New F16 #225505
12/16/10 09:27 AM
12/16/10 09:27 AM
France
pepin Offline OP
pepin  Offline OP
France
Socoabeach (Web site is a little bare at the moment) has the design for a new F16 all ready, production is planned to start next year.
Socoabeach is not a commercial enterprise, it is a non-profit in regard to French law. You have to be a member to gain access to boats, I'm curious to know how it's going to work in practice.
002e F16 persp4.jpg (931 downloads)
Rear view
Re: New F16 [Re: pepin] #225508
12/16/10 09:49 AM
12/16/10 09:49 AM
What is the angle of those daggerboards? Looks like they are outside class spec?
Re: New F16 [Re: pepin] #225509
12/16/10 09:50 AM
12/16/10 09:50 AM
Live in Germany, House in UK, ...
DanTnz Offline
DanTnz  Offline
Interesting design and concept.
Is that much centreboard cant legal? I thought the boards couldn't go outside max beam (assuming the cat is at max legal beam) when raised. Can't find the exact rule though, but assume it comes under the box rule paragraph.
Re: New F16 [Re: DanTnz] #225517
12/16/10 11:45 AM
12/16/10 11:45 AM
7.5 Overall width of the platform
The overall width of a platform corresponds with the horizontal distance between the verticals passing
through the extremities of the sides of the platform, with the boat being levelled on its waterline and
excluding protruding dagger boards, rudder blades or tiller bars. When wings are being used than the equivalent overall beam is determined by measuring the overall width including only one fully extended
wing.
7.13 Daggerboard and Centreboards
All lift producing elements that have as their dominant purpose to resist sideways movement of the craft
while sailing and of which no part is canted at a greater angle than 6 degrees off the vertical when the boat is level on the waterline.
Re: New F16 [Re: Jalani] #225635
12/18/10 01:24 PM
12/18/10 01:24 PM
Mike Fahle Offline
Mike Fahle  Offline
Hi John,
I saw the new design from Germany in another post and wondered if you could take a skeg design like that one and also have highly canted boards to produce vertical lift w/o breaking the rules.
Re: New F16 [Re: Mike Fahle] #225643
12/18/10 03:09 PM
12/18/10 03:09 PM
Yes you could but max cant would still be 6 degrees off vertical.
The rules state that there will be only 1 dagger/centreboard per hull and also ban horizontal underwater appendages so the skeg in addition to a board should be OK.
Re: New F16 [Re: Jalani] #225674
12/20/10 03:53 AM
12/20/10 03:53 AM
C
Catfan Offline
Catfan  Offline
C
Where can I find the rules you mentioned?
They are not in the Box rule on the official F16 web site (http://www.formula16.net/content/view/13/36/lang,it/)
Re: New F16 [Re: Catfan] #225675
12/20/10 04:35 AM
12/20/10 04:35 AM
You have to look at both the rules and the definitions.
http://www.formula16.net/content/view/13/36/lang,en/
http://www.formula16.net/content/view/17/39/lang,en/
Re: New F16 [Re: Rolf_Nilsen] #225880
12/24/10 03:00 PM
12/24/10 03:00 PM
FL
sail7seas Offline
sail7seas  Offline
FL
On the subject of innovative design, check out the bows of this Cat.
http://forums.sailinganarchy.com/in...p;pid=3103815&st=0&#entry3103815
Re: New F16 [Re: sail7seas] #225893
12/26/10 07:14 AM
12/26/10 07:14 AM
Brett Goodall Offline
the holes???anti drag??? I think it has more to do with beach mobility... exactly the same as the same as the handles molded into the transom of this boat.
if you believe the golf ball dimple theory I think you should go back to your first year engineering books. Sorry to sound like an butt but I like to see people innovate not bullsh^*t...
I do love being proven wrong though... it meams i can learn something!!!
Re: New F16 [Re: sail7seas] #225894
12/26/10 07:15 AM
12/26/10 07:15 AM
Re: New F16 [Re: Brett Goodall] #225931
12/27/10 02:37 PM
12/27/10 02:37 PM
Maryland
Kris Hathaway Offline
Maryland
Makes it lighter
Kris Hathaway
Re: New F16 [Re: Kris Hathaway] #225944
12/27/10 07:25 PM
12/27/10 07:25 PM
wink
Re: New F16 [Re: Brett Goodall] #225958
12/28/10 07:05 AM
12/28/10 07:05 AM
waynemarlow Offline
waynemarlow  Offline
Rumour has it that the designed 2.5cm hole for the future spinaker pole guy wire, was mis translated to 2.5 inches in the mould cut out. wink
0 registered members (), 20,577 guests, and 826 spiders.
Most Online22,490
Yesterday at 08:14 AM
