P19 MX pole #22762
08/01/03 05:09 PM
08/01/03 05:09 PM
Flagstaff, Arizona
Dennis Offline OP
Dennis  Offline OP
Flagstaff, Arizona
It looks like I'm going to have to build an MX pole for my P19.
Does anyone have the dimensions? I was thinking 1/2 inch aluminum pole .010 wall. Also using 3/32 spectra for the side supports rather than 1/16 wire.
Too thick or thin? Has anyone broken one of these?
Any other suggestions for a 'best' setup?
Re: P19 MX pole [Re: Dennis] #22763
08/03/03 02:05 AM
08/03/03 02:05 AM
E
elgreengo Offline
elgreengo  Offline
E
check out this guy's website, he knows more than me... http://www.whitecaps.net/
Re: P19 MX pole [Re: elgreengo] #22764
08/04/03 11:00 AM
08/04/03 11:00 AM
Flagstaff, Arizona
Dennis Offline OP
Dennis  Offline OP
Flagstaff, Arizona
Thanks, Gringo. Anyone else have info or pictures I could use?
Re: P19 MX pole [Re: Dennis] #22765
08/11/03 08:16 PM
08/11/03 08:16 PM
Flagstaff, Arizona
Dennis Offline OP
Dennis  Offline OP
Flagstaff, Arizona
Anyone?
Re: P19 MX pole [Re: Dennis] #22766
08/12/03 03:40 PM
08/12/03 03:40 PM
jdr Offline
jdr  Offline
My MX pole is 6 feet of 1 1/4" OD alluminum tubing.
the attachment to the bridle is 26" (cut at an angle) of 5/8" alluminum tubing.
Rope or wire will work (I use rope)
Never heard of one breaking from usage.
Re: P19 MX pole [Re: jdr] #22767
08/12/03 06:45 PM
08/12/03 06:45 PM
is that a spinnaker pole or does it stop at the bridle just for the jib? My 6.0NA pole is 13.5' long and pretty standard.
Re: P19 MX pole [Re: jdr] #22768
08/12/03 06:58 PM
08/12/03 06:58 PM
Flagstaff, Arizona
Dennis Offline OP
Dennis  Offline OP
Flagstaff, Arizona
Thank you so much! I'm almost ready to order materials. If there are any pictures of the joints out there, I would use them.
Re: P19 MX pole [Re: Jake] #22769
08/12/03 07:00 PM
08/12/03 07:00 PM
Flagstaff, Arizona
Dennis Offline OP
Dennis  Offline OP
Flagstaff, Arizona
The pole stops below the bridles, and then angles up at the same rake as the forestay.
Re: P19 MX pole [Re: Dennis] #22770
08/13/03 05:16 AM
08/13/03 05:16 AM
Crystal Beach/Dunedin CSWY Fl.
catsailorp19mx Offline
Hi Dennis,
Just saw your post. I'll take a photo of mine this afternoon when I get home, and post it for you.
Dave
Re: P19 MX pole [Re: Dennis] #22771
08/13/03 12:23 PM
08/13/03 12:23 PM
Hi Dennis,
Hope these pole pics help. Horizontal pole is 71 3/4" long,
vertical (not exactly vertical) is 25 1/4" long. Small pole is attached to large pole with bracket, pin and ring. Small pole is cut at an angle that relects the angle of the forestay. Small pole is attached (with metal tab) to a shackle that captures the bridle wire thimbles. I mounted small blocks for a downhaul system. I am happy with using aircraft cable with turnbuckles that are secured at the hull attachment for the bridle wires. Easy on, easy off with minimal stretch.
Lets try the pics,
Dave
23326-MX pole1.JPG (82 downloads)
Re: P19 MX pole [Re: catsailorp19mx] #22772
08/13/03 12:25 PM
08/13/03 12:25 PM
Sorry,
I don't know how to post multiple pics, so I'll do them in separate posts.
23327-MX pole2.JPG (63 downloads)
Re: P19 MX pole [Re: catsailorp19mx] #22773
08/13/03 12:27 PM
08/13/03 12:27 PM
Third pic out of 5.
23328-MX pole3.JPG (54 downloads)
Re: P19 MX pole [Re: catsailorp19mx] #22774
08/13/03 12:29 PM
08/13/03 12:29 PM
Four of 5
23329-MX pole4.JPG (49 downloads)
Re: P19 MX pole [Re: catsailorp19mx] #22775
08/13/03 12:33 PM
08/13/03 12:33 PM
O.K. Dennis,
This is the last one. Not being a photographer, I probably didn't do that good of a job. But, I hope that it will be of some benefit to you. I don't know the sizes, but I have never had any problems with this pole in the two years that I've owned it.
Dave
23330-MX pole5.JPG (52 downloads)
Re: P19 MX pole [Re: catsailorp19mx] #22776
08/13/03 12:48 PM
08/13/03 12:48 PM
Oooops....
Thought I'd get one that gives you a better look at the end of the pole.
Dave
23332-MX pole6.JPG (46 downloads)
Re: P19 MX pole [Re: catsailorp19mx] #22777
08/13/03 12:51 PM
08/13/03 12:51 PM
Flagstaff, Arizona
Dennis Offline OP
Dennis  Offline OP
Flagstaff, Arizona
Awesome! That's everything I need to get it done. Thanks, Dave! I hope I can return the favor somehow. Our "long distance" race is in Rocky Point, Mexico on October 18. About 25 miles total. Several P19mx expected. Some may need crew. See Fleet42.com if you're available.
Thanks again, Dennis
Re: P19 MX pole [Re: Dennis] #22778
08/13/03 01:13 PM
08/13/03 01:13 PM
You are more than welcome, Dennis. I would LOVE to take you up on the Mexico race, but it IS a fair distance from Florida. If you are ever in the Clearwater area of Florida, drop me a line, and we can go Gulf sailing. We live right next to a beautiful beach launch area, and can be in the Gulf in a few minutes. Dunedin Causeway is a very active cat sailing area. YEAR ROUND!!May I ask what you were using for a pole up to now? Attached is a pic where we raced into a bad storm. OOOOOWWWEEEE!!
Dave
www.lifespanfitness.us
23335-Stormy race.JPG (53 downloads)
0 registered members (), 2,533 guests, and 195 spiders.
