curved foil hits one. Now imagine your curved foil sticking outside the boat hitting one. You now have a situation where:
a) you can't even see your foil moving in the water b/c its 11 feet away from you b) your foil hits first as usual, but instead of a blunt impact, which is generally survivable, the entire boat is torquing around a 3 foot moment arm...snap is usually what happens when that kind of load is applied to a thin airfoiled surface.
With the foils under the boat, moments like that are a non-issue, its far far easier to know your full boat width so you can avoid hitting shoals, and more importantly your not worried about touching some F18's $1500 carbon daggerboard with your $1800 curved carbon daggerboard while on the start line. That would just get confusing and dangerous.
Scorpion F18
3,175
guests, and 228
