| Re: Square top sails
[Re: Lost in Translation]
#227653 01/27/11 02:22 PM 01/27/11 02:22 PM |
Posts: 2,490 On the Water | I believe Kirk at Key Sailing now has the two test kites for new development. Trey and I had them at an event at Nigel's in the late fall but they were rigged for end pole snuffer so that we couldn't try them. We put one up in the parking lot and noticed the luff was significantly shorter. Hard to see a lot else without any wind. Should be a lot easier on the spin poles though by not requiring as much pre-bend.
I believe the new kite is coming out soon but don't know the dates. I've asked Trey to give an update. "Rumor" has it that the "test kites" were simply NOS spins sent out, hence the patches for end pole. Why would an updated spin under development be patched for end pole? The kite, main, jib that Kirk has is for the aluminum rig, which has a spin hound lower than the carbon rigs. They are beautiful sails. The aluminum rig provided jib was used at Tradewinds on a carbon rig with the aftermarket main.
Philip USA #1006 | | | Re: Square top sails
[Re: P.M.]
#227680 01/27/11 10:03 PM 01/27/11 10:03 PM |
Posts: 1,459 Annapolis,MD | I believe Kirk at Key Sailing now has the two test kites for new development. Trey and I had them at an event at Nigel's in the late fall but they were rigged for end pole snuffer so that we couldn't try them. We put one up in the parking lot and noticed the luff was significantly shorter. Hard to see a lot else without any wind. Should be a lot easier on the spin poles though by not requiring as much pre-bend.
I believe the new kite is coming out soon but don't know the dates. I've asked Trey to give an update. "Rumor" has it that the "test kites" were simply NOS spins sent out, hence the patches for end pole. Why would an updated spin under development be patched for end pole? The kite, main, jib that Kirk has is for the aluminum rig, which has a spin hound lower than the carbon rigs. They are beautiful sails. The aluminum rig provided jib was used at Tradewinds on a carbon rig with the aftermarket main. In my experience you can get a significantly shorter (or longer) luff just buying one of the old sails. In my uneducated sail making knowledge, I had always believed that in modern spins a longer luff gave you more power (even if sail area was equal or slightly less). Will they come up with two spins, one for the aluminum rig and one for the carbon? | | | Re: Square top sails
[Re: Devon]
#227743 01/28/11 11:10 PM 01/28/11 11:10 PM |
Posts: 110 | | | | Re: Square top sails
[Re: Devon]
#227755 01/29/11 10:38 AM 01/29/11 10:38 AM |
Posts: 3,224 Roanoke Island ,N.C. | Talking about pitch poles, here`s mine as close as you can get last week Australia day..That tested the mast...http://www.youtube.com/watch?v=s4DDilL4SNY Didnt mean to laugh at the crew so much but this was really funny, thanks to Alex on a jet ski and a steady hand.. Nice recovery on the crew's part. You should sell tickets for that ride.
[Re: P.M.]
#227762 01/29/11 02:43 PM 01/29/11 02:43 PM |
Posts: 829 Charleston, SC | I believe Kirk at Key Sailing now has the two test kites for new development. Trey and I had them at an event at Nigel's in the late fall but they were rigged for end pole snuffer so that we couldn't try them. We put one up in the parking lot and noticed the luff was significantly shorter. Hard to see a lot else without any wind. Should be a lot easier on the spin poles though by not requiring as much pre-bend.
I believe the new kite is coming out soon but don't know the dates. I've asked Trey to give an update. "Rumor" has it that the "test kites" were simply NOS spins sent out, hence the patches for end pole. Why would an updated spin under development be patched for end pole? The kite, main, jib that Kirk has is for the aluminum rig, which has a spin hound lower than the carbon rigs. They are beautiful sails. The aluminum rig provided jib was used at Tradewinds on a carbon rig with the aftermarket main. MummP-Rumors are just that, rumors. You asked this specific question at Tradewinds and I told you the answer. The test chutes were endpole setups because the test boat at E/P has an endpole system. Most of the N20's in CA are still endpole setups. The new spinnaker is coming out this quarter and will hopefully be available by the end of February. When I have a hard date for the release, I'll be sure to post it on Catsailor. If all goes well, the new main and jib will be out first quarter of 2012, potentially last quarter of this year. My email address is: velocitytrey (at) gmail.com. Anyone feel free to email me if you have questions regarding the N20 and I'll make sure you have the honest answer, no rumors here. So what are you guys with open sails going to do when the updated E/P sails beat you around the course?  I love this boat!
Trey
[Re: NCSUtrey]
#227773 01/29/11 07:08 PM 01/29/11 07:08 PM |
Posts: 2,921 Michigan | So what are you guys with open sails going to do when the updated E/P sails beat you around the course? hell, the original ones already do!! Zombies rule!!! | | | Re: Square top sails
[Re: Devon]
#227785 01/30/11 03:53 AM 01/30/11 03:53 AM |
Posts: 1,383 Kingston SE South Australia | Don't think you would have saved that pitchpole with a square top. you definately need a camera
[Re: ]
#227788 01/30/11 08:55 AM 01/30/11 08:55 AM |
Posts: 364 | Working out how big a head can go is easy. You keep making it bigger until the mast breaks. Then make it a little smaller!
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: NCSUtrey]
#227803 01/30/11 05:43 PM 01/30/11 05:43 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | My email address is: velocitytrey (at) gmail.com. Anyone feel free to email me if you have questions regarding the N20 and I'll make sure you have the honest answer, no rumors here.
How about just updating us on the Nacra 20 class e-mail group? You testing the new ones is a signifigant thing we would like to hear about. As our "class president" I was hoping you'd keep us informed.
Lee
[Re: TeamChums]
#227840 01/31/11 02:04 PM 01/31/11 02:04 PM |
Posts: 1,403 | How about just updating us on the Nacra 20 class e-mail group? How can I join? | | | Re: Square top sails
[Re: Ventucky Red]
#227848 01/31/11 02:35 PM 01/31/11 02:35 PM |
Posts: 3,224 Roanoke Island ,N.C. | How about just updating us on the Nacra 20 class e-mail group? How can I join? PM me your Email address and I'll send you an invite. Unfortunately it doesn't get much use.
[Re: Team_Cat_Fever]
#227854 01/31/11 02:50 PM 01/31/11 02:50 PM |
Posts: 829 Charleston, SC | Todd, weren't you the originator of the group? If I understand the google group thing correctly, only the person that started it can add people in. I may be wrong though.
Lee- what do you mean by 're-cut custom ones?'
Trey
2,796
guests, and 637
