| Spin trim help #230097 03/22/11 08:20 AM 03/22/11 08:20 AM |
Posts: 186 Chattanooga, TN | Joanna and I have noticed that since we have been running the goodall spin that we seem to have a very fine area where it is flying and that it seems to need to be tight most of the time. Does any one have a suggestion of any adjustments we can look at making to let it fill out some more or is this what others are finding with this spin?
thanks
Jody
Blade F16 724
Plays with Sharp Objects
| | | Re: Spin trim help
[Re: PTP]
#230188 03/23/11 07:54 PM 03/23/11 07:54 PM |
Posts: 404 Chattanooga, TN | Gill- I have issues at all the wind speeds. Feel like I have to pull it in very tight to keep it flying correctly. Have checked luff, seemed fine, but will do that again. The Glaser spin seemed to have a much larger "range", or easier to keep flying. Will also check the sheeting angles next time we are out. I noticed the difference btw the two from the start.
Joanna
Blade F16 "Too Sharp to Touch" | | | Re: Spin trim help
[Re: PTP]
#230196 03/23/11 11:48 PM 03/23/11 11:48 PM | Scarecrow
| Scarecrow
Unregistered | you should play with the sheeting angle in the smae way you do with a jib. ie fwd to flatten the top of the sail and/or add shape down low or aft to add shape up high or flatten down low. put some wools on your kite it will make all the difference. | | | Re: Spin trim help
[Re: ]
#230202 03/24/11 05:33 AM 03/24/11 05:33 AM |
Posts: 404 Chattanooga, TN | "wools" is that the same as "tell tails"?
Joanna
[Re: Joanna]
#230204 03/24/11 07:11 AM 03/24/11 07:11 AM |
Posts: 118 Pensacola, FL | Joanna, I think the luff on the Goodall spin is a little shorter, 6-8 inches. I remember that you guys moved the block on your mast down when you made the change. I moved the pole a little higher because I was sailing uni and not using the pelican striker. Mine seems to work fine, the same as the Glaser. The vipers carry their spin pole higher than the blades. Maybe that has shifted your sheeting angle a little?
Chris Trident F16
| | | Re: Spin trim help
[Re: Cab]
#230207 03/24/11 07:43 AM 03/24/11 07:43 AM |
Posts: 186 Chattanooga, TN | So by lowering the spin we would have to move the sheeting angle forward I guess? Is there any special backing for the spin blocks if I move them forward? I do think you are probably right one that Chris since we moved the Goodall job tack up a few inches the boat seems to be pointing and performing better. Also makes more sense on the lower part of the jib near the foot of the main where more power can be used (I think that is right). So to move the spin pole up some I assume we need a shorter pelican striker?
Jody
Blade F16 724
| | | Re: Spin trim help
[Re: Joanna]
#230209 03/24/11 08:01 AM 03/24/11 08:01 AM |
Posts: 5,525 | "wools" is that the same as "tell tails"? Some peope HATE tell tales on their spinnakers. My first spinnaker came without tell tales, the second with. It's the difference between night and day for me, I have to have them.
Pete Pollard Blade 702
| | | Re: Spin trim help
[Re: Chris9]
#230210 03/24/11 08:03 AM 03/24/11 08:03 AM |
Posts: 439 Memphis, TN | Have you measured the distance of the end of your spin pole to the top where the spin hoists to?
Here's what I have been told to do....
Measure the head of the spin to the tack. When you get that measurement, then add 1% to it. That should be your measurement from the end of your spin pole to the point where it hoists to.
Viper USA 132
1984 Hobie 18
| | | Re: Spin trim help
[Re: jody]
#230212 03/24/11 08:14 AM 03/24/11 08:14 AM |
Posts: 118 Pensacola, FL | Jody, An easy test would be to put the spin block back in the original place on the mast, raise the spin pole using a piece of line instead of the pelican striker, go out without the jib and see if the spin does better. If it does, I think it would be easy to make a pelican striker that is a few inches shorter.
Chris Trident F16
| | | Re: Spin trim help
[Re: Cab]
#230218 03/24/11 09:38 AM 03/24/11 09:38 AM |
Posts: 6,049 Sebring, Florida. | When you are sailing downwind, are you always trying to be on one hull? I always want to be on one hull unless it will lead to a swim.
I have 2 spins. A very "full" cut spin and a very flat one. I've found it's easier for me to fly a hull using the very flat one, I can head up, get the hull up, accelerate and ride it downwind on one hull much easier than with the very full cut spin, which doesn't want to go high enough to get the hull up in medium air.
In heavier air, I run deep on two hulls usually (when running on one will most likely result in a pitch-pole) so the fuller cut spin is better for that.
It is a little counter-intuitive, you would think the flater spin would be better (de-powered) in bigger winds but actually it's better in lighter air as you must head up higher to get the hull up. The fuller spin is better for running deep on two hulls in big air.
Blade F16 #777
| | | Re: Spin trim help
[Re: jody]
#230223 03/24/11 09:56 AM 03/24/11 09:56 AM |
Posts: 6,049 Sebring, Florida. | The fuller one is an older Glaser, from about 4 (?) years ago. The flatter one is about 1yr. old Landenberger.
The fuller one is easier to keep from stalling, but as I said before, you can't go as high with it to get the hull up in light/medium wind, where as the Landy is much easier to "heat it up" and get going after the set, get a hull up and get cruising. But when it's really blowing, I don't sail on one hull.
The times I've tried to go on one hull in big wind, I seem to stuff it to the mast too often, which really slows you down, even if you don't go swimming. I've found it's more 'productive' to sail it deep on two hulls and jump over the waves rather than plow through them on one hull and stuff it to the mast.
But in medium wind I want to be on one hull all the time, upwind and down, so the flatter spin works better for that.
Blade F16 #777
| | | Re: Spin trim help
[Re: Timbo]
#230226 03/24/11 11:01 AM 03/24/11 11:01 AM |
Posts: 186 Chattanooga, TN | how tight are you running the flatter spin on the sheets.
Jody
Blade F16 724
| | | Re: Spin trim help
[Re: jody]
#230229 03/24/11 11:41 AM 03/24/11 11:41 AM |
Posts: 548 MERRITTISLAND, FL | how tight are you running the flatter spin on the sheets. This should not matter. The sail should fly within a broad range of sheet tension settings. Rig the sail with the luff tension “in the ball park” 45-90 degrees with a fist twist. Then sail it. You can try different sheeting angles to see then if that is the issue or the sail is just a bad cut. If it is relatively light have the crew below and hold the sheets simulating more forward or a more aft sheet location. Forward will pull the leach and aft will pull the foot more. If it is windy it is easy to rig a quick moveable sheet point much like the old barberhauler system on my H20. The F16 has a max hoist height and a max spin pole length, so the potential combination of triangles for the sail are pretty limited. The Viper has a higher set pole but on the Blade if you jack up the pole the jib is also moved, so watch out screwing up that sail trim in the process. I would not go drilling new holes or cutting strikers off until you know that this is the fix that will actually work. | | | Re: Spin trim help
[Re: jody]
#230230 03/24/11 11:43 AM 03/24/11 11:43 AM |
Posts: 6,049 Sebring, Florida. | Pretty tight at times, maximum in, but that's only when I'm really trying to get as high as possible, usually when the wind is on the lighter side. Normally I'm easing and trimming continually trying to keep the luff on the edge of curling.
Also counter intuitive; easing the halyard will actually make the luff a little flatter so you can point a little higher, and pulling the halyard tighter will put more of a curl into the luff, which is ok when running deep in big air, but not what you want for pointing in light air.
Blade F16 #777
| | | Re: Spin trim help
[Re: Timbo]
#230231 03/24/11 11:49 AM 03/24/11 11:49 AM |
Posts: 6,049 Sebring, Florida. | Now Jody, if you would hurry up and get down here, we could get out and practice all this stuff on days like today!
Supposed to be 88 today, 92 by Sunday, and it's blowing 13 G 25 out back right now. I'm going on a bike ride now but when I get back, I'm going sailing.
Sebring, FL (33870) WeatherSave This Location Updated: Mar 24, 2011, 12:25pm EDTUPDATE DATANearby TruPoint Locations: Orlando International ... | Higlands Hammock State... | Your Address Overview Hourly Tomorrow Weekend 5-Day 10-Day Month Map Right Now Next 36 Hours Today Tonight Tomorrow Mostly Cloudy Partly Cloudy Mostly Clear Partly Cloudy 79°F 88° 59° 87° Feels Like: 81° Get FREE weather on your desktop High Low High Past 24-hr: Precip: 0 in Snow: 0 in Chance of Precip: 10% Chance of Precip: 10% Chance of Precip: 10% Wind: From WSW at 13mph gusting to 23mph Wind: WSW at 16 mph Wind: W at 10 mph Wind: NW at 7 mph
Blade F16 #777
2,549
guests, and 508
