Sticker Crud #223987
11/12/10 03:08 PM
11/12/10 03:08 PM
V
Ventucky Red Offline OP
V
Any recommendations for getting the sticky crud off that is usually left behind by stickers on the hull.
I use to use Goo Off in the past, but looking for something that is less toxic. Got a lot of stickers to remove.
Thanks
Re: Sticker Crud [Re: Ventucky Red] #223988
11/12/10 03:12 PM
11/12/10 03:12 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
I put goo off over the decals and heated it up a bit. They peeled off smoothly and left minimal residue.
Re: Sticker Crud [Re: BLR_0719] #223989
11/12/10 03:21 PM
11/12/10 03:21 PM
Goo-Gone gel in the squirt bottle. Let it sit for a bit and use a hard plastic squeegee. Works great.
Re: Sticker Crud [Re: Ventucky Red] #223990
11/12/10 03:45 PM
11/12/10 03:45 PM
A citrus based cleaner will work well too (very similar to goo-gone). gentle heat will loosen as mentioned above.
Denatured alcohol will work slowwwwly. Acentone will work quiiiikly. Goo-gone is somewhere in the middle but probably more mild than either from a chemical standpoint.
Re: Sticker Crud [Re: Jake] #223994
11/12/10 04:22 PM
11/12/10 04:22 PM
brucat Offline
brucat  Offline
I've also used Goo-Gone. Works great, but takes some time (as mentioned).
I've heard that a hair dryer or heat gun can also help (heat the vinyl as you remove it, most of the glue should come with it).
Re: Sticker Crud [Re: brucat] #223995
11/12/10 04:23 PM
11/12/10 04:23 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Goof-off in the spray can. Add Heat gun. Rinse Repeat. I just took all the stickers off my hull and its quite a chore.
Re: Sticker Crud [Re: Jake] #223997
11/12/10 04:31 PM
11/12/10 04:31 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Xylene. It's the main ingredient in 3m Vinyl/Decal remover( which is great but expensive).
Isak Dinesen
E. B. White
Re: Sticker Crud [Re: Ventucky Red] #224003
11/12/10 05:39 PM
11/12/10 05:39 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Thanks
Basically you have two choices...toxic or not.
The more toxic, the better and faster it will work.
If want want to be totally "green" you will just have to live with sticker gooo.
I am 66 years old and have been using acetone and similar solvents all my life and I am still here...caugh, caugh, hack.
The main thing we have learned is to use these solvents with respect, in good ventilation and perhaps with gloves.
The sailing we do is more risky than the chemicals we use (IMHO)
Just be careful out there.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Sticker Crud [Re: Ventucky Red] #224004
11/12/10 05:54 PM
11/12/10 05:54 PM
Lake Norman. NC
M
Matt_Z Offline
Matt_Z  Offline
M
Lake Norman. NC
Don't know if it meets your toxicity requirement, but regular lighter fluid that you put in a zippo type lighter will get rid of it in an instant. Cheap too.
Don't think I'd use it on a sail, just on the hull.
Re: Sticker Crud [Re: Matt_Z] #224006
11/12/10 07:01 PM
11/12/10 07:01 PM
V
V
I have actually seen this in action, but you need to clean it off real fast or it will hurt your gelcoat - so I have been told.
Re: Sticker Crud [Re: Ventucky Red] #224016
11/12/10 08:25 PM
11/12/10 08:25 PM
based on lots of experience is with old stickers, Acetone wins...hands down
but use in a well ventilated area
I apply it without gloves
What happens when acetone comes into contact with my skin?
Acetone is either slightly irritating or not irritating, based on animal and limited human information. Application of 1 mL of acetone in a small glass tube to six male volunteers for 30 or 90 minutes resulted in only mild redness and swelling at 90 minutes
Re: Sticker Crud [Re: _flatlander_] #224022
11/12/10 10:35 PM
11/12/10 10:35 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
You all are wrong. MEK is the best. But wear nitril gloves and have good venelation. It will melt about anything including your liver.
Mike Hill
N20 #1005
Re: Sticker Crud [Re: Ventucky Red] #224023
11/12/10 10:38 PM
11/12/10 10:38 PM
Lakewood, Colorado
MUST429 Offline
MUST429  Offline
Lakewood, Colorado
Thanks
I cannot believe it has not yet been said,
Buckets and Buckets of Acetone ! ! !
Life is not about waiting for the storms to pass...
It's about learning to dance in the rain
Re: Sticker Crud [Re: Ventucky Red] #224063
11/13/10 07:07 PM
11/13/10 07:07 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
I use to use Goo Off in the past, but looking for something that is less toxic. Thanks
The only thing less toxic than Goo Off is water. Good luck.
Man up...acetone or MEK.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Sticker Crud [Re: Mugrace72] #224070
11/13/10 09:07 PM
11/13/10 09:07 PM
Dunedin Causeway, FL
hobiephil Offline
hobiephil  Offline
There is a completely non-toxic AND effective way to remove stickers or decals from you hulls. It's an eraser that fits in an electric drill. It looks like a grinding wheel except it's made of rubber. Leaves no residue or marks.
Re: Sticker Crud [Re: hobiephil] #224071
11/13/10 09:48 PM
11/13/10 09:48 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Yeah, my bodyman showed me that, and it works amazingly well.
Dave
Re: Sticker Crud [Re: hobiephil] #224087
11/14/10 07:49 AM
11/14/10 07:49 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
An eraser?
Sounds Elementary to me!
F-18 Infusion
#626- SOLD it!
Re: Sticker Crud [Re: hobiephil] #224098
11/14/10 10:41 AM
11/14/10 10:41 AM
I've got one but it doesn't work well on old crusty graphics.
Re: Sticker Crud [Re: MUST429] #224100
11/14/10 10:51 AM
11/14/10 10:51 AM
V
V
Thanks
That only works on sails!
I got lucky this time out and the stickers came off pretty easy. I had went to the old stand by Goof Off, applied a generous amount of Goof Off using some old towels, turned the hull so it was facing into the sun for about an hour, came back with a razor blade and a plastic paint scraper and presto they came right off.
Thanks for the help, appreciate it
Re: Sticker Crud [Re: Ventucky Red] #224106
11/14/10 12:11 PM
11/14/10 12:11 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
PETROL
0 registered members (), 16,525 guests, and 861 spiders.
Most Online22,490
Yesterday at 08:14 AM
