| Sticker Crud #223987 11/12/10 03:08 PM 11/12/10 03:08 PM |
Posts: 1,403 | Any recommendations for getting the sticky crud off that is usually left behind by stickers on the hull.
I use to use Goo Off in the past, but looking for something that is less toxic. Got a lot of stickers to remove.
Thanks
| | | Re: Sticker Crud
[Re: Ventucky Red]
#223988 11/12/10 03:12 PM 11/12/10 03:12 PM |
Posts: 271 Atlanta, Ga | I put goo off over the decals and heated it up a bit. They peeled off smoothly and left minimal residue. | | | Re: Sticker Crud
[Re: BLR_0719]
#223989 11/12/10 03:21 PM 11/12/10 03:21 PM |
Posts: 3,293 Long Beach, California | Goo-Gone gel in the squirt bottle. Let it sit for a bit and use a hard plastic squeegee. Works great.
| | | Re: Sticker Crud
[Re: Ventucky Red]
#223990 11/12/10 03:45 PM 11/12/10 03:45 PM |
Posts: 12,310 South Carolina | A citrus based cleaner will work well too (very similar to goo-gone). gentle heat will loosen as mentioned above.
Denatured alcohol will work slowwwwly. Acentone will work quiiiikly. Goo-gone is somewhere in the middle but probably more mild than either from a chemical standpoint.
Jake Kohl | | | Re: Sticker Crud
#223997 11/12/10 04:31 PM 11/12/10 04:31 PM |
Posts: 3,224 Roanoke Island ,N.C. | Xylene. It's the main ingredient in 3m Vinyl/Decal remover( which is great but expensive).
| | | Re: Sticker Crud
[Re: Ventucky Red]
#224003 11/12/10 05:39 PM 11/12/10 05:39 PM |
Posts: 921 Alachua, FL | Any recommendations for getting the sticky crud off that is usually left behind by stickers on the hull.
Thanks Basically you have two choices...toxic or not. The more toxic, the better and faster it will work. If want want to be totally "green" you will just have to live with sticker gooo. I am 66 years old and have been using acetone and similar solvents all my life and I am still here...caugh, caugh, hack. The main thing we have learned is to use these solvents with respect, in good ventilation and perhaps with gloves. The sailing we do is more risky than the chemicals we use (IMHO) Just be careful out there.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Sticker Crud
[Re: Matt_Z]
#224006 11/12/10 07:01 PM 11/12/10 07:01 PM |
Posts: 1,403 | Don't know if it meets your toxicity requirement, but regular lighter fluid that you put in a zippo type lighter will get rid of it in an instant. Cheap too. Don't think I'd use it on a sail, just on the hull. I have actually seen this in action, but you need to clean it off real fast or it will hurt your gelcoat - so I have been told. | | | Re: Sticker Crud
[Re: Ventucky Red]
#224016 11/12/10 08:25 PM 11/12/10 08:25 PM |
Posts: 1,187 38.912, -95.37 | based on lots of experience is with old stickers, Acetone wins...hands down but use in a well ventilated areaI apply it without gloves What happens when acetone comes into contact with my skin?
Acetone is either slightly irritating or not irritating, based on animal and limited human information. Application of 1 mL of acetone in a small glass tube to six male volunteers for 30 or 90 minutes resulted in only mild redness and swelling at 90 minutes
| | | Re: Sticker Crud
[Re: _flatlander_]
#224022 11/12/10 10:35 PM 11/12/10 10:35 PM |
Posts: 833 St. Louis, MO, | You all are wrong. MEK is the best. But wear nitril gloves and have good venelation. It will melt about anything including your liver.
Mike Hill N20 #1005
| | | Re: Sticker Crud
[Re: Ventucky Red]
#224023 11/12/10 10:38 PM 11/12/10 10:38 PM |
Joined: Jan 2004 Posts: 216 Lakewood, Colorado MUST429
Posts: 216 Lakewood, Colorado | Any recommendations for getting the sticky crud off that is usually left behind by stickers on the hull.
Thanks I cannot believe it has not yet been said, Buckets and Buckets of Acetone ! ! !
Life is not about waiting for the storms to pass... It's about learning to dance in the rain
| | | Re: Sticker Crud
[Re: Ventucky Red]
#224063 11/13/10 07:07 PM 11/13/10 07:07 PM |
Posts: 921 Alachua, FL | I use to use Goo Off in the past, but looking for something that is less toxic. Thanks The only thing less toxic than Goo Off is water. Good luck. Man up...acetone or MEK.
[Re: hobiephil]
#224087 11/14/10 07:49 AM 11/14/10 07:49 AM |
Posts: 2,844 42.904444 N; 88.008586 W | There is a completely non-toxic AND effective way to remove stickers or decals from you hulls. It's an eraser that fits in an electric drill. It looks like a grinding wheel except it's made of rubber. Leaves no residue or marks. An eraser? Sounds Elementary to me! ;-)
F-18 Infusion #626- SOLD it!
| | | Re: Sticker Crud
[Re: hobiephil]
#224098 11/14/10 10:41 AM 11/14/10 10:41 AM |
Posts: 12,310 South Carolina | There is a completely non-toxic AND effective way to remove stickers or decals from you hulls. It's an eraser that fits in an electric drill. It looks like a grinding wheel except it's made of rubber. Leaves no residue or marks. I've got one but it doesn't work well on old crusty graphics.
[Re: MUST429]
#224100 11/14/10 10:51 AM 11/14/10 10:51 AM |
Thanks I cannot believe it has not yet been said, Buckets and Buckets of Acetone ! ! ! That only works on sails! I got lucky this time out and the stickers came off pretty easy. I had went to the old stand by Goof Off, applied a generous amount of Goof Off using some old towels, turned the hull so it was facing into the sun for about an hour, came back with a razor blade and a plastic paint scraper and presto they came right off. Thanks for the help, appreciate it | | |
1 registered members (FredL),
2,799
guests, and 283
