Wall thickness on beach wheel aluminum #231679
04/29/11 08:33 AM
04/29/11 08:33 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
whats the specs on aluminum tubing used for beach wheels? Is quarter inch?
I need a 9 ft long piece, anybody know a source in ATL for aluminum?
McMaster only sells it in 6ft legnths.
Re: Wall thickness on beach wheel aluminum [Re: bvining] #231685
04/29/11 09:08 AM
04/29/11 09:08 AM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
I know the older cattrak's was thinner than the currrent(and lighter). It is not so much the thickness but the stiffness level.
Re: Wall thickness on beach wheel aluminum [Re: orphan] #231687
04/29/11 09:17 AM
04/29/11 09:17 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Amen brother!
Re: Wall thickness on beach wheel aluminum [Re: ksurfer2] #231688
04/29/11 09:24 AM
04/29/11 09:24 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Amen brother!
From a woman that response is spot on and the timing is brilliant. From a dude... it's just gay. Love you anyway Karl, but I'm taken.
F18 USA 242
http://www.solarwind.solar
Re: Wall thickness on beach wheel aluminum [Re: bvining] #231689
04/29/11 09:30 AM
04/29/11 09:30 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
Bill
I could never find the right size and ended up buying from Florida Sailcraft.http://www.floridasailcraft.com/CatAccesories.htm
Re: Wall thickness on beach wheel aluminum [Re: Dlennard] #231692
04/29/11 10:13 AM
04/29/11 10:13 AM
mikekrantz Offline
mikekrantz  Offline
I've had good luck sourcing all types of metal at
www.metalsupermarkets.com
Re: Wall thickness on beach wheel aluminum [Re: mikekrantz] #231716
04/29/11 03:54 PM
04/29/11 03:54 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Thanks for the input, I ended up buying a 2" OD 10 ft long piece of PVC for $5, and some Seitech A wheels. I got the axels and plan on using some delrin as a way to make up the differience between the ID of the PVC and the OD of the axels. I will let you know how it works.
Re: Wall thickness on beach wheel aluminum [Re: bvining] #231721
04/29/11 05:52 PM
04/29/11 05:52 PM
catman Offline
catman  Offline
Alro Metals
This place has been good and if their near you no shipping.
Re: Wall thickness on beach wheel aluminum [Re: catman] #231722
04/29/11 05:58 PM
04/29/11 05:58 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I think I bought aluminum conduit from an electrical supply house. Was pretty heavy walled and worked well.
Dave
Re: Wall thickness on beach wheel aluminum [Re: bvining] #231754
05/01/11 07:07 AM
05/01/11 07:07 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
The PVC beach wheel experiment seems to be working out well.
Drilled a 1" hole in the PVC end cap, added two bolts 1 3/4" to the axle, in opposite planes to center the axle, glued the end cap onto the pipe.
the axle and the bolts are all contained inside the tube end cap glues it all together nicely. the best part is that if I dont like it, I only spent 10 bucks on the pvc.
Re: Wall thickness on beach wheel aluminum [Re: bvining] #231768
05/02/11 05:17 AM
05/02/11 05:17 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Well, this was a FAIL.
PVC isnt stiff enough
0 registered members (), 668 guests, and 112 spiders.
Posts267,056
