Jib halyard #230335
03/28/11 05:15 AM
03/28/11 05:15 AM
Chattanooga, TN
jody Offline OP
jody  Offline OP
Chattanooga, TN
Ok I was going back through a monohull sailing book and they were going on about jib halyard tightness. How many people actually adjust this on the cat much? We usually pull is snug in medium air, tight in heavy air and i guess slightly less then snug in light air. On my H16 I remember the jib seemed to take over as the forestay when you tightened it up, should we be getting that tight on these boats?
Thanks
Jody Blade F16 724 Plays with Sharp Objects
Re: Jib halyard [Re: jody] #230619
04/01/11 07:53 AM
04/01/11 07:53 AM
I have my jib halyard adjustment rigged back to the front beam left side, so when winds go light or get stronger, I can adjust it as needed. One thing you want to be careful of, do not over-do it if you are going downwind, because when you turn upwind and pull on the mainsheet, it could be enough 'extra' to break it.
0 registered members (), 517 guests, and 100 spiders.
Posts267,056
