Mast step link kit #23036
08/07/03 05:33 PM
08/07/03 05:33 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
Does anyone have a diagram on how to rig one of these?
I got one with my H14T but have never used one or seen one rigged.
Thanks,
TSU :
Tim S. Urfer 1984 Nacra 5.2
Re: Mast step link kit [Re: TSurfer] #23037
08/07/03 11:27 PM
08/07/03 11:27 PM
C
CrashedAgain Offline
C
It makes a hinge mounting at the base of the mast for stepping the mast. Check with a dealer or someone who has a H16, the H16 manual shows how to use it but the H14 manual does not.
Remove it as soon as the mast is stepped & stayed, if left in place it will try to prevent the mast from roatating & something will break.
Re: Mast step link kit [Re: CrashedAgain] #23038
08/08/03 07:37 PM
08/08/03 07:37 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
Thanks for your tip on the H16 manual but looking at the downloadable .pdf version of this it really doesn't show much.
Maybe the actual manual has it though?
TSU
Re: Mast step link kit [Re: CrashedAgain] #23039
08/09/03 09:43 AM
08/09/03 09:43 AM
K
kurtweiser Offline
kurtweiser  Offline
K
Hey Crashed,
A question on your post... Do you mean that once the mast is stepped and stayed, that one should remove the pin at the base of the mast step?
Re: Mast step link kit [Re: kurtweiser] #23040
08/10/03 08:40 PM
08/10/03 08:40 PM
C
C
Yes. and probably a good idea to remove the link parts too. The mast has to be free to swivel in its base and you don't want to lose any loose pieces. When I got my boat (H14), the lug that the pin goes through was broken right off the mast base casting, presumably from leaving the link connected. I made a new 'lug' piece which I clamped to the mast using the sail slot but it could be a very difficult repair for someone who is not an amateur machinist.
Re: Mast step link kit [Re: TSurfer] #23041
08/10/03 09:06 PM
08/10/03 09:06 PM
C
C
TSurfer-check page 36 of Murrays catalogue
http://murrays.com/archive/archive.html#anchor73592
There is a diagram showing how it connects.
Re: Mast step link kit [Re: CrashedAgain] #23042
08/10/03 10:37 PM
08/10/03 10:37 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
Thanks CrashedAgain.
That did the trick.
TSU
0 registered members (), 16,102 guests, and 1,036 spiders.
Most Online22,490
Yesterday at 08:14 AM
