Mosquito beam extrusion....where to buy ? #223646
11/08/10 11:16 PM
11/08/10 11:16 PM
V
Victor vector Offline OP
V
Hello
I have just bought a new house and an old Mosquito came with it ....
The original alloy beams are badly pitted / corroded , the hulls appear sound.
I would like to replace the beams , but do not know what the section is , or where to order new ones .
Can anyone help with this information please ?
P.S....Forgot to mention........ I`m in Adelaide , South Australia.
Re: Mosquito beam extrusion....where to buy ? [Re: Victor vector] #223648
11/08/10 11:34 PM
11/08/10 11:34 PM
Scarecrow
Scarecrow
Victor where are you? First stop would be here .If Phillip can't help let me know as I'm currently getting the gear together for a new boat and will be getting a set of "custom" beams made up by one of my ali boat building clients. The third option is I have a set of used beams here you can have cheap if you want them. They're off the old wooden boat I just picked up for parts.
Both beams are nominally 50x39 (+/-1) with a minimum wall thickness of 3mm. Most ali suppliers stock a 50x40x3 with square corners. G.James have a 50x40x5 with radius corners but I'm waiting to hear back from them on the radius as your only allowed up to 2mm.
edit: Sorry just noticed your location. Ignore me.
Re: Mosquito beam extrusion....where to buy ? [Re: ] #223653
11/09/10 01:04 AM
11/09/10 01:04 AM
V
V
Wow ! That was quick !
Thank you very much for all the info. Scarecrow.
I have a place to start now.
Much appreciated !
Re: Mosquito beam extrusion....where to buy ? [Re: Victor vector] #223654
11/09/10 01:09 AM
11/09/10 01:09 AM
thricebitten
thricebitten
Hi Victor,
I was able to source Alloy tube to beam specs from the local aluminium fabricator/seller in country Vic. That was the original idea I believe, that the beam was a readily available section not restricted to marine suppliers.
So check the specs from the National Mosquito Website here http://home.vicnet.net.au/~nmcca/documents.htm
look in Building Rules & Restrictions and check your local supplier.
Re: Mosquito beam extrusion....where to buy ? [Re: ] #223660
11/09/10 04:24 AM
11/09/10 04:24 AM
V
V
Thank you thricebitten.
I looked up the rules , it clearly states what is required .I don`t think this will be too difficult after all.
This is a very helpful friendly group.
Re: Mosquito beam extrusion....where to buy ? [Re: Victor vector] #223666
11/09/10 06:49 AM
11/09/10 06:49 AM
Simon_Hallsworth Offline
Hi Victor,
The SA Mossie Association have beams in stock for $40 each for members - hint hint smile
If you are interested in assistance any of us in the association will be more than happy to help. All of our details are on the MCASA website at http://www.mossie.org.au.
Cheers,
Simon
Re: Mosquito beam extrusion....where to buy ? [Re: Simon_Hallsworth] #226892
01/17/11 02:41 AM
01/17/11 02:41 AM
whitney01 Offline
whitney01  Offline
There the experts here already advice you what to do.. Hope your problem is okay now.
Glass Urns
